del sol daddy-O Posted May 26, 2009 Share Posted May 26, 2009 Hello to all! I am new to this forum and relatively new to owning a 1993 Del sol. I am currently in need of an engine or doing some engine work to this little car. I'm new to working on imports so please be patient as I may ask a lot of newbie questions that seem simple to most of you. thanks in advance for any help in getting this thing under way! Quote Link to comment Share on other sites More sharing options...
Xeryon Posted May 26, 2009 Share Posted May 26, 2009 Hello and welcome to HF. Don't be put off if anyone here acts like an asshat from time to time. In general the people are nice and will help you where they can. Quote Link to comment Share on other sites More sharing options...
SpeedDemon Posted May 26, 2009 Share Posted May 26, 2009 Welcome To The Forum Quote Link to comment Share on other sites More sharing options...
DelSolSweetie Posted May 27, 2009 Share Posted May 27, 2009 welcome!! we will help Quote Link to comment Share on other sites More sharing options...
wannaBstuntin Posted May 27, 2009 Share Posted May 27, 2009 Welcome to the thunderdome bitch. Quote Link to comment Share on other sites More sharing options...
nnoossss Posted May 27, 2009 Share Posted May 27, 2009 hello Quote Link to comment Share on other sites More sharing options...
s_adbell Posted May 27, 2009 Share Posted May 27, 2009 run Quote Link to comment Share on other sites More sharing options...
tallhamer88 Posted May 27, 2009 Share Posted May 27, 2009 welcome to the forum champ Quote Link to comment Share on other sites More sharing options...
AsianLady Posted May 27, 2009 Share Posted May 27, 2009 Dead Slow, Hahah im kidding. Quote Link to comment Share on other sites More sharing options...
bluebyu Posted May 27, 2009 Share Posted May 27, 2009 Que Pasa. What help can we start you off with? Quote Link to comment Share on other sites More sharing options...
hiemsnox Posted May 28, 2009 Share Posted May 28, 2009 welcome to the forums and the del sol addiction Quote Link to comment Share on other sites More sharing options...
del sol daddy-O Posted June 1, 2009 Author Share Posted June 1, 2009 Well the sol was burning A LOT of oil and then quit all together. I pulled the head off of the D15B7 that is in it and found two of the exhaust valves to be actually broken out along the radius. (cylinders 1 & 3) I looked and could see not signs of damage to the cylinder walls nor any remnants of the missing valve pieces. Has anyone ever heard of this happening before? Still doesn't really explain the burning oil though does it? I'm thinking blown head gasket as well since #4 had signs of some pretty nasty deposits on the valves as well. This car was just meant to be an inexpensive commuter/fun car so right now I dont think I'm gonna do too much to it other than just get it running so I can start saving some cash...maybe more later then. Quote Link to comment Share on other sites More sharing options...
alex37211 Posted June 1, 2009 Share Posted June 1, 2009 (edited) I had a broken valve in my sol. If you have a haynes manual, a torque wrench, and a valve spring compressor ($10) you can change them. Try to find a parts head rather than buying new parts. I found a complete good head for $30 but just used it for parts because it looked nasty. Clean those nasty deposits off with a wire brush wheel attached to a drill. If it's burning a lot of oil though, the rings may be shot. In this case, just find another engine. They are usually $150-$250 for a good used d15b7. Or if you want to eventually make this car faster, there are other motors that would bolt right in for you. Are you sure it isn't leaking oil? Oh and welcome and stuff. Edited June 1, 2009 by alex37211 Quote Link to comment Share on other sites More sharing options...
del sol daddy-O Posted June 3, 2009 Author Share Posted June 3, 2009 I had a broken valve in my sol. If you have a haynes manual, a torque wrench, and a valve spring compressor ($10) you can change them. Try to find a parts head rather than buying new parts. I found a complete good head for $30 but just used it for parts because it looked nasty. Clean those nasty deposits off with a wire brush wheel attached to a drill. If it's burning a lot of oil though, the rings may be shot. In this case, just find another engine. They are usually $150-$250 for a good used d15b7. Or if you want to eventually make this car faster, there are other motors that would bolt right in for you. Are you sure it isn't leaking oil? Oh and welcome and stuff. The engine was definitely burning the oil. What other engines would be a direct bolt in? What all would be involved in doing this? ie. ecm, torque converter/flywheel, etc... mine is an automatic. my thoughts were to re-ring the engine since I already had the head off. The cylinder walls look like they are in pretty good shape with no visible cracks or gouges in them. Quote Link to comment Share on other sites More sharing options...
cmgogo Posted June 3, 2009 Share Posted June 3, 2009 well a d16z6 (si trim motor) will bolt right up. and your tranny should bolt right up. about 99% of your parts will work with the d16z6. D motors are great, they are cheap, reliable, and for the most part interchangeable with their parts, especialy the d16's. not sure about the d15/d16 change over though. The other thing you might want to look at doing is something called a mini-me. You take the head off of your b7, and put the head of a z6 on. All you need to install other that that is 1 wire for your vtec solinoid (if you even want to use it) should net you a few ponnies, and it will prob cost you just as much to do it as it would to repair your current dilema Quote Link to comment Share on other sites More sharing options...
del sol daddy-O Posted June 7, 2009 Author Share Posted June 7, 2009 well a d16z6 (si trim motor) will bolt right up. and your tranny should bolt right up.about 99% of your parts will work with the d16z6. D motors are great, they are cheap, reliable, and for the most part interchangeable with their parts, especialy the d16's. not sure about the d15/d16 change over though. The other thing you might want to look at doing is something called a mini-me. You take the head off of your b7, and put the head of a z6 on. All you need to install other that that is 1 wire for your vtec solinoid (if you even want to use it) should net you a few ponnies, and it will prob cost you just as much to do it as it would to repair your current dilema By putting a z head on my 1.5 would this make it vtec? what wire would you be referring to that i wold need to add? Would my existing distributor work or would I also need the distributor off of a d16z6? How can I positively identify one from the other since I am new to these? Quote Link to comment Share on other sites More sharing options...
airjordan223 Posted June 7, 2009 Share Posted June 7, 2009 hey man welcome to the forums. heres a write-up of the mini-me swap, it should give you a better idea of whats going on http://www.jdmuniverse.com/forums/how-tos-...p-write-up.html Quote Link to comment Share on other sites More sharing options...
del sol daddy-O Posted June 10, 2009 Author Share Posted June 10, 2009 hey man welcome to the forums. heres a write-up of the mini-me swap, it should give you a better idea of whats going on http://www.jdmuniverse.com/forums/how-tos-...p-write-up.html Thanks. much appreciated! Quote Link to comment Share on other sites More sharing options...
