Joe W Posted March 13, 2007 Share Posted March 13, 2007 Everybody paypal dan $1.00. Link to comment Share on other sites More sharing options...
Pyrorocketeer Posted March 13, 2007 Share Posted March 13, 2007 did you contact them about the TB yet? Get on the phone and start bitchin! Link to comment Share on other sites More sharing options...
mycarsux Posted March 13, 2007 Share Posted March 13, 2007 good luck tracking all those people down and good luck getting them to pay at least get the money from the movie Link to comment Share on other sites More sharing options...
compuvision02 Posted March 13, 2007 Share Posted March 13, 2007 Killswitch Engage Old album FTW Link to comment Share on other sites More sharing options...
90IntegraC1 Posted March 13, 2007 Author Share Posted March 13, 2007 the TB was shipped airmail today yeah...brian, sam, and eric owe me $27 ($9 each) for that movie 300, which was ridiculously good btw. Link to comment Share on other sites More sharing options...
compuvision02 Posted March 13, 2007 Share Posted March 13, 2007 Yeah, throttle body updates? Everybody paypal dan $1.00. I'll get him when he needs a drink at work, haha. Link to comment Share on other sites More sharing options...
90IntegraC1 Posted March 16, 2007 Author Share Posted March 16, 2007 Before: After: Before: After: Gaskets and Seals still need a head gasket, head bolts, and vtec solinoid gasket Just picked up some Si wheels....other 2 are in my frozen shut trunk Link to comment Share on other sites More sharing options...
TS John Posted March 16, 2007 Share Posted March 16, 2007 Sweet deal. Glad you finally got it back. What else do you need to get this show on the road? Link to comment Share on other sites More sharing options...
mycarsux Posted March 16, 2007 Share Posted March 16, 2007 finally!! looks pretty! you're gonna put on the Si wheels? Link to comment Share on other sites More sharing options...
90IntegraC1 Posted March 16, 2007 Author Share Posted March 16, 2007 j-k-tuning chipped P28 ecu + obd-1 conversion harness-$255 Mfactory Cam Gears-$150 timing belt kit-$150 head gasket-$66 (10% over cost from Honda) IACV-$100 Head Bolts-$8 each Spark Plugs-$15 Plug Wires-i dunno, $60? think that's it....getting there.... Link to comment Share on other sites More sharing options...
TS John Posted March 17, 2007 Share Posted March 17, 2007 That's a lot of money. How much power will you be putting down again? Link to comment Share on other sites More sharing options...
90IntegraC1 Posted March 17, 2007 Author Share Posted March 17, 2007 Harry- yeah, next week....see how they look.... John- uhh, looking for about 10 more than a gsr....got the port/polish/3-angle valve job, blox intake manifold, and a tune should be pretty nice....especially on a b17 trans w/ a 8 lb flywheel.... maybe 180 to the crank....the actual motor build won't be happening for a while b/c i have better things to spend money on. Link to comment Share on other sites More sharing options...
KingKoopa Posted March 18, 2007 Share Posted March 18, 2007 Like Women? Link to comment Share on other sites More sharing options...
compuvision02 Posted March 18, 2007 Share Posted March 18, 2007 Dan, the throttle body looks sick! SI wheels thanks to me. (and Jaime) Link to comment Share on other sites More sharing options...
90IntegraC1 Posted March 18, 2007 Author Share Posted March 18, 2007 I put the TB on today....runs better, but idle's at 3000 rpm's now....wtf. didn't do that before.... Cranny help me out!!!! King Koopa- exactly. Rob- Seriously, you and Jaime FTW. Link to comment Share on other sites More sharing options...
mycarsux Posted March 18, 2007 Share Posted March 18, 2007 Well Dan, remember you shortened your throttle cable...did you think of that? Link to comment Share on other sites More sharing options...
Pyrorocketeer Posted March 18, 2007 Share Posted March 18, 2007 he didn't shorten it, just moved the lever for the TB up on the cable, so it was always open. I'm sure he set it to normal when he got his new one back. Link to comment Share on other sites More sharing options...
90IntegraC1 Posted March 18, 2007 Author Share Posted March 18, 2007 yeah i already set it to factory settings.....you think the ECU just needs to re-learn this TB? orrr....there's a check valve on the TB, if that's installed backwards could that be the problem? Link to comment Share on other sites More sharing options...
mycarsux Posted March 18, 2007 Share Posted March 18, 2007 Reset the ECU...? Link to comment Share on other sites More sharing options...
cranny Posted March 18, 2007 Share Posted March 18, 2007 you sure everything is hooked up correctly dan? if it is and its acting like a weiner , you may have to adjust the idle , haha. i know mycar , ive said never touch the idle screw , but for certain things , it must be changed. that TB is letting more air through now so. take your itake off dan , and look at the butterfly valve when its closed all the way , is it shut all the way? if the throttle body is closing all the way , than just adjust your idle dude using idle screw. your car should idle at 750-800. the throttle body is altered , therefore its settings must be also , to put it simply. Link to comment Share on other sites More sharing options...
compuvision02 Posted March 19, 2007 Share Posted March 19, 2007 j-k-tuning chipped P28 ecu + obd-1 conversion harness-$255Mfactory Cam Gears-$150 timing belt kit-$150 head gasket-$66 (10% over cost from Honda) IACV-$100 Head Bolts-$8 each Spark Plugs-$15 Plug Wires-i dunno, $60? think that's it....getting there.... I'd just get a street tune, atleast, just so your car is running good for what modifications you are running. He will most likely just chip you and hook you up with a base map for something similar for that price. I believe an extra $100 gets you a street tune and $200-250 for a dyno tune. I'm actually going to go Evans-Tuning for my turbo build, but I trusted him with my all motor build. If you've ever seen Whiplash videos, he is the Civic hatch that is always in it, so obviously he tunes it well enough to get the freaking piss beat out of it for stupid things without it dying, should be able to make it reliable to go down the track and daily drive. He has a LS turbo EK hatch which he dailys and a turbo B16 (I think) EG that is his race car. Link to comment Share on other sites More sharing options...
compuvision02 Posted March 19, 2007 Share Posted March 19, 2007 P.S. Don't forget to find a replacement bolt for the Rudy's throttle body, haha. Link to comment Share on other sites More sharing options...
90IntegraC1 Posted March 19, 2007 Author Share Posted March 19, 2007 ha well i'm getting the dyno tune right afterwards just to be safe. the P28 comes chipped w/ crome, so i'm gonna use that program. That bolt should be under his CRX, we just couldn't get to it b/c of the snowww Link to comment Share on other sites More sharing options...
mycarsux Posted March 19, 2007 Share Posted March 19, 2007 ugh, snow FTL so dan what do you need now? Link to comment Share on other sites More sharing options...
90IntegraC1 Posted March 19, 2007 Author Share Posted March 19, 2007 well next up is either the mfactory cam gears or j-k-tuning package depending on my money situation.... i had to cut my hours at work b/c my grades were slipping.....sooo now i have no money. Link to comment Share on other sites More sharing options...
