Drop Shock Posted January 3, 2011 Share Posted January 3, 2011 alright so today i went to my car and turned it on. i than tried to roll down my driver side window and it wouldnt work. so i figured maybe it was stuck so i pushed down a little on it and it eventually rolled down by it self. I than drove to work and 9 hours later i went out to my car and tried to roll down my window again and to my suprise it wouldnt go down. So i tried nudging it a little and it still wouldnt go down. I tried the other windows and not one of them would budge. not even the back window. any ideas? I was thinking it might be the fuses but i doubt all 3 of the fuses were blown at the same time. please help Link to comment Share on other sites More sharing options...
Tubbith Posted January 3, 2011 Share Posted January 3, 2011 alright so today i went to my car and turned it on. i than tried to roll down my driver side window and it wouldnt work. so i figured maybe it was stuck so i pushed down a little on it and it eventually rolled down by it self. I than drove to work and 9 hours later i went out to my car and tried to roll down my window again and to my suprise it wouldnt go down. So i tried nudging it a little and it still wouldnt go down. I tried the other windows and not one of them would budge. not even the back window. any ideas? I was thinking it might be the fuses but i doubt all 3 of the fuses were blown at the same time. please help than Link to comment Share on other sites More sharing options...
MChester Posted January 3, 2011 Share Posted January 3, 2011 alright so today i went to my car and turned it on. i than tried to roll down my driver side window and it wouldnt work. so i figured maybe it was stuck so i pushed down a little on it and it eventually rolled down by it self. I than drove to work and 9 hours later i went out to my car and tried to roll down my window again and to my suprise it wouldnt go down. So i tried nudging it a little and it still wouldnt go down. I tried the other windows and not one of them would budge. not even the back window. any ideas? I was thinking it might be the fuses but i doubt all 3 of the fuses were blown at the same time. please help Check your wire harness connection to the power window control module. If that's OK, then see if you can find one from a friend or your dealer that they'll let you swap in place of yours to verify functionality. Unfortunately, the damn things aren't cheap either. Finding one used may be possible. Good luck. http://www.hondapart...ionGroupID=7130 Link to comment Share on other sites More sharing options...
Raley Posted January 3, 2011 Share Posted January 3, 2011 did you make sure that lil safty switch is off.... i'll have to rummage around but i wouldn't be suprided if i have that switch panel just floating around... you'll have to wait a while, im in the process of moving and you know how that crap goes. Link to comment Share on other sites More sharing options...
Drop Shock Posted January 3, 2011 Author Share Posted January 3, 2011 lol thanks guys. yes i've tried the "main" switch about a hundred time. and I'll get back to you when I check to see if its the harness Link to comment Share on other sites More sharing options...
DelSolSweetie Posted January 4, 2011 Share Posted January 4, 2011 I was going to ask if you hit the switch too.. i somehow hit it all the time and then go WTF when it doesnt roll down Link to comment Share on other sites More sharing options...
lastresort576 Posted January 4, 2011 Share Posted January 4, 2011 I was going to ask if you hit the switch too.. i somehow hit it all the time and then go WTF when it doesnt roll down Same thing has happened to me. It's almost nerve racking when you do that lol. Link to comment Share on other sites More sharing options...
hiemsnox Posted January 10, 2011 Share Posted January 10, 2011 try the switch on the other side and see if that one at least works for the passenger window. that should give u a good idea where your problem is Link to comment Share on other sites More sharing options...
