Exclusive Honda Girl Posted May 1, 2006 Share Posted May 1, 2006 I took the car in due to the maitenance issue and they said the timing belt is a must...is this so?? What can I do to turn the light off?? Link to comment Share on other sites More sharing options...
00' Ex Posted May 2, 2006 Share Posted May 2, 2006 Disconnect your negative terminal of your battery for about 5 mins and then reconnect it. Link to comment Share on other sites More sharing options...
sohcVTEC-E Posted May 2, 2006 Share Posted May 2, 2006 Bad idea. You need to get the timing belt replaced. You are five thousand miles overdue. Link to comment Share on other sites More sharing options...
00' Ex Posted May 2, 2006 Share Posted May 2, 2006 First do that and if the light comes back on then change the timing belt. Link to comment Share on other sites More sharing options...
Exclusive Honda Girl Posted May 2, 2006 Author Share Posted May 2, 2006 First do that and if the light comes back on then change the timing belt. When should it be replaced?? I'm at 110 Kilometers (Canadian) lol Link to comment Share on other sites More sharing options...
sohcVTEC-E Posted May 2, 2006 Share Posted May 2, 2006 My bad! Didn't notice that. Do what 00' EX said. If it comes back on you should change the timing belt. Link to comment Share on other sites More sharing options...
Chubs Posted May 2, 2006 Share Posted May 2, 2006 Is it your check engine light that keeps comming on ? If so that really doesn't have much to do with the timing belt, your check engine light has to do with Emissions control, if it keeps comming on it might be an old oxygen sensor or you might have the same problem I did. My gas cap wouldn't screw on all the way and it says if it doesn't screw all the way down the check engine light comes on, so I just bought a new gas cap. Link to comment Share on other sites More sharing options...
Exclusive Honda Girl Posted May 2, 2006 Author Share Posted May 2, 2006 Is it your check engine light that keeps comming on ? If so that really doesn't have much to do with the timing belt, your check engine light has to do with Emissions control, if it keeps comming on it might be an old oxygen sensor or you might have the same problem I did. My gas cap wouldn't screw on all the way and it says if it doesn't screw all the way down the check engine light comes on, so I just bought a new gas cap. Nope...it's the "maitenance required" light Link to comment Share on other sites More sharing options...
Benji Posted May 2, 2006 Share Posted May 2, 2006 don't you just hold the trip reset button in for a few secs with the key in the run posistion(engine off) or something to reset that thing... i always have to look it up Link to comment Share on other sites More sharing options...
Nancy Posted May 2, 2006 Share Posted May 2, 2006 don't you just hold the trip reset button in for a few secs with the key in the run posistion(engine off) or something to reset that thing... i always have to look it up yes, the reset button under the dash. mine comes on every 3000 miles. just lets you know its time to change your oil soon. Link to comment Share on other sites More sharing options...
CleanGSR Posted May 2, 2006 Share Posted May 2, 2006 Yeah, I just reset mine a few weeks ago. Each car is different though, but with tegs, there's a button under the dash. Link to comment Share on other sites More sharing options...
babykansas04 Posted May 2, 2006 Share Posted May 2, 2006 when mine came on (99 civic ex) theres a little key slot on the cluster and you stick ur key in there...and the color would change from red to green..... have u looked in ur manual Link to comment Share on other sites More sharing options...
SolLesHonda Posted May 2, 2006 Share Posted May 2, 2006 The del sol doesn't even have one of those lights I think :( Link to comment Share on other sites More sharing options...
