Ian93EG Posted November 4, 2010 Share Posted November 4, 2010 so i have a 1993 Honda Civic Hatchback EG with a stock D15B7 non-vtech motor in it, but i want to build a D16Y8 or Z6 with a ZC bottom end. can and which would be better/more power, but safe, to throw on top of the ZC bottom end, D16Y8 or Z6 head? and would it be ok if i threw RC440cc injectors on my D15B7? what would happen? more power? may fail? just wondering and trying to questions answered before i do stuff Link to comment Share on other sites More sharing options...
C92hatchX Posted November 4, 2010 Share Posted November 4, 2010 you dont need bigger injectors in a stock d15 either head would be fine id personally would go with the z6 make sure you have everything before doing the mini me swap Link to comment Share on other sites More sharing options...
Ian93EG Posted November 4, 2010 Author Share Posted November 4, 2010 tru, but bigger injectors means more power. and yea im gonna buy a ZC bottom end and most likely a Z6 head, i will also throw the injectors on the build and try an boost it sum Link to comment Share on other sites More sharing options...
Xeryon Posted November 4, 2010 Share Posted November 4, 2010 bigger injectors does not mean more power. all that will happen is you will be wasting fuel unless the rest of the motor is built accordingly. honda motors are not limited by fuel supply, it is air flow that is your limiting factor. it is pretty safe to assume that stock injectors should be sufficient all the way up to around 200hp before you run into supply problems. Link to comment Share on other sites More sharing options...
Escape-performance Posted November 22, 2010 Share Posted November 22, 2010 If you put in larger injectors without a way to control them your car will run like crap, waste fuel, and make LESS POWER. Link to comment Share on other sites More sharing options...
lastresort576 Posted November 22, 2010 Share Posted November 22, 2010 This is how your car will run with dsm 450cc blue top injectors...And yes that is fuel vapor being pissed out of the exhaust. Absolutely ZERO power and barely crawled at a high rpm through my neighborhood to my buddies house so I could install my turbo..Tn theory the car should never have ran but it had been just rebuilt for high boost. Link to comment Share on other sites More sharing options...
cmgogo Posted November 22, 2010 Share Posted November 22, 2010 tru, but bigger injectors means more power. and yea im gonna buy a ZC bottom end and most likely a Z6 head, i will also throw the injectors on the build and try an boost it sum If you honestly think this, then maybe you should rethink your idea of rebuilding a motor. Bigger injectors do not mean more power More air AND more fuel mean more power You need to READ READ READ. Link to comment Share on other sites More sharing options...
Ian93EG Posted November 27, 2010 Author Share Posted November 27, 2010 im tryn to learn at the same time lol Link to comment Share on other sites More sharing options...
Raley Posted November 27, 2010 Share Posted November 27, 2010 im tryn to learn at the same time lol thats useally really really expensive. Link to comment Share on other sites More sharing options...
GTS 2.4 Posted December 3, 2010 Share Posted December 3, 2010 This is how your car will run with dsm 450cc blue top injectors...And yes that is fuel vapor being pissed out of the exhaust. Absolutely ZERO power and barely crawled at a high rpm through my neighborhood to my buddies house so I could install my turbo..Tn theory the car should never have ran but it had been just rebuilt for high boost. lol it sounds like its got asthma Link to comment Share on other sites More sharing options...
DelSolSweetie Posted December 4, 2010 Share Posted December 4, 2010 why has no one pointed out the obvious why the hell are you going to find a ZC bottom end just to put a Z6 head on it? they are the same fricken motor assuming you are talking a SOHC There are (3) ZC's: DOHC non vtec SOHC non vtec SOHC vtec --------- aka the Z6 without a sensor on the back of the intake mani and maybe 5 more hp and a smidge more torque Last time I checked if you get a dohc zc you cant put a sohc head on it.. so you cant be talking about that so i'm going to assume you want a SOHC ZC.. aka a Z6 bascially either do a mini me and put a d16 head on the d15.. or just get a d16 from somewhere and drop that in and you better not ask how to do either one of those cause there are 193409 write ups on the internet about both mini mes and d15 to d16 swaps Link to comment Share on other sites More sharing options...
