SpeedDemon Posted September 30, 2010 Share Posted September 30, 2010 ok so i tried to get some work done today on the rims i just got, well it didnt work out too good. i used a polish wheel on it with polishing compound and it took the clear coat, silver coat, and whatever else was on there completely off before i could react. it went all the way down to being blueish color. so with that said ill have to paint the rims. so my question is...what can i use to strip the rest of the clearcoat and silver coat off so i can get these ready for paint. since they look like ass im just going to spray paint with LOTS of clear coat. ive heard of aircraft stripper, but idk, then there is sanding....that might be what ill do. what is everyones ideas? Quote Link to comment Share on other sites More sharing options...
SolMusic Posted September 30, 2010 Share Posted September 30, 2010 erm, paint stripper? nitromorse, if u have it over there. or at least put in some effort n polish/sand them down properly so you get a decent finish. Quote Link to comment Share on other sites More sharing options...
cmgogo Posted September 30, 2010 Share Posted September 30, 2010 aircraft stripper/ sand blast/ plastic media blast/ hand sand, so many possibilities, although id be partial to the aircraft stripper and plastic media blasting then go get em powdercoated. Quote Link to comment Share on other sites More sharing options...
SolMusic Posted September 30, 2010 Share Posted September 30, 2010 show them ya man titties, you'll scare the paint straight off Quote Link to comment Share on other sites More sharing options...
airjordan223 Posted September 30, 2010 Share Posted September 30, 2010 ^bahahahaha aircraft strippers are they best. you saw them in iron man Quote Link to comment Share on other sites More sharing options...
SpeedDemon Posted September 30, 2010 Author Share Posted September 30, 2010 show them ya man titties, you'll scare the paint straight off ..i do fit in a B.... ^bahahahaha aircraft strippers are they best. you saw them in iron man i did? well im sitting here sanding them my hand right now. ill get some stripper when i get some funds.....paint stripper that is Quote Link to comment Share on other sites More sharing options...
SpeedDemon Posted September 30, 2010 Author Share Posted September 30, 2010 here is what the polishing did. its just right there on the spoke. i didnt even notice until i stopped and turned the wheel.... And im so poor i tear tires off with a dremel to avoid the tire removal fee Quote Link to comment Share on other sites More sharing options...
OTiS Posted September 30, 2010 Share Posted September 30, 2010 what are all the words on the back of the rim? and id probably do the same things with getting tires off lmao Quote Link to comment Share on other sites More sharing options...
SpeedDemon Posted September 30, 2010 Author Share Posted September 30, 2010 the words range from "MAX WHEEL LOAD 1400LBS" "MAX MOUNTING INFLATION 60PSI" "30MM OFFSET" "14 X 6 J" "DOT-T" "IBR TYPE 42" "MADE IN BRAZIL" and then on two seperate spokes it looks like it is blank, but they are stamped "24" and "27" i still dont really know what kind of rim this is. but i need to know so i can order center caps lol Quote Link to comment Share on other sites More sharing options...
airjordan223 Posted September 30, 2010 Share Posted September 30, 2010 Is that "polish" just a reflection or did you really wear down that much of the wheel? Quote Link to comment Share on other sites More sharing options...
SpeedDemon Posted September 30, 2010 Author Share Posted September 30, 2010 (edited) no it really wore down that much. i went over it once and boom thats what showed. i was like "OH YOU MOTHER FUUUCKER!!!!!!!!!" edit: if you are talking about the big dip and worn spot on the edge it was like that when i bought it. looked like someone took a file to it, i just didnt see it until i got home and cleaned the massive amount of brake dust and grime off of them i am referring to the blue spots on the inner part of the spoke. Edited September 30, 2010 by SpeedDemon Quote Link to comment Share on other sites More sharing options...
airjordan223 Posted September 30, 2010 Share Posted September 30, 2010 Yeah that huge white/reflective line by the blue spots, is that worn down? Quote Link to comment Share on other sites More sharing options...
SpeedDemon Posted September 30, 2010 Author Share Posted September 30, 2010 yes. its not as bad as it looks. i took some 1000 grit sand paper to it to sand it down. it did have burs on it...i hope these rims are still good. im having them checked tomorrow if possible Quote Link to comment Share on other sites More sharing options...
airjordan223 Posted September 30, 2010 Share Posted September 30, 2010 Yeah they might be out of balance. If you need to do some cosmetic repair to them, this is a pretty good guide: http://www.audiworld.com/tech/ext43.shtml Quote Link to comment Share on other sites More sharing options...
mpearce1974 Posted September 30, 2010 Share Posted September 30, 2010 Should of emailed me dumbasss! Quote Link to comment Share on other sites More sharing options...
airjordan223 Posted September 30, 2010 Share Posted September 30, 2010 zomg youre alive? Quote Link to comment Share on other sites More sharing options...
SpeedDemon Posted September 30, 2010 Author Share Posted September 30, 2010 yeah i tried to take better pics...but got poor camera quality here are the blue spots i was taking about. it wore it down that fast...i take it the blue is bare aluminum? Quote Link to comment Share on other sites More sharing options...
SpeedDemon Posted September 30, 2010 Author Share Posted September 30, 2010 Yeah they might be out of balance. If you need to do some cosmetic repair to them, this is a pretty good guide: http://www.audiworld...ech/ext43.shtml its ok if they are out of balance. i am going to have tires mounted on them and have them balanced. i just skimmed through, but it looks like it would do pretty good. ill have to read more into it Should of emailed me dumbasss! i would if you were every online!!! zomg youre alive? no kidding where did he come from?! Quote Link to comment Share on other sites More sharing options...
mpearce1974 Posted September 30, 2010 Share Posted September 30, 2010 its ok if they are out of balance. i am going to have tires mounted on them and have them balanced. i just skimmed through, but it looks like it would do pretty good. ill have to read more into it i would if you were every online!!! no kidding where did he come from?! Your moms Vag. I would be on more if I was entertained! AMUSE ME peasant!!! Quote Link to comment Share on other sites More sharing options...
airjordan223 Posted September 30, 2010 Share Posted September 30, 2010 wait if youre from my moms vag, that would make us.....BROTHERS! BROTHERS DONT SHAKE HANDS BROTHERS GOTTA HUG! Quote Link to comment Share on other sites More sharing options...
SpeedDemon Posted September 30, 2010 Author Share Posted September 30, 2010 Your moms Vag. I would be on more if I was entertained! AMUSE ME peasant!!! ...jklakljLKJSAD';IFGSRU C8VRUUYVTN8ERNP9W8ERGPIUHCVLZUHCLKSJGHFDJD!!!!!1 :MIDDLEFINGER:!!!!!!!!!!!!!!!!!!!!!!!!1 wait if youre from my moms vag, that would make us.....BROTHERS! BROTHERS DONT SHAKE HANDS BROTHERS GOTTA HUG! hahahaha god you guys are homos Quote Link to comment Share on other sites More sharing options...
airjordan223 Posted September 30, 2010 Share Posted September 30, 2010 we're not homos we're brothers didnt you get the vag memo? mpearce1974 1 Quote Link to comment Share on other sites More sharing options...
mpearce1974 Posted September 30, 2010 Share Posted September 30, 2010 ...jklakljLKJSAD';IFGSRU C8VRUUYVTN8ERNP9W8ERGPIUHCVLZUHCLKSJGHFDJD!!1 :MIDDLEFINGER:!!!!!!1 hahahaha god you guys are homos You are the one with his head in his ass!!! Quote Link to comment Share on other sites More sharing options...
SpeedDemon Posted September 30, 2010 Author Share Posted September 30, 2010 we're not homos we're brothers didnt you get the vag memo? yeah i did get the memo. so you must be pretty sore...must of been hell with mike climbing out of you like that You are the one with his head in his ass!!! i..wow haha ok so the blue that i was seeing looks to be primer. when i sand it down some more...bare aluminum. Quote Link to comment Share on other sites More sharing options...
mpearce1974 Posted September 30, 2010 Share Posted September 30, 2010 yeah i did get the memo. so you must be pretty sore...must of been hell with mike climbing out of you like that i..wow haha ok so the blue that i was seeing looks to be primer. when i sand it down some more...bare aluminum. Go to walmart get this crap and a brush!! Quote Link to comment Share on other sites More sharing options...
