95delsolboy Posted December 2, 2007 Share Posted December 2, 2007 Okay tell me what you think of my Del sol. Motor upgrades __________________ Greddy T3 Turbo Greddy Turbo Manifold HKS BOV Greddy Intercooler and piping Apexi VAFC Autometer Mesh Boost Gauge OBX Rising Rate Fuel Pressure Regulator 450cc Injectors Synapsi Missing link MAP sensor ZEX 59100 cam AEM adjustable cam gear Crower Dual valve springs titanium valves Low Compression Pistons Eagle Crank Eagle Rods Unorthodox Power Pulleys Skunk 2 ECU Accel Plug Wires External Coil Denso Plugs Transmission upgrade _______________________ 400HP axels Xedey Stage 2 clutch suspension upgrade ____________________ Tokico adustable struts skunk 2 coil overs front and rear camber kits Lightweight Control Arms Upper and Lower Front and Rear Strut Supports H type frame connector Cabin Bars Exterior mods ____________________ Z3 Fenders VIS carbon Fider vented hood Invader urethane front bumper wings west urethane side skirts R34 urethane rear bumper Clear headlights and corners Clear markers Clear taillights PIAA aux lights Aluminum Wing powder coated GSR wheels interior mods _______________ 5" dragon tach carbon fiber overlays b&m short shifter car toys custom 12" enclosure clarion head unit rockford fosgate components black out boost gauge and oil pressure gauge Link to comment Share on other sites More sharing options...
airjordan223 Posted December 2, 2007 Share Posted December 2, 2007 well a lot of people on here will not like it because of the kit, fenders, spoiler, tach, floormats etc, stuff like that, so be prepared for some heat. its not really my taste, but i respect the work done to the car. theres a lot of cosmetic stuff and a decent amount of motor work as well to go along with it. what kind of numbers are you putting down with the boosted set-up? also i didnt see anything you tuned it with, have you done that yet? Link to comment Share on other sites More sharing options...
TS John Posted December 2, 2007 Share Posted December 2, 2007 Not my style (too flashy) but it's at least done well. It's a lot worse to see cheaply done cosmetic stuff than quality work. Also wondering about tunes and times and things. Link to comment Share on other sites More sharing options...
wannaBstuntin Posted December 2, 2007 Share Posted December 2, 2007 Pretty flashy, but at least most of it matches well. The wing/fenders/tails look the most out-of-place. But damn, that's a lot of work. How much would you say you've put into it $-wise? Link to comment Share on other sites More sharing options...
Xeryon Posted December 2, 2007 Share Posted December 2, 2007 this guy is already ok in my book. I gave him some crap about his car after his first post and he took it very well. You already know my opinion: I think it would be cheaper to start over then to try and remedy the problems this car has. The three things that are an immediate negative to me are the stickers on the doors, the absurdly large spoiler and the altezza tails. All three I think you could rework a little and the appeal of the car would go up immensely. Do some nice smoke tinted tails to fit your red/black theme, put on a more subtly sized spoiler - something a bit lower to the deck would look excellent, and save the stickers for applying to the side of your tool boxes. Aside from these three I mentioned above I won't further knock it. It does look well crafted. edit: I just had a thought! His ride is about the perfect one for an Ameripol (sp?) glasstop - don't do a carbon skin, get the glass one. Link to comment Share on other sites More sharing options...
TS John Posted December 2, 2007 Share Posted December 2, 2007 All del sols should get the Ameripol top. It's just so ded secksay. Good points on how to improve his ride. I think that would help a lot but different front/rear bumpers would have to be added to the list for my tastes. Link to comment Share on other sites More sharing options...
Ben. Posted December 2, 2007 Share Posted December 2, 2007 how about oem appearance with MAYBE a lip kit. and rims. and a drop. period. Link to comment Share on other sites More sharing options...
95delsolboy Posted December 2, 2007 Author Share Posted December 2, 2007 Thanks for all the information. I havent ran a Dyno or anything yet, but the estimated HP is 190hp but we think its running closer to 200hp. But I havent had the time or money to run a drag strip or dyno. and to busted is 1- I think ill pass on more of a drop. The race suspension I put into it put an 1 1/2 inch drop, and I have already ripped off or busted the front bumper multiple times, and have even busted the back bumper once. And Wannabstuntn- Me personally have somewhere between $9,000 & $9,500 dollors in it, plus my brother has given me parts. Link to comment Share on other sites More sharing options...
wannaBstuntin Posted December 2, 2007 Share Posted December 2, 2007 I'm pretty sure busted meant only do those things, not add them to your list. $9K isn't bad for that much stuff. Link to comment Share on other sites More sharing options...
Ben. Posted December 2, 2007 Share Posted December 2, 2007 Thanks for all the information. I havent ran a Dyno or anything yet, but the estimated HP is 190hp but we think its running closer to 200hp. But I havent had the time or money to run a drag strip or dyno. and to busted is 1- I think ill pass on more of a drop. The race suspension I put into it put an 1 1/2 inch drop, and I have already ripped off or busted the front bumper multiple times, and have even busted the back bumper once. And Wannabstuntn- Me personally have somewhere between $9,000 & $9,500 dollors in it, plus my brother has given me parts. no, i pretty much meant crapcan your current bumpers and go oem with a lipkit. then slam it some more. Link to comment Share on other sites More sharing options...
Kegger Posted December 2, 2007 Share Posted December 2, 2007 Actually I don't mind that kit, sure it's flashy, but not too extreme. Wings gay though, lol. Link to comment Share on other sites More sharing options...
Ben. Posted December 2, 2007 Share Posted December 2, 2007 Dude the corners look like the mouth of a bumper from the movie Cars. Link to comment Share on other sites More sharing options...
wannaBstuntin Posted December 2, 2007 Share Posted December 2, 2007 lol Basically I like the majority of the front and sides, but not the rear. Link to comment Share on other sites More sharing options...
Hatch92 Posted December 2, 2007 Share Posted December 2, 2007 how much boost are you running it on? is it tuned at all? if it was mildly tuned and runnin around 8psi it should be puttin a little more than 190. Link to comment Share on other sites More sharing options...
95delsolboy Posted December 2, 2007 Author Share Posted December 2, 2007 Dude the corners look like the mouth of a bumper from the movie Cars. Yea, I actually thought about turning it into a cars car. But I was like no way. Link to comment Share on other sites More sharing options...
Ben. Posted December 3, 2007 Share Posted December 3, 2007 lol dude is cool by me. he didn't get butthurt when i instigated. Link to comment Share on other sites More sharing options...
TS John Posted December 3, 2007 Share Posted December 3, 2007 In all fairness, I don't see his kit or his wing as any worse than yours, sebby. He seems pretty cool. Hope he sticks around. We need a rather intelligent member who has a flashy car to increase the diversity on this site. Link to comment Share on other sites More sharing options...
Ben. Posted December 3, 2007 Share Posted December 3, 2007 I like his more than Sebs. Mainly because the mesh he has (if any) isn't as noticeable. That crap is cheesy looking. Link to comment Share on other sites More sharing options...
95delsolboy Posted December 3, 2007 Author Share Posted December 3, 2007 In all fairness, I don't see his kit or his wing as any worse than yours, sebby. He seems pretty cool. Hope he sticks around. We need a rather intelligent member who has a flashy car to increase the diversity on this site. Well thanks I apreciate that, but im no where near being as smart about cars as people on here. I can install stuff and modify it, but Im not good at telling specs and what parts are good, and actually naming off parts. But im working on making myself smarter. And to seb..- Our cars are like really close in looking the same. You wings the same hieghth as mine and alot of stuff is the same. Link to comment Share on other sites More sharing options...
TS John Posted December 3, 2007 Share Posted December 3, 2007 I like mesh... Link to comment Share on other sites More sharing options...
Xeryon Posted December 3, 2007 Share Posted December 3, 2007 lol dude is cool by me. he didn't get butthurt when i instigated. thats what I said. looks like he passed the HF flame test - hes fireproof! look into the Ameripol top instead of the one you have with the roof scoop on it. A glasstop would be sweet! Link to comment Share on other sites More sharing options...
Ben. Posted December 3, 2007 Share Posted December 3, 2007 i know, x. sometimes it doesn't work like that with other people. they're cool towards one, snap towards another. Link to comment Share on other sites More sharing options...
95delsolboy Posted December 3, 2007 Author Share Posted December 3, 2007 thats what I said. looks like he passed the HF flame test - hes fireproof! look into the Ameripol top instead of the one you have with the roof scoop on it. A glasstop would be sweet! Well thanks, but I think its kindof stupid to get mad over the internet. Plus I respect other peoples opinions. If we had all the same opinions this would be a boring world to live on. Is this glass top tinted or what, and how much does it run in cost. and by the way, Right now I only have 35 dollors to my name. I had a $250 speeding ticket I had to pay for. Link to comment Share on other sites More sharing options...
wannaBstuntin Posted December 3, 2007 Share Posted December 3, 2007 I had a $250 speeding ticket I had to pay for. haha, only 1, and only $250? Link to comment Share on other sites More sharing options...
Xeryon Posted December 3, 2007 Share Posted December 3, 2007 we were just talking about the top the other day.....here is the old thread with a few pics and some pricing info. last weeks thread about glass tops Link to comment Share on other sites More sharing options...
