lastresort576 Posted December 2, 2010 Share Posted December 2, 2010 Hey whats up guys? I'm in the process right now installing my ES end links and I'm curious as to far people that have experience with installing them have tightened them up? In theory I think the more I tighten/loosen each side while keeping each side tightened up the same, the tension on the front sway bar should be more or less correct? Also is there some way I can make sure each side has the same tension other than measuring the amount of bolt poking out of the top nut? I can't think of any other way... Link to comment Share on other sites More sharing options...
Raley Posted December 2, 2010 Share Posted December 2, 2010 torque wrench... but you want them both snug... not to tight, not to loose... Link to comment Share on other sites More sharing options...
Velocifero Posted December 16, 2010 Share Posted December 16, 2010 There be like 4-5 threads showing or something. Link to comment Share on other sites More sharing options...
cmgogo Posted December 16, 2010 Share Posted December 16, 2010 german torque "gudntight" Link to comment Share on other sites More sharing options...
lastresort576 Posted December 17, 2010 Author Share Posted December 17, 2010 yeah I just ended up tightening both sides until it wouldn't tighten or allow the bushings to spin anymore. There's just a lot of bolt sticking out the top. Link to comment Share on other sites More sharing options...
