leber008 Posted October 22, 2006 Share Posted October 22, 2006 im new to this stuff and i need help. I have a 96 integra SE and im about to build it. Im not lookin to spend too much money. I want to get it to about 225-250hp and i want to know the best way to do this. My dad wants to me to get vtech heads for it, whats the advantage and whats the cost of this? Link to comment Share on other sites More sharing options...
Chubs Posted October 22, 2006 Share Posted October 22, 2006 Maybe your dad ment a VTEC head, a VTEC head would run you around 300-500 depending on if you want the B16, B18c1 etc.. but even with a VTEC head that isn't going to get you anywhere close to 250WHP, If you are really a broke weiner and dont want to spend any money I would say a cheap way for power is nitrous but I HIGHLY recommend NOT getting that. You should learn a little more about motors etc.. first before you want to do anything too serious. If you stick around here for a while you will learn. Link to comment Share on other sites More sharing options...
leber008 Posted October 22, 2006 Author Share Posted October 22, 2006 Maybe your dad ment a VTEC head, a VTEC head would run you around 300-500 depending on if you want the B16, B18c1 etc.. but even with a VTEC head that isn't going to get you anywhere close to 250WHP, If you are really a broke weiner and dont want to spend any money I would say a cheap way for power is nitrous but I HIGHLY recommend NOT getting that. You should learn a little more about motors etc.. first before you want to do anything too serious. If you stick around here for a while you will learn. i know the vtech alone wont get me 250hp but how much would it increase? Link to comment Share on other sites More sharing options...
Chubs Posted October 22, 2006 Share Posted October 22, 2006 God damnit it is spelled VTEC, there is a meaning to VTEC, variable valve timing and lift electronic control. Link to comment Share on other sites More sharing options...
TLontheDL Posted October 22, 2006 Share Posted October 22, 2006 vtech is just a device thats already built into a honda (your car has a honda motor) motor. it kicks in at a certain rpm/speed. VTECH Link to comment Share on other sites More sharing options...
leber008 Posted October 22, 2006 Author Share Posted October 22, 2006 whats the hp increase i should see with the vtec. Link to comment Share on other sites More sharing options...
90IntegraC1 Posted October 22, 2006 Share Posted October 22, 2006 1. VTEC 2. Putting a vtec head on a LS block will not put you anywhere near 235 whp, and will cost you well over $1500 for parts, not including labor. I just bought a B18C1 (GSR) head, ported, polished, 3-way valve job for $500. I still have to buy many parts including a GSR Water Pump, Timing Belt, Oil Pump, Valve Cover Gasket, Cam Shafts, Cam gears, Head Gasket, etc...then I have to take it to my friend when i get all the necessary parts for lsvtec, then an oil line has to be placed in the head, dowels plugged etc...so if you really want 235 whp do this: JDM H22A Golden Eagle Sleeved (CIICK ME) Motor Mounts Axle's ECU Wiring Harnesses Turbo Kit + many many more parts.... Basically, if you want 235 whp, you're gonna have to spend over $5000 edit: whats the hp increase i should see with the vtec about 35-45 whp on stock blocks/heads Link to comment Share on other sites More sharing options...
VR17 Posted October 25, 2006 Share Posted October 25, 2006 ....forget about vtech.. if someone spells VTECH incorrectly, dont worry about it geezz.. Link to comment Share on other sites More sharing options...
Nancy Posted October 25, 2006 Share Posted October 25, 2006 God damnit it is spelled VTEC. youre funny, wish i couldve seen your expression when you were typing that. Link to comment Share on other sites More sharing options...
TS John Posted October 25, 2006 Share Posted October 25, 2006 I keep seeing chubs in your avatar and thinking it's him posting for some reason. I was like, "Why was he just talking to himself?" Good thing it says your name in your sig or I'd be totally confused all the time. Link to comment Share on other sites More sharing options...
SIR_VTEC Posted October 27, 2006 Share Posted October 27, 2006 Your best bet is supercharging with comptech or any aftermarket turbo charger Link to comment Share on other sites More sharing options...
cranny Posted October 30, 2006 Share Posted October 30, 2006 if your only looking for 220 , than do a LSVTEC(vtec head on your engine) , get a set of cams springs/retainers , throw 11.5:1 CR pistons in it with lightweight rods. chip your ecu and get it tuned , youl have 220 . Link to comment Share on other sites More sharing options...
