20011.7vtech Posted November 16, 2010 Share Posted November 16, 2010 ok i have a 2001 civic ex vtec.Today I was driving and everything was normal,until the engine started bogging out like the safety switch came on,I went to two shops and had it read,both came back error connect cables,blah,blah,blah, then the glove box area started clicking,and the cel kept flickering, just some random sam and dean winchester type stuff,I need help, I've been told that it might be the ecu if so plz let me know. Also would it be easier to kill two birds with one stone,if it is the ecu,to get a performance replacement granted i can ebay one for a good deal. ty in advance Link to comment Share on other sites More sharing options...
airjordan223 Posted November 17, 2010 Share Posted November 17, 2010 A performance ecu won't give you anything extra unless you have performance parts Link to comment Share on other sites More sharing options...
20011.7vtech Posted November 17, 2010 Author Share Posted November 17, 2010 I have typical performance parts i.e. c/a intake,exhaust,and so on Link to comment Share on other sites More sharing options...
airjordan223 Posted November 17, 2010 Share Posted November 17, 2010 Won't really do anything unless you're boosted or highly modded N/A Link to comment Share on other sites More sharing options...
Xeryon Posted November 17, 2010 Share Posted November 17, 2010 in regards to a performance ecu: basic bolt on items would not require ecu replacement. forced induction or internal machining could bring about that need, anything else it would be a waste of your money and you most likely will cause your power and fuel mileage to decrease. Link to comment Share on other sites More sharing options...
20011.7vtech Posted November 17, 2010 Author Share Posted November 17, 2010 o.k. oem it is then 'cuz i don't plan on boosting. side note could it be the little relays that sit in front of the ecu causing that clicking noise and malfunction if so i searched both and only had results for one not the other. even sidier note how do i test the functionality of the two they have no visible wear to speak of Link to comment Share on other sites More sharing options...
cranny Posted November 18, 2010 Share Posted November 18, 2010 those relays are the PGMFI relays. aka main relays. Link to comment Share on other sites More sharing options...
mpearce1974 Posted November 18, 2010 Share Posted November 18, 2010 Comingfrom left field, but could you possibly be having grounding issues?? Bad ECU ground or shorting one would cause world of issues...... Link to comment Share on other sites More sharing options...
20011.7vtech Posted November 23, 2010 Author Share Posted November 23, 2010 i looked and couldnt tell but now im thinking it could be a map sensor issue Link to comment Share on other sites More sharing options...
20011.7vtech Posted November 23, 2010 Author Share Posted November 23, 2010 the throttle and intake inlet area are making this rapid clicking noise that wasnt an issuue before. also when the clicking under the dash stops and the engine bogs out i noticed that i have no guages no heat rpm speed or gas nothing works Link to comment Share on other sites More sharing options...
20011.7vtech Posted November 23, 2010 Author Share Posted November 23, 2010 also i just realized my main belt was ridiculously loose (didnt think the car could even run without it but i guess so) could that be the issue Link to comment Share on other sites More sharing options...
20011.7vtech Posted December 14, 2010 Author Share Posted December 14, 2010 well i fixed and replaced a bunch of stuff including the ecm (which has the same part #) some of the issues were fixed but there is still the issue of no instuments or inability to go over 3000 rpm (each gear) and the sputtering at hirgher rpm please if any one can help im lost Link to comment Share on other sites More sharing options...
DelSolSweetie Posted December 15, 2010 Share Posted December 15, 2010 did you change the map Link to comment Share on other sites More sharing options...
20011.7vtech Posted January 5, 2011 Author Share Posted January 5, 2011 yeah its in the shop now and has been for like a month and they still cant figure it out yea its a honda shop too Link to comment Share on other sites More sharing options...
OTiS Posted January 6, 2011 Share Posted January 6, 2011 is it smoking any? when my headgasket blew i wasnt able to go past a certain rpm and when it did it ran like even more crap. thats probably not the issue but its a suggestion. also check your grounds like pearce said. Link to comment Share on other sites More sharing options...
adamEj6 Posted January 9, 2011 Share Posted January 9, 2011 stuck in limp mode, is it still giving you a CEL? Link to comment Share on other sites More sharing options...
20011.7vtech Posted January 13, 2011 Author Share Posted January 13, 2011 WELL ALL IS SAID AND DONE IT TURNED OUT THAT THE ECU NEEDED REFLASHING SO HONDA HAS IT NOW AND THE MECH TOLD ME EVERYTHING IN THE CAR WAS IN PRISTENE COND. WHICH IS A PLUS FOR A 10 YEAR OLD CAR THANKS GUY FOR ALL THE HELP HOPE TO HEAR FROM YOU ALL ON MY OTHER TOPICS THANKS AGAIN Link to comment Share on other sites More sharing options...
boostingcivicsi Posted February 22, 2011 Share Posted February 22, 2011 Good to know you figured it out. Link to comment Share on other sites More sharing options...
