wannaBstuntin Posted February 10, 2008 Author Share Posted February 10, 2008 Recommended for 40K miles: Rotate tires Replace engine oil filter Check front and rear brakes Check parking brake adjustment Inspect the tie rod ends, steering gear box, and boots Inspect the suspension components Inspect the driveshaft boots Inspect the brake hoses and lines (including ABS) Inspect all fluid levels and condition of fluids Inspect the exhaust system Inspect the fuel lines and connections Link to comment Share on other sites More sharing options...
Kegger Posted February 10, 2008 Share Posted February 10, 2008 Recommended for 40K miles: Rotate tires Replace engine oil filter Check front and rear brakes Check parking brake adjustment Inspect the tie rod ends, steering gear box, and boots Inspect the suspension components Inspect the driveshaft boots Inspect the brake hoses and lines (including ABS) Inspect all fluid levels and condition of fluids Inspect the exhaust system Inspect the fuel lines and connections Link to comment Share on other sites More sharing options...
Hatch92 Posted February 10, 2008 Share Posted February 10, 2008 ^ agreed Link to comment Share on other sites More sharing options...
Ben. Posted February 11, 2008 Share Posted February 11, 2008 lawl. i r haz stock mufflar. and, omfg. i'm loving the silence O_O Link to comment Share on other sites More sharing options...
wannaBstuntin Posted February 12, 2008 Author Share Posted February 12, 2008 I'm trying to order right now, but I'm not too confident that there are 4-2-1 DC headers for a D17A2. A couple sites have them listed but they look the same as the 4-1, so I'm not sure if they are using the wrong picture, or listing it wrong. Another site I've had success with only lists the 4-2-1 for the 96-00 civics. But then again, it only lists up to '03 in the first place so it may not be updated. Anybody have any ideas if there are 4-2-1 headers for a D17A2? I just don't want to order the wrong thing. Link to comment Share on other sites More sharing options...
museic07 Posted February 12, 2008 Share Posted February 12, 2008 stainless or ceramic? Link to comment Share on other sites More sharing options...
wannaBstuntin Posted February 12, 2008 Author Share Posted February 12, 2008 Preferably ceramic. Link to comment Share on other sites More sharing options...
museic07 Posted February 12, 2008 Share Posted February 12, 2008 http://www.autopartswarehouse.com/products...der+DC%20Sports first one Link to comment Share on other sites More sharing options...
VR17 Posted February 12, 2008 Share Posted February 12, 2008 nice ride.. not my style but its cool, i would slam it on some H+R springs, swap a dohc, and get some nicer wheels. btw what kind of alarm system did you install? Link to comment Share on other sites More sharing options...
lceah Posted February 13, 2008 Share Posted February 13, 2008 did you find the 4-2-1? a tune wont really do anything with just I/H/E would optimize fuel efficiency a bit... Link to comment Share on other sites More sharing options...
CleanGSR Posted February 13, 2008 Share Posted February 13, 2008 did you find the 4-2-1? would optimize fuel efficiency a bit... Not really....if anything it would hurt fuel economy. With I/H/E you'll be running a little lean if anything other than stoich. A tune would richen the mixture to be stoich and cause you to burn more fuel. Link to comment Share on other sites More sharing options...
wannaBstuntin Posted February 13, 2008 Author Share Posted February 13, 2008 Yea, wouldn't Honda stock ecu be tuned to be as fuel efficient as possible for DD? No worries though. I don't need a lot of power. Just reliability and regular maintenence and I'm good. That and some nice handling. I'm tempted to skip I/H/Cam and do the suspension first. I will end up doing both before the meet, but I hate the roll I have right now. Thoughts? btw, VR there's no alarm system, but has an immobilizer system. Why do you ask? And I was thinking of these in 16 or 17, but I can live with the "stockies" for a while. Link to comment Share on other sites More sharing options...
airjordan223 Posted February 13, 2008 Share Posted February 13, 2008 drop it like its hawt Link to comment Share on other sites More sharing options...
lceah Posted February 13, 2008 Share Posted February 13, 2008 Not really....if anything it would hurt fuel economy. With I/H/E you'll be running a little lean if anything other than stoich. A tune would richen the mixture to be stoich and cause you to burn more fuel. just adding the exhaust itself, you let the used air get out and not go back in as inert which doesn't do anything except for wasting your gas... you won't be burning more fuel if you are at stoich.! Stoich. itself means you use equal amounts! you burn as much fuel as air coming in (very closely...not perfectly of course...nothing is perfect lol) the stock set up actually doesn't give the best fuel efficiency...due to above reason... and those look nice...I clicked on "view on your vehicle" or whatever and it looks really nice on yours Link to comment Share on other sites More sharing options...
lceah Posted February 13, 2008 Share Posted February 13, 2008 Yea, wouldn't Honda stock ecu be tuned to be as fuel efficient as possible for DD?I don't need a lot of power. Just reliability and regular maintenence and I'm good. consider this: good suspension/dropping car (lowering center of gravity) will give better handling and can save you from incidents! I/H/cam nice but not adding so much power and you say you don't want power... stock ecu is...but once you add stuff like your exhaust that you already have, the ecu will try to adjust but won't be perfect... Link to comment Share on other sites More sharing options...
wannaBstuntin Posted February 13, 2008 Author Share Posted February 13, 2008 Ordered They're special order though so it's gonna be 2-3 weeks before they're shipped. Link to comment Share on other sites More sharing options...
Kegger Posted February 13, 2008 Share Posted February 13, 2008 Nice choice Ryan Link to comment Share on other sites More sharing options...
lceah Posted February 13, 2008 Share Posted February 13, 2008 great they better hurry...hehe Link to comment Share on other sites More sharing options...
wannaBstuntin Posted February 14, 2008 Author Share Posted February 14, 2008 Thanks guys....I'm so impatient. I want it all in now! :rant: Link to comment Share on other sites More sharing options...
Kegger Posted February 15, 2008 Share Posted February 15, 2008 Yeah, that's what she said. Link to comment Share on other sites More sharing options...
Hatch92 Posted February 15, 2008 Share Posted February 15, 2008 yea but he can't give all she wants.... i can Link to comment Share on other sites More sharing options...
lceah Posted February 17, 2008 Share Posted February 17, 2008 since you are going to get a clutch and change it, then why not add the flywheel too? just a thought... Link to comment Share on other sites More sharing options...
Hatch92 Posted February 18, 2008 Share Posted February 18, 2008 ^ agreed Link to comment Share on other sites More sharing options...
wannaBstuntin Posted February 29, 2008 Author Share Posted February 29, 2008 Got em. Camera is acting up, so heres crappy phone pics. Link to comment Share on other sites More sharing options...
Hatch92 Posted March 1, 2008 Share Posted March 1, 2008 nice man Link to comment Share on other sites More sharing options...
