jkm345 Posted August 29, 2008 Share Posted August 29, 2008 Is this a direct fit??or do i need a couple things to make it fit???i got a 94 gsr head with a b16a block! Link to comment Share on other sites More sharing options...
..SSR.. Posted August 29, 2008 Share Posted August 29, 2008 It works very well. GSR intake ports have better geometry and a better entry angle. Quench pads for more compression and a more complete burn. Doesn't hurt that the GSR head flows better on the intake side either. Link to comment Share on other sites More sharing options...
lastresort576 Posted August 30, 2008 Share Posted August 30, 2008 very good set-up for boost. youve got a great rod-stroke ratio, plus the more desired head for boost as well. Link to comment Share on other sites More sharing options...
..SSR.. Posted August 30, 2008 Share Posted August 30, 2008 R/S doesn't matter, especially for boost. Boosted engines have less tensile stress on the rods. Which is why they have no problem running up to 12k. Link to comment Share on other sites More sharing options...
jkm345 Posted August 30, 2008 Author Share Posted August 30, 2008 yeahs, but i want to know if i was to put a 94 gsr head on a b16 block..well it be a DIRECT FIT???or do i need to buy a couple things to make it fit? Link to comment Share on other sites More sharing options...
alex37211 Posted August 30, 2008 Share Posted August 30, 2008 I don't see why it wouldn't be a direct fit. When building an LS VTEC, the b16's and b18c's are both options for the same block, so I would say, yes. It is a direct fit. I'm not too sure if there's a difference in head gasket though. Link to comment Share on other sites More sharing options...
Hatch92 Posted August 30, 2008 Share Posted August 30, 2008 it'll bolt on fine Link to comment Share on other sites More sharing options...
adamEj6 Posted September 18, 2008 Share Posted September 18, 2008 just need the gsr ecu or chip the b16 one. Link to comment Share on other sites More sharing options...
jkm345 Posted September 29, 2008 Author Share Posted September 29, 2008 i recently threw the whole thing together and is not sure of the gsr timing belt fitting the whole thing..it fits but will it be good enough???do i have to get a b16 timing belt? Link to comment Share on other sites More sharing options...
shak3yb0n3z Posted October 5, 2008 Share Posted October 5, 2008 B16A, B16B, B18C B18C1, B18C5 all have the same interchangable parts. they all use the same waterpump, oil pump, alternator timing belts, you can interchange any of their pistons, camshafts and valve trains Link to comment Share on other sites More sharing options...
cranny Posted October 5, 2008 Share Posted October 5, 2008 couldnt be more wrong. b18a/b are the same. b18c5/c1 the same/ and b16a is its own. and you need a b16a timingbelt buddy. dont run that gsr belt , would be a bad thing. Link to comment Share on other sites More sharing options...
shak3yb0n3z Posted October 6, 2008 Share Posted October 6, 2008 couldnt be more wrong. b18a/b are the same. b18c5/c1 the same/ and b16a is its own. and you need a b16a timingbelt buddy. dont run that gsr belt , would be a bad thing. i never mentioned the B18a/b engines cuz that information doesn't apply to him. as far as the VTEC B-series goes you can use a GSR timing belt on a B16a. B16A3/A2 and B18C/C1 are very similar, with the GSR head intake ports having a better geometry and a better entry angle the B16B and B18C5 heads are damn near identical. both come from factory with a P&P and upgraded Valvetrain and differnt Pistons. the B16B is a destroked B18C5. putting a GSR head on a B16 block wouldn't limit you to one type of belt. you could use a B16 or the GSR belt. even when you do an LS/VTEC setup you can use either belt (providing you're using a VTEC water pump and not an LS water pump), why would it be any different here? Link to comment Share on other sites More sharing options...
cranny Posted October 6, 2008 Share Posted October 6, 2008 im not gonna argue with you , but the block height is different on all those engines dude. but run what you want , to each thier own. you cant use a b16 timing belt on an lsvtec either , i dont know where your getting this from. to the guys car in question here , do yourself a favor , run a b16a timing belt. Link to comment Share on other sites More sharing options...
Hondahunter Posted October 6, 2008 Share Posted October 6, 2008 Do me a favor...BUY MY B16 belt!!! I have a brand new OEM one!!! Link to comment Share on other sites More sharing options...
jkm345 Posted October 7, 2008 Author Share Posted October 7, 2008 yeahs, the gsr belt was too long, i bought a b16 belt and it fits nows!! Link to comment Share on other sites More sharing options...
Hondahunter Posted October 8, 2008 Share Posted October 8, 2008 do you have motor pics??? I love me some B-series! :drool: Link to comment Share on other sites More sharing options...
