ATF Posted August 28, 2009 Share Posted August 28, 2009 Will most civic parts work on a del sol??? The reason I'm asking is because my neighbor (who works on cars) said they are hard to get parts for. Quote Link to comment Share on other sites More sharing options...
airjordan223 Posted August 28, 2009 Share Posted August 28, 2009 del sol parts are not hard to find at all. a lot of the mechanical ones will swap over, what parts were you thinking? Quote Link to comment Share on other sites More sharing options...
ATF Posted August 28, 2009 Author Share Posted August 28, 2009 del sol parts are not hard to find at all. a lot of the mechanical ones will swap over, what parts were you thinking? I'm not sure yet. Just basic stuff to make sure the car runs good. I'm going to see a Del Sol in a few days that may need some work. Quote Link to comment Share on other sites More sharing options...
airjordan223 Posted August 28, 2009 Share Posted August 28, 2009 yeah you'll be able to get del sol part without a problem. if you want new OEM parts check out majestic honda. if you want used, check out forums and junkyards Quote Link to comment Share on other sites More sharing options...
nobody Posted August 28, 2009 Share Posted August 28, 2009 it may be hard to find some parts at a junk or to find a sol, i think the only way is to order parts or just take em off a civic like i did. coudnt find any sols at any junk :l Quote Link to comment Share on other sites More sharing options...
BrIaN EG2 Posted August 28, 2009 Share Posted August 28, 2009 alot of 92 - 95 civic hatchback parts will fit as for suspension 92 - 95 civic and 94 - 01 integra suspension parts will work.. i have integra GSR LCA's and GSR sway bars on my del sol and my tein flex's were labeled 93 - 97 del sol, 92 - 95 civic, 94 - 01 integra Quote Link to comment Share on other sites More sharing options...
DelSolSweetie Posted August 29, 2009 Share Posted August 29, 2009 body part wise no not really if they did putting the front end on my car wouldnt have taken a new front support and welding of fenders Quote Link to comment Share on other sites More sharing options...
Xeryon Posted August 29, 2009 Share Posted August 29, 2009 (edited) Mechanical: a del sol S and del sol SI is like 95% identical to 92-95 civics of various varities. The exception to this is if you get a del sol VTEC. If that is the case then only the suspension, brakes and steering are the same. All of the motor and trans parts will be different. As for the body the sol is 100% different. there are certain parts that can be made to fit with a little modification though. Edited August 29, 2009 by Xeryon Quote Link to comment Share on other sites More sharing options...
DelSolSweetie Posted August 29, 2009 Share Posted August 29, 2009 the hood bolts up about it and it wont close without a civic latch and a civic front support hahah Quote Link to comment Share on other sites More sharing options...
93d3ls0l Posted September 10, 2009 Share Posted September 10, 2009 Mechanical: a del sol S and del sol SI is like 95% identical to 92-95 civics of various varities. The exception to this is if you get a del sol VTEC. If that is the case then only the suspension, brakes and steering are the same. All of the motor and trans parts will be different. As for the body the sol is 100% different. there are certain parts that can be made to fit with a little modification though. 93-95 del sol s (d15b7) is compatible with 92-95 civic dx/lx 93-95 del sol si (d16z6) is compatible with 92-95 civic ex as far as engine and trans................. Quote Link to comment Share on other sites More sharing options...
