..SSR.. Posted September 16, 2005 Share Posted September 16, 2005 This is the thread that any info about my car will go into from now on. Things to do: Pull ZC trans apart, grind 4th gear to fit Put ZC 2-3-4-5 into my trans Buy EX front LCA's and install them with CTR front swaybar while putting the trans back in. Put ITR rear sway bar on along with A-Spec-Racing subframe brace that I just received (ASR brace, ITR swaybar, and ZC trans all got here this week). Compare 1/4 mile times before and after trans swap (I'll take weight out somewhere to account for the added weight of the sway bars). See how much better I do at the next autocross. Info on my car: 1996 Honda Civic DX hatchback Outside: Berlina Black Shady Valley sticker ITR Expo 220 sticker Quiksilver sticker Inside: 1990 Integra RS shiftknob working cupholder OEM radio block-off plate Si CD player relocated to cupholder DIN EX center console CTR cluster Engine: removed intake resonator since I was too lazy to put it back on after trans work Miller beer wrist band on brake res. removed exhaust piping, hung muffler with coat hanger Drivetrain: Action Clutch 1MD (6-puck sprung) Fidanza 7lb. flywheel OEM ISB Advanced axles Brakes: CTR front/rear brakes w/ OEM CTR pads Suspension: CTR front/rear shocks/springs Spinners: CR-V 5-spoke steelies, 195(maybe 205)/60/15 Falken Ziex (street) Rota Slipstreams 15x6.5 satin black, 205/50/15 Falken Azenis, Daiyama lugnuts (race) To install: CTR front swaybar EX front LCA's ASR rear subframe brace ITR rear swaybar ITR brake MC/Booster/Res. Z6 intake manifold ZC 2-3-4-5 gears Next up to order: Quaife LSD Z6 countershaft (have ring gear) to complete FD Sparco Speed seats fab 4-point roll bar (Autopower is designed for coupes so it doesn't fit tight) harnesses (still researching, will NOT be used on street) SFI padding seat brackets new Bell helmet Debating on how I want to build my engine. Going to start a group buy for the SRR 4.9 FD since it is discontinued and I want it that bad. Link to comment Share on other sites More sharing options...
XScarAudio Posted September 16, 2005 Share Posted September 16, 2005 good plans there man! Link to comment Share on other sites More sharing options...
..SSR.. Posted October 28, 2005 Author Share Posted October 28, 2005 Update time. Bought a new in box SRR 4.7 final drive on ebay for $165 shipped. Going to rebuild my trans (bearings, seals, synchro's) when I put in my ZC gears. Not going to put in the final drive until I get the Quaife. I want to feel the difference from the gear sway first. Going to go with Sparco EVO seats versus the Speeds I think. Probably going to use a D15B7 4th gear for 3rd gear if I can get a B7 trans for free from someone. (1.066 versus 1.033 ZC) Doing some testing for Omnipower. Clutch master cylinder and prototype aluminum front lower control arms. Putting that stuff on this weekend. Going to start getting stuff for my first build in a week or two. 12.7:1 CR with FLAT TOP pistons. Should be able to run 87 for daily driving, 93 when I want to get on it. This will be an all OEM bottom end build and I'm hoping to make 150whp non-VTEC. Did half an HPDE (story later) at Summit Point in West Virginia, and rolled a Cobra (killed me on the straights, but I stuck to his ass in the turns so he had to let me by). ..SSR.. out bizatches. P.S. My website is getting close to being done. Link to comment Share on other sites More sharing options...
babyboy200417 Posted October 28, 2005 Share Posted October 28, 2005 I like your plans that your are doing to your car keep up the good work Link to comment Share on other sites More sharing options...
Humphries Posted October 28, 2005 Share Posted October 28, 2005 finally.. i havent seen you posting as much as usual. good stuff keep it up and post pics of your car later on.. i havent ever seen it. Link to comment Share on other sites More sharing options...
VR17 Posted October 28, 2005 Share Posted October 28, 2005 oh nice, how much did you pay for the OEM radio block-off plate? i need one Link to comment Share on other sites More sharing options...
..SSR.. Posted October 29, 2005 Author Share Posted October 29, 2005 Twenty some dollars. Link to comment Share on other sites More sharing options...
..SSR.. Posted February 22, 2006 Author Share Posted February 22, 2006 Bought a Y8 exhaust manifold today for $30 off a friend of mine. Swapped it out and drove it. Idle is a bit lumpier sounding. Deeper and louder sound. Annoying as hell at 50% throttle around 2-3k. Quiet when crusing. Sounds like a LS swap at WOT. Kicked an Impala's ass on the way home from work. Ordered some wheels a couple of weeks ago, they should be here in a couple of months. Link to comment Share on other sites More sharing options...
Humphries Posted February 22, 2006 Share Posted February 22, 2006 good buy.. months for a set of wheels? are they in mars right now? Link to comment Share on other sites More sharing options...
90IntegraC1 Posted February 22, 2006 Share Posted February 22, 2006 yoo ssr is there anywhere that you've posted pics of your car?? i don't feel like looking through your 6,871 posts to find a pic...thanks Link to comment Share on other sites More sharing options...
Humphries Posted February 22, 2006 Share Posted February 22, 2006 theres some in the honda image and video forum thing. its was from a while ago. look around in there. Link to comment Share on other sites More sharing options...
90IntegraC1 Posted February 22, 2006 Share Posted February 22, 2006 thanks i found it i liked the pic w/ the C5 in the back seat...funny funny Link to comment Share on other sites More sharing options...
sohcVTEC-E Posted February 23, 2006 Share Posted February 23, 2006 nice ride! do you sell cams ssr? Link to comment Share on other sites More sharing options...
..SSR.. Posted February 24, 2006 Author Share Posted February 24, 2006 Rocket Motorsports cams Link to comment Share on other sites More sharing options...
Blackoutt Posted March 8, 2006 Share Posted March 8, 2006 Great setup SSR. Link to comment Share on other sites More sharing options...
sohcVTEC-E Posted March 9, 2006 Share Posted March 9, 2006 Drivetrain:Action Clutch 1MD (6-puck sprung) *unsprung Link to comment Share on other sites More sharing options...
..SSR.. Posted March 9, 2006 Author Share Posted March 9, 2006 Correct. Link to comment Share on other sites More sharing options...
..SSR.. Posted March 9, 2006 Author Share Posted March 9, 2006 Need to order Si endlinks so I can install rear sway. Not going to run a front sway as of right now. Need to send ZC 4th off to be ground, then install it and replace 2/3 synchro's. Have some dents and scratches to be repaired. Backed into my friend trashcan and dented my hatch, so I preordered a Composites Fab carbon hatch. Will need to order a FAL rear window for it. Going to bust out my sound deadening whenever I get around to ordering and installing a Hawker Odyssey battery. Removing A/C at the same time. Probably going to order a Delta 272 regrind and mill the head while I do my build. Wheels are halfway paid off, so once they're done, I'm ordering some Koni Yellows and 205/50/15 Ziex for the Slips. Link to comment Share on other sites More sharing options...
..SSR.. Posted April 16, 2006 Author Share Posted April 16, 2006 Still need to send 4th gear off. Once I get it back I will put it in along with EX 1 and 2 gears and the CRX Si 5th. Ordered an SMSP header. Plans for engine build are almost finalized Going to order Function7 endlinks versus OEM. $40 vs. $100. Link to comment Share on other sites More sharing options...
Whitebballguy89 Posted April 17, 2006 Share Posted April 17, 2006 Yeah 1996 DX's represent You have the Y8 Heads or the non vtec like mine? Link to comment Share on other sites More sharing options...
SolLesHonda Posted April 17, 2006 Share Posted April 17, 2006 Uh oh, SMSP header ... how much did that bitch run you ? Link to comment Share on other sites More sharing options...
..SSR.. Posted April 17, 2006 Author Share Posted April 17, 2006 I have the Y7 head. $730 for the header. Link to comment Share on other sites More sharing options...
SolLesHonda Posted April 17, 2006 Share Posted April 17, 2006 Is that your price .. or an average price ? Link to comment Share on other sites More sharing options...
..SSR.. Posted April 17, 2006 Author Share Posted April 17, 2006 I pay retail just like anybody else does. There are no dealers for SMSP. Link to comment Share on other sites More sharing options...
SolLesHonda Posted April 17, 2006 Share Posted April 17, 2006 Is there a place that sells them online ? Link to comment Share on other sites More sharing options...
