kyle 09 Posted November 12, 2010 Share Posted November 12, 2010 easy big guy, only need to make one of these i have a 1994 honda civic ex and wile i was driving the car engine , which is a d16z6, just shut off. i was in second gear and i pushed on the gas and the car would not accelerate. all of my dash lights came on as if i was about to turn it on. i pulled over to the side of the road, tried to start it and it would not start the starter sounded just fine. wile my friend was towing me to my house i put it into second gear to see if i could push stat it but it did nothing just rolled. i have no clue whats wrong plz help!!!! Quote Link to comment Share on other sites More sharing options...
Xeryon Posted November 12, 2010 Share Posted November 12, 2010 most likely: snapped the timing belt. Oh, and one post please. Quote Link to comment Share on other sites More sharing options...
cmgogo Posted November 12, 2010 Share Posted November 12, 2010 (edited) so many possibilities Test for fuel, and spark, as well as the condition of your t-belt, let us know what you get. Also any odd noises, smells, ecu codes, oil in coolant, coolant in oil, fouled plugs, etc etc etc. Basicly your asking us a question that has 50+ correct awnsers, you need to narrow down the possibilities. Edited November 12, 2010 by cmgogo Quote Link to comment Share on other sites More sharing options...
kyle 09 Posted November 12, 2010 Author Share Posted November 12, 2010 thx guys im looking at it 2day and will keep you posted Quote Link to comment Share on other sites More sharing options...
kyle 09 Posted November 15, 2010 Author Share Posted November 15, 2010 well i took my car apart and the timing belt is good the gas pump is good. then i thought that it might be my main relay so i replaced that and that was not it!!! so i took apart my distributer and i need to take the coil in to get that tested and if thats the problem than i will just replace the hole thing. Quote Link to comment Share on other sites More sharing options...
93d3ls0l Posted January 12, 2011 Share Posted January 12, 2011 <br />well i took my car apart and the timing belt is good the gas pump is good. then i thought that it might be my main relay so i replaced that and that was not it!!! so i took apart my distributer and i need to take the coil in to get that tested and if thats the problem than i will just replace the hole thing.<br /><br /><br /><br /> make sure when you check your timing belt that you look at the whole thing because ive seen times where the timing belt strips the teeth off the part on the crank and will look good on the top but not actually spin when cranking it over. hope you figure out your problem Quote Link to comment Share on other sites More sharing options...
SpeedDemon Posted January 13, 2011 Share Posted January 13, 2011 why is this in the wrong section? Quote Link to comment Share on other sites More sharing options...
