Raley Posted December 19, 2010 Author Share Posted December 19, 2010 Hook a hot air ballon to it? Any specs on the track and any specs on suspension reqiurments? Link to comment Share on other sites More sharing options...
DelSolSweetie Posted December 20, 2010 Share Posted December 20, 2010 suspension is all us front is uneven a arm drivetrain decided on a swing arm / solid axle is the rear (WTF i know).. i wanted IRS from the start but im not on the team (thankfully) for some reason our advisor said the rear suspension was drivetrains choice so yah endurance track (there are also other dynamic/static events) will have like 1000ft of an M shaped water thing.. jumps.. rocks.. logs.. etc etc Link to comment Share on other sites More sharing options...
Ben. Posted December 20, 2010 Share Posted December 20, 2010 I have no idea what's going on here Link to comment Share on other sites More sharing options...
diablo2dusk Posted December 20, 2010 Share Posted December 20, 2010 theyll both have the same amount of power... Link to comment Share on other sites More sharing options...
Raley Posted December 20, 2010 Author Share Posted December 20, 2010 id do a soild rear end... sorta dirtbike/quad style... it will be lighter then irs...don't even put suspension on the front... just alil less air in the front tires... tell your guys to put a lil patting in there pants and stfu. Link to comment Share on other sites More sharing options...
DelSolSweetie Posted December 20, 2010 Share Posted December 20, 2010 lol no.. a arms up front solid rears dont normally do as well in the event as IRS cause of the stuff they come up with for the track but hopefully it'll last.. they are going with a pretty beefy axle so it should break Link to comment Share on other sites More sharing options...
Raley Posted December 20, 2010 Author Share Posted December 20, 2010 lower gearing, bigger tires... then you can make it over everything and still have a good speed... id mount the engine and rear axle on its own piviting part and then hook the suspension to that... old school style but very light. Link to comment Share on other sites More sharing options...
DelSolSweetie Posted December 20, 2010 Share Posted December 20, 2010 the swing arm is its own pivot.. engine is on back of chassis cant afford new tires.. the ones we have are 22 in tread to tread gearing is all within the cvt.. a lot of teams do really well with the cvt.. we just have to make sure its sealed up nice and good so the belts dont get wet Link to comment Share on other sites More sharing options...
Raley Posted December 21, 2010 Author Share Posted December 21, 2010 is there a price cap or is it basicly what the school says is the cap? also on price, is it based on each part? Link to comment Share on other sites More sharing options...
DelSolSweetie Posted December 21, 2010 Share Posted December 21, 2010 price cap is what we raise.. turns out we will be getting new rear tires.. need ones that will perform better in the water.. probably going to go with a $50 harbor freight notcher instead of the $200 one we were going to get Link to comment Share on other sites More sharing options...
Raley Posted December 22, 2010 Author Share Posted December 22, 2010 i have these on my quad... CLICKY! they are great in the water... kinda crapty in hard packed dirt but surprisingly not bad... Link to comment Share on other sites More sharing options...
DelSolSweetie Posted December 22, 2010 Share Posted December 22, 2010 have you strapped flotation on your atv and put fenders on the back and see if propelled you through the water well? lol i have a feeling its going to be MUDDY and fun kinda what we are going to have to do: except this year its an m shaped course with more water instead of just a lake thing to drive through Link to comment Share on other sites More sharing options...
Raley Posted December 22, 2010 Author Share Posted December 22, 2010 I usually just skip across it going 60.... haha. Link to comment Share on other sites More sharing options...
DelSolSweetie Posted March 4, 2011 Share Posted March 4, 2011 Link to comment Share on other sites More sharing options...
cmgogo Posted March 4, 2011 Share Posted March 4, 2011 looking good so far, however one thing you might want to look at doing is putting a cross brace on the front suspension mount box. Are you guys going to put in a belly pan or run open? If you are going to skin then I would recomend riveting alumnium sheet instead of welding steel plate. And for the sides look into using coroplast, its super lightweight, tough, flexible, and easy to work with. To mount it all you need to do is cut it into the shape, punch a few holes, and zip tie it to the chassis. and if you havent done it already foam fill your bars with expanding foam. It adds a little rigidity to them, but more importantly keeps water out. Link to comment Share on other sites More sharing options...
DelSolSweetie Posted March 4, 2011 Share Posted March 4, 2011 we have to cap the ends of the open tubes we are running .025 inch aluminum on the sides and rear roll hoop.. and a steel skid plate on the bottom.. rivets for all of it.. and the float on the bottom has to have a skid plate as well no zip ties or velcro allowed I hate the difference with the rear and front track widths.. drive train actually wants to bring the rear in even more.. they think it will be more "stable" closer together or something like that.. fantastic engineering decision right? Link to comment Share on other sites More sharing options...
Raley Posted March 4, 2011 Author Share Posted March 4, 2011 Id rather run 1 wheel in the back... like the t rex Link to comment Share on other sites More sharing options...
DelSolSweetie Posted March 4, 2011 Share Posted March 4, 2011 yah they made 3 wheel off road vehicles one time pretty sure they got banned cause they kept rolling and injuring people Link to comment Share on other sites More sharing options...
cmgogo Posted March 4, 2011 Share Posted March 4, 2011 well you dont want all 4 wheels inline with eachother, ideally you want the rear wheels closer together or farther apart by 5-10% of the chassis length to aid with turn in. for the side plates look into using the coroplast, its alot less expensive and you can rivet it on, you will just need to use fender washers to help spread the load. Link to comment Share on other sites More sharing options...
DelSolSweetie Posted March 4, 2011 Share Posted March 4, 2011 our front track width (outside tire to outside tire) is right about 60 inches they want the rear between 42 inches and 45 inches Link to comment Share on other sites More sharing options...
cmgogo Posted March 4, 2011 Share Posted March 4, 2011 our front track width (outside tire to outside tire) is right about 60 inches they want the rear between 42 inches and 45 inches noooooo too narrow, the narrowest I would put it at would be 50', any narrower than that and you loose stability and increase oversteer. Link to comment Share on other sites More sharing options...
Raley Posted March 4, 2011 Author Share Posted March 4, 2011 They were just heavy and the front forks would break and make a sweet poll vault Link to comment Share on other sites More sharing options...
DelSolSweetie Posted March 5, 2011 Share Posted March 5, 2011 noooooo too narrow, the narrowest I would put it at would be 50', any narrower than that and you loose stability and increase oversteer. everyone knows this but them ill make sure to record the first couple testings and see how long it takes to roll it or for them to spin out.. or any other funny Link to comment Share on other sites More sharing options...
Raley Posted March 5, 2011 Author Share Posted March 5, 2011 I think this summer i might build one... i found my briggs so i have a motivation Link to comment Share on other sites More sharing options...
DelSolSweetie Posted March 5, 2011 Share Posted March 5, 2011 we bent our first tube last week of jan/beginning of feb. and are that far... and since you wouldnt have to work with people in my group you could probably get it done faster if you had the tools to do it lol Link to comment Share on other sites More sharing options...
