SpeedDemon Posted May 27, 2009 Share Posted May 27, 2009 (edited) ok guys and gals, it has begun. i am going to turbo the d16z6. heres a base D16z6-160,000 miles Si Tranny-160,000 miles -does not burn oil,does not smoke GOAL: ~200 WHP(180 would do fine) going to be a DD so not looking to go all out. List of parts: Stage 2 Clutch(should i go stage 3?) http://www.buyimportperformance.com/product_p/8022-2100.htm -is there any stage 2 clutches that dont require a break in period? ARP Head Studs 2.5" exhaust--- http://www.buyimportperformance.com/produc...c%20catback.htm new tires-suggestions? have not decided on the full kit yet, still looking around for prices. so far the cheapest ive found is $1895 http://www.buyimportperformance.com/produc...rks-strtkit.htm Turbo Timer http://www.buyimportperformance.com/product_p/3530003.htm im going later next week to have a compression test done. any suggestions or comments are welcome Edited May 28, 2009 by SpeedDemon Quote Link to comment Share on other sites More sharing options...
alex37211 Posted May 27, 2009 Share Posted May 27, 2009 (edited) I suggest buying a compression tester. I bought one new for like $12. It was a cheap harbor freight one, but it works. Also, I don't think you will need the head studs. If you take the studs off, you may need to replace the head gasket. That seems like a lot of unnecessary work. The kit looks good. Edited May 27, 2009 by alex37211 Quote Link to comment Share on other sites More sharing options...
Kastigir Posted May 27, 2009 Share Posted May 27, 2009 I suggest buying a compression tester. I bought one new for like $12. It was a cheap harbor freight one, but it works. Also, I don't think you will need the head studs. If you take the studs off, you may need to replace the head gasket. That seems like a lot of unnecessary work. The kit looks good. Headstuds are a good upgrade. You can, in fact, change the headbolts out and install the headstuds without removing the head. Quote Link to comment Share on other sites More sharing options...
SpeedDemon Posted May 27, 2009 Author Share Posted May 27, 2009 Headstuds are a good upgrade. You can, in fact, change the headbolts out and install the headstuds without removing the head. yep, but im gonna go ahead and get the apr. the car is almost due for a new gasket anyways. first thing to come is a new exhaust. does anyone know where i can find one for cheap? probably 2.5". might go with a 3". Quote Link to comment Share on other sites More sharing options...
alex37211 Posted May 27, 2009 Share Posted May 27, 2009 muffler shop, custom made. And pre-made "catback" is gonna cost more usually Quote Link to comment Share on other sites More sharing options...
jerrodh Posted May 27, 2009 Share Posted May 27, 2009 Yeah if your looking for cheap find a local shop to fab you up one. On a 'stock' z6 2.5" would be more than enough. Might also wanna try CL for a cheap catback. I've sceen plunty of fair/good shape Greedy catbacks from various cars go for as low as $100. Quote Link to comment Share on other sites More sharing options...
SpeedDemon Posted May 27, 2009 Author Share Posted May 27, 2009 (edited) Yeah if your looking for cheap find a local shop to fab you up one. On a 'stock' z6 2.5" would be more than enough. Might also wanna try CL for a cheap catback. I've sceen plunty of fair/good shape Greedy catbacks from various cars go for as low as $100. yeah i tried CL but cant seem to find anything. and what i do find is so far away that i would rather just pay the extra for the muffler shop to fab one. ill stop by tomorrow and ask them if i get time. i know the owner personally so maybe ill get a discount update on OP Edited May 28, 2009 by SpeedDemon Quote Link to comment Share on other sites More sharing options...
hessey0788 Posted June 5, 2009 Share Posted June 5, 2009 all i have to say is 3 inch exaust will be pretty damn big you need back pressure for the turbo to spool. im doing a b18b swap into mine and going turbo i was thinking about a 2 1/4 would be about right with a high flow cat and muffler im sure my opinion probably isnt the best but thats what i was planning if im wrong please correct me so i dont make a mistake thanks Quote Link to comment Share on other sites More sharing options...
r_wiggum01 Posted June 5, 2009 Share Posted June 5, 2009 all i have to say is 3 inch exaust will be pretty damn big you need back pressure for the turbo to spool. im doing a b18b swap into mine and going turbo i was thinking about a 2 1/4 would be about right with a high flow cat and muffler im sure my opinion probably isnt the best but thats what i was planning if im wrong please correct me so i dont make a mistake thanks that's actually ass backwards. you need some backpressure on a naturally aspirated engines to help with exhaust scavenging. turbo engines are the opposite, backpressure prevents the turbo from spooling quickly. the best exhaust for a turbo car(in terms of spool up and power) is no exhaust. Quote Link to comment Share on other sites More sharing options...
hessey0788 Posted June 6, 2009 Share Posted June 6, 2009 see thats what i used to think that all the back pressure for the motor was contained in the turbo but after i started talking to people that have driven turbos for a long time said you need some back pressure or the turbo to spool im not arguing im just stating what i have been told anyone else have any knowledge for the contrast of information thanks Quote Link to comment Share on other sites More sharing options...
Kastigir Posted June 6, 2009 Share Posted June 6, 2009 see thats what i used to think that all the back pressure for the motor was contained in the turbo but after i started talking to people that have driven turbos for a long time said you need some back pressure or the turbo to spool im not arguing im just stating what i have been told anyone else have any knowledge for the contrast of information thanks Well, everyone else is wrong. Turbos need exhaust gas to flow as freely as possible. More flow = quicker spool = earlier power. Quote Link to comment Share on other sites More sharing options...
SpeedDemon Posted June 6, 2009 Author Share Posted June 6, 2009 =fun Quote Link to comment Share on other sites More sharing options...
hessey0788 Posted June 7, 2009 Share Posted June 7, 2009 (edited) well crap im glad i found this out now because i would have my damn turbo on listening to others with fracking a cat and muffler on it loosing what i really want a quick spool im more of a redlight to redlight guy so that would kill me thanks oh yeah isnt the compression of the z6 a little high to just straight turbo without low compression pistons thats why i was affraid of turboing mine or did i miss him saying that he was changing the pistons? Edited June 7, 2009 by hessey0788 Quote Link to comment Share on other sites More sharing options...
Kastigir Posted June 7, 2009 Share Posted June 7, 2009 well crap im glad i found this out now because i would have my damn turbo on listening to others with fracking a cat and muffler on it loosing what i really want a quick spool im more of a redlight to redlight guy so that would kill me thanks oh yeah isnt the compression of the z6 a little high to just straight turbo without low compression pistons thats why i was affraid of turboing mine or did i miss him saying that he was changing the pistons? Street racing is bad...don't do it. If you're running OBD2, or in an emissions state leave your cat on, it's better for the environment. You can turbo any motor, but the lower the compression the easier it is. DSMs run 8.5:1 Quote Link to comment Share on other sites More sharing options...
SpeedDemon Posted June 7, 2009 Author Share Posted June 7, 2009 Street racing is bad...don't do it. If you're running OBD2, or in an emissions state leave your cat on, it's better for the environment. You can turbo any motor, but the lower the compression the easier it is. DSMs run 8.5:1 dsm's are amazingly fun to turbo. as soon as my buddy comes to work ill try and get a pic of his gen 2 talon 450 AWHP. yeah i just want the turbo to be a little quicker on the street, not racing wise, just incase a need to put the foot down and dont have enough power. im not replacing the pistons, just stock. only going with 8 psi..only thing im changing is the head studs and exhaust Quote Link to comment Share on other sites More sharing options...
hessey0788 Posted June 8, 2009 Share Posted June 8, 2009 dsm's are amazingly fun to turbo. as soon as my buddy comes to work ill try and get a pic of his gen 2 talon 450 AWHP. yeah i just want the turbo to be a little quicker on the street, not racing wise, just incase a need to put the foot down and dont have enough power. im not replacing the pistons, just stock. only going with 8 psi..only thing im changing is the head studs and exhaust 8 Lbs damn lol i was going to only run 5 or 6 on my b18b i didnt think it would last long on anything higher than that and its a lower compression than the z6 how much lb boost can a stock b18b handle before it is to much for the roads to handle Quote Link to comment Share on other sites More sharing options...
Kastigir Posted June 8, 2009 Share Posted June 8, 2009 (edited) 8 Lbs damn lol i was going to only run 5 or 6 on my b18b i didnt think it would last long on anything higher than that and its a lower compression than the z6 how much lb boost can a stock b18b handle before it is to much for the roads to handle Depends on the tune. 8 lbs is a conservative setup, can run 10 with a good tune. HP is a better indicator than boost level. Boost level is really only for estimation purposes. Have a good shop locally that can dyno tune it? Edited June 8, 2009 by Kastigir Quote Link to comment Share on other sites More sharing options...
SpeedDemon Posted June 8, 2009 Author Share Posted June 8, 2009 Depends on the tune. 8 lbs is a conservative setup, can run 10 with a good tune. HP is a better indicator than boost level. Boost level is really only for estimation purposes. Have a good shop locally that can dyno tune it? theres a place or two that tuned my buddys mr2. im only looking at about 180-200 hp max Quote Link to comment Share on other sites More sharing options...
Kastigir Posted June 8, 2009 Share Posted June 8, 2009 theres a place or two that tuned my buddys mr2. im only looking at about 180-200 hp max 200 is achievable on the stock components. Just think, get it tuned to 200 and you'll be where a DSM sits stock. Quote Link to comment Share on other sites More sharing options...
SpeedDemon Posted June 8, 2009 Author Share Posted June 8, 2009 200 is achievable on the stock components. Just think, get it tuned to 200 and you'll be where a DSM sits stock. yep lol thats about what the goal is..thers a couple dsm guys running around chillicothe with super loud exhausts and no turbos that need some lessons :devil: :devil: :devil: :devil: :devil: :devil: :devil: Quote Link to comment Share on other sites More sharing options...
CleanGSR Posted June 9, 2009 Share Posted June 9, 2009 200 is achievable on the stock components. Just think, get it tuned to 200 and you'll be where a DSM sits stock. At the wheels? Didn't know DSM's came with 200whp stock. Plus, they're kinda heavy compared to a civic aren't they? Quote Link to comment Share on other sites More sharing options...
hessey0788 Posted June 9, 2009 Share Posted June 9, 2009 i was going to ask the same question about the stock dsm's i thought more like around the 160 range thats just a guess though wouldnt have thought 200 and so you think i could have my b18b set up for 200 hp and it wouldnt risk blowing the motor within a few thousand miles and i dont have anyone close for a dyno tune but i know a guy that does a street tune so that i can at least drive it to get it dyno tuned later on Quote Link to comment Share on other sites More sharing options...
alex37211 Posted June 9, 2009 Share Posted June 9, 2009 (edited) b18b would be safe and sound at 200whp with stock internals if properly tuned. A good street tuner would be fine for temporary. There's a guy around here who a LOT of ppl use for tuning and they've never seen dyno time, but their stuff has held up well. He's made quite a name for himself. And yeah, a 2G eclipse gsx is like 210hp at the crank. But awd has a LOT of drivetrain loss. Like 35% or so. That would put that 210 figure at around 136whp. That's less than a GSR. Edited June 9, 2009 by alex37211 Quote Link to comment Share on other sites More sharing options...
hessey0788 Posted June 9, 2009 Share Posted June 9, 2009 yeah awsome i have a t3t4 turbo for it i know its big but im planning on doing bigger and better things later on approximately when do you think ill hit full spool with it with a 2.5 inch exaust and a stock b18b tuned for 200hp with a 255 fuel pump and dsm 450's i know its really hard to tell all are diffrent i know but i was just curious to see the responses Quote Link to comment Share on other sites More sharing options...
Kastigir Posted June 9, 2009 Share Posted June 9, 2009 (edited) At the wheels? Didn't know DSM's came with 200whp stock. Plus, they're kinda heavy compared to a civic aren't they? He's not saying at the wheels. A 2G DSM turbo has about 210 at the crank, non turbos around 130. They weigh just shy of 2800 pounds. Edited June 9, 2009 by Kastigir Quote Link to comment Share on other sites More sharing options...
