SolLesHonda Posted August 28, 2006 Author Share Posted August 28, 2006 On how much boost? Link to comment Share on other sites More sharing options...
CleanGSR Posted August 28, 2006 Share Posted August 28, 2006 A gt28 is different than a t28 though....(I think) Link to comment Share on other sites More sharing options...
SolLesHonda Posted August 28, 2006 Author Share Posted August 28, 2006 Oh yeah most definitely. T28 is journal bearing, GT28 is ball bearing for one. Link to comment Share on other sites More sharing options...
SolLesHonda Posted August 28, 2006 Author Share Posted August 28, 2006 Ok question. For my setup, if I ran on stock A6 internals for a while with a built Z6 head, would you go with the GT28RS or GT25R from Full-Race? Link to comment Share on other sites More sharing options...
xxscaxx Posted August 28, 2006 Share Posted August 28, 2006 i agree with ssr and cranny. gt35r is wayy too big. stick with a t3 or ssr's suggestion. nice build up though. Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted August 28, 2006 Share Posted August 28, 2006 GT28RS. Link to comment Share on other sites More sharing options...
SolLesHonda Posted August 29, 2006 Author Share Posted August 29, 2006 I want a ball bearing turbo. Out of the two I posted, I think I am going to get the GT28RS. Link to comment Share on other sites More sharing options...
That Guy Posted August 29, 2006 Share Posted August 29, 2006 hahaha , it is cheap style solles , but it does work , and there solid as a rock. but i hear ya for 250 fuk it. just a suggestion. welding is not hard unless youve never done it. ive welded quite a bit and you get good at it after a while like anything. when your MIG welding , once your arc is started , make tiny back and forth U's between 2 surfaces your welding together. find the right power and wire settings on every thing you weld first so its strong. your not hitting 300 WHP with a D and a T28(unless it has different housing) its that simple. there tiny. go T3 for sure solles. stick with your .48 man , your in. I know how to weld, just havent done too much of it myself, I always had my brother do it for me but i dont live in cali any more so its a hassle to get him to do it. and plus im practicing to get better, lke you said the more you do the better you get like anything you do. I just bought a tig welder cause i wanted to do a chromoly cage in my car, would you suggest a different metal? im just curious cuz i know 4130 is strong enough but dont know if there is stronger metal for less $ Link to comment Share on other sites More sharing options...
cranny Posted August 29, 2006 Share Posted August 29, 2006 chromoly good choice for weight reasons. but ill be totally honest ive never welded it , nor read about welding it. but im sure theres lots of info on it out there. all you need to know is what gas to use and what wire , or for your TIG welder , what filling rods. i mean to be quite honest id go with mild steel for that job , its inside the car so it wont rust , just paint it before installing it flat black or somin. you could make your roll cage from mild steel thick wall round stock , or even if you wanted to bump up on the quality , go with stainless steel exhaust pipe(i know sounds funny , but its actually perfect for what you want). no rust , easy to weld , stainless steel good for learning to weld on. one more time for those who dont know: TIG - tungsten inert gas MIG - metal inert gas Link to comment Share on other sites More sharing options...
That Guy Posted August 29, 2006 Share Posted August 29, 2006 ya i found a book all about welding and its a damn good informative source for welding, tells you all the temps wire metals welders etc that go with each other. like carbon steel needs to be tig welded and same with chromoly since it does have carbon in it. and i do plan on painting it. this is my first time doin a cage myself, never really was interested in them but im gona need it in this car. whats the regulations on cages does anyone know? like what type of metal it needs to be? all i know is you need like a 6 inch sheet base at every contact point where you weld the cage to the frame. Link to comment Share on other sites More sharing options...
SolLesHonda Posted August 29, 2006 Author Share Posted August 29, 2006 Stop whoring my thread about metal. Link to comment Share on other sites More sharing options...
sohcVTEC-E Posted August 29, 2006 Share Posted August 29, 2006 You should get a GT75 Link to comment Share on other sites More sharing options...
SolLesHonda Posted August 29, 2006 Author Share Posted August 29, 2006 Lol. But for real I am definitely getting the GT28RS. The graph looks great. Will I need an adapter for the mani since it has a T3 flange, or shouldn't the turbo have a T3 outlet? Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted August 29, 2006 Share Posted August 29, 2006 No. Link to comment Share on other sites More sharing options...
SolLesHonda Posted August 29, 2006 Author Share Posted August 29, 2006 No to what? Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted August 29, 2006 Share Posted August 29, 2006 I thought it had a T28 flange. Link to comment Share on other sites More sharing options...
blackdelsol Posted August 29, 2006 Share Posted August 29, 2006 get the disco potato Link to comment Share on other sites More sharing options...
sohcVTEC-E Posted August 29, 2006 Share Posted August 29, 2006 How'd it get that nickname? Link to comment Share on other sites More sharing options...
Chubs Posted August 29, 2006 Share Posted August 29, 2006 get the disco potato DISCO POTATO FTW!! Thats why im goign to be running soon enough, inless Sexy decides to coaporate with me =) How'd it get that nickname? Can you not see the resemblance ?? Lol. Link to comment Share on other sites More sharing options...
90IntegraC1 Posted August 29, 2006 Share Posted August 29, 2006 are you gonna make sure the IM and head are ported to match, along with making sure the TB is the optimal size for the port of the IM and head? or, are you sure the 65 mm TB is the perfect size for a ported IM and head? Link to comment Share on other sites More sharing options...
sohcVTEC-E Posted August 29, 2006 Share Posted August 29, 2006 Yeah solles, are you sure of all that? Link to comment Share on other sites More sharing options...
90IntegraC1 Posted August 29, 2006 Share Posted August 29, 2006 im just askin b/c if i were to spend all that $$$ i would make sure everythings ported to match and that the tb is the optimal size for the port. Link to comment Share on other sites More sharing options...
90IntegraC1 Posted August 29, 2006 Share Posted August 29, 2006 ? Link to comment Share on other sites More sharing options...
SolLesHonda Posted August 30, 2006 Author Share Posted August 30, 2006 The IM is 62 mm opening, and the TB is 62 mm too. Link to comment Share on other sites More sharing options...
90IntegraC1 Posted August 30, 2006 Share Posted August 30, 2006 GOOD. im glad you know what you're doing. Link to comment Share on other sites More sharing options...
