SolLesHonda Posted September 22, 2006 Author Share Posted September 22, 2006 Just the LS Rods. Link to comment Share on other sites More sharing options...
LAtuning Posted September 22, 2006 Share Posted September 22, 2006 There is only one slot, above that are heater and ac controls. Show us a pic because we're all confused here! Link to comment Share on other sites More sharing options...
LAtuning Posted September 22, 2006 Share Posted September 22, 2006 why the b20 crank pully and not a set of after market pullys? Link to comment Share on other sites More sharing options...
CleanGSR Posted September 22, 2006 Share Posted September 22, 2006 I noticed that your headset for the radio is in the bottom slot in your dash... I have that bottom slot open but figured I would take out my stock radio instead of having 2 radios...? What did you do with the stock radio that is in the dash... if it was in the dash at all? Del Sol's only have one slot with a cover that can hide it. Link to comment Share on other sites More sharing options...
SolLesHonda Posted September 22, 2006 Author Share Posted September 22, 2006 why the b20 crank pully and not a set of after market pullys? B20 crank pulley to use for the SC. Stock pulleys > Aftermarket ones. Link to comment Share on other sites More sharing options...
TS John Posted September 22, 2006 Share Posted September 22, 2006 Damnit, I had just typed a response here and hit back on the keyboard by mistake. Here it is again, slightly shorter: 1) Good call on Exospeed cam gear (I was just going with a trusted name before). 2) Skunk2 Throttle body too? Done. 3) What all is recommended fuel wise? 4) If I use crome or neptune how does that all work (ie what is required and where do I go for that?) 5) I'd really prefer to stick it out with the D15B7 and not swap on a Z6 or anything. Perhaps you could recommend a new set of pistons instead of a whole new setup? Link to comment Share on other sites More sharing options...
sohcVTEC-E Posted September 23, 2006 Share Posted September 23, 2006 Where did you get the OE radio block off plate? Can't find one in MI, if I paypal you will you send me one SolLes? Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted September 23, 2006 Share Posted September 23, 2006 He doesnt have a block off plate... Link to comment Share on other sites More sharing options...
90IntegraC1 Posted September 23, 2006 Share Posted September 23, 2006 i called Michael today. we talked. i want him to buy the H22 if this other guy bails again. that would be sweet. errrrrrbody convince him to do it. kthnx. Link to comment Share on other sites More sharing options...
TS John Posted September 23, 2006 Share Posted September 23, 2006 If he does it that would be sweet like candy. I would buy all his D series crap off of him in a heartbeat. Link to comment Share on other sites More sharing options...
99CiViCSi99 Posted September 23, 2006 Share Posted September 23, 2006 Damn mike. Lots of crap on order. How much you spend on all the stuff on order? And where you get all that money from last month where you had none.. Link to comment Share on other sites More sharing options...
SolLesHonda Posted September 23, 2006 Author Share Posted September 23, 2006 I worked. I sell street pharmaceuticals. Lol. Just kidding. I got my money back from what I had to pay for college. My Scholarship was late. What block off plate are you talking about? Link to comment Share on other sites More sharing options...
SolLesHonda Posted September 23, 2006 Author Share Posted September 23, 2006 Damnit, I had just typed a response here and hit back on the keyboard by mistake. Here it is again, slightly shorter: 1) Good call on Exospeed cam gear (I was just going with a trusted name before). 2) Skunk2 Throttle body too? Done. 3) What all is recommended fuel wise? 4) If I use crome or neptune how does that all work (ie what is required and where do I go for that?) 5) I'd really prefer to stick it out with the D15B7 and not swap on a Z6 or anything. Perhaps you could recommend a new set of pistons instead of a whole new setup? 1. Exospeed makes great cams. Take your cam, send it to them, and get the Stage 3. Get new valvetrain from them too. I believe they use Ferrea or Supertech, both are great. If you are going all motor, flat faced valves are preferred. 2. Skunk 2 TB, 68mm. 3. I'd do the fuel setup I ordered if you wanna spend a little more and know it's all brand new and perfect. I have Walbro In tank fuel pump, AEM Fuel Filter, B&M FPR, and AEM Fuel Rail. Get Russell lines and it will look "sweet like candy" as you say. 4. Crome is different than Hondata. It's like burning a chip and just replugging in your ECU. With the mods you have, I probably wouldn't even change anything with your stock ECU. Except remove your rev limiter. Because your motor is going to want to go beyond 7000RPMs. 5. D16a6 pistons, D16a6 or LS Rods, Stock HG, and mill the head 0.020 in and you have a compression of 11.18:1. Which, with a good tranny, headwrok, IM, I/H/E, you could make 140-170whp. Link to comment Share on other sites More sharing options...
TS John Posted September 24, 2006 Share Posted September 24, 2006 Coolness. So they shall be added to the list. Thanks, man. Link to comment Share on other sites More sharing options...
SolLesHonda Posted September 24, 2006 Author Share Posted September 24, 2006 I'm stoked to see how it works out. It sounds like a killer setup. Link to comment Share on other sites More sharing options...
SolLesHonda Posted September 25, 2006 Author Share Posted September 25, 2006 Ok, just something I wanted to see what people will say. For my sol, what do you all think would be more badass? SC'd D16 to make around 200-220whp, or All motor B18C1? Link to comment Share on other sites More sharing options...
90IntegraC1 Posted September 25, 2006 Share Posted September 25, 2006 N/A H22 w/ LSD Link to comment Share on other sites More sharing options...
Chubs Posted September 25, 2006 Share Posted September 25, 2006 N/A H22 w/ LSD Link to comment Share on other sites More sharing options...
mycarsux Posted September 25, 2006 Share Posted September 25, 2006 N/A H22 w/ LSD Link to comment Share on other sites More sharing options...
SolLesHonda Posted September 25, 2006 Author Share Posted September 25, 2006 I don't have the money right now. This won't be until about January when I do it all. Link to comment Share on other sites More sharing options...
TS John Posted September 25, 2006 Share Posted September 25, 2006 I'm stoked to see how it works out. It sounds like a killer setup. My setup plans? I'm stoked too. Wanna lend me some money? I might even pay it back! For my sol, what do you all think would be more badass? SC'd D16 to make around 200-220whp, or All motor B18C1? Edit: I had originally said B18C1 but now I think go with the SC D. Too many swaps spoil the broth. Unless you go H22 of course. Link to comment Share on other sites More sharing options...
SolLesHonda Posted September 25, 2006 Author Share Posted September 25, 2006 I talked to Dan. I might do it. Link to comment Share on other sites More sharing options...
TS John Posted September 25, 2006 Share Posted September 25, 2006 Do it. Do it. Then sell me your D series mods. Link to comment Share on other sites More sharing options...
Del Sol Tow Hook Posted September 25, 2006 Share Posted September 25, 2006 baaa Link to comment Share on other sites More sharing options...
SolLesHonda Posted September 25, 2006 Author Share Posted September 25, 2006 Lol. Which mods would you want? Link to comment Share on other sites More sharing options...
