clio_16v Posted May 20, 2008 Share Posted May 20, 2008 I'm looking to drop my 99 EJ coupe at the moment. I was looking at maybe K Sport coilovers. Only problem is the price. They're the equivilant of about 1600 dollars here! I was offered a second hand set of coilovers from an Integra type r though, Will they fit my coupe? I've seen kits advertised saying "will fit Civics/Integras" does that mean its the same setup on both cars? Link to comment Share on other sites More sharing options...
CleanGSR Posted May 20, 2008 Share Posted May 20, 2008 When it says civic/integra's it's talking about non-ITR's. ITR suspension won't fit your car unless you do a full conversion and I'm not sure what all that entails. Link to comment Share on other sites More sharing options...
clio_16v Posted May 21, 2008 Author Share Posted May 21, 2008 When it says civic/integra's it's talking about non-ITR's. ITR suspension won't fit your car unless you do a full conversion and I'm not sure what all that entails. Does anyone know what this entails? Link to comment Share on other sites More sharing options...
CleanGSR Posted May 21, 2008 Share Posted May 21, 2008 Nancy does. She did an entire 5 lug conversion on her hatch. I believe the entire setup will run between 1000-1500 if my memory serves me correct. Link to comment Share on other sites More sharing options...
CRG7 Posted May 21, 2008 Share Posted May 21, 2008 ^ Nancy will answer. The guy I sold my CRX front end to did the 5-lug conversion on his Integra, said he wouldn't do it again, for what it's worth. Link to comment Share on other sites More sharing options...
lastresort576 Posted May 21, 2008 Share Posted May 21, 2008 if you just want the 5 lugs, and not the brakes, cant you just swap the hubs instead of the whole sheabang? Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted May 21, 2008 Share Posted May 21, 2008 I thought the only difference (besides 5 lug, anyways) was a stronger rear subframe and different rear LCA's? Someone can clarify? Link to comment Share on other sites More sharing options...
CleanGSR Posted May 21, 2008 Share Posted May 21, 2008 That's right from what I believe. 5 lug, rear subframe is stiffer, larger rear sway bar and different LCA's (oh and the rear brace in the trunk. Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted May 21, 2008 Share Posted May 21, 2008 I just want some ITR rear LCA's. Im not going to order suspension again for my car until I get those... Link to comment Share on other sites More sharing options...
clio_16v Posted May 22, 2008 Author Share Posted May 22, 2008 I dont care about the 5 lug conversion, I was just offered some Integra type r coilovers and wondering what is necessary to fit them Link to comment Share on other sites More sharing options...
Nancy Posted May 22, 2008 Share Posted May 22, 2008 you need to run itr rear lca's for those coilovers. might have a little problem with that as the em1, ej6 rear lca's are longer than itr ones. but you can still try the lca swap but might mess up the natural geometry of your car. itr coilovers in the rear dont have the fork design like the non itr integras do. heres some function7 lca's, the best aftermarket lcas out right now this is the itr application, notice the strut mounts into the hole for better rigidity non itr application for common fork design coilovers Link to comment Share on other sites More sharing options...
clio_16v Posted May 22, 2008 Author Share Posted May 22, 2008 Thanks Nancy. I have a feeling you'll be answering a lot of my Honda queries! Link to comment Share on other sites More sharing options...
clio_16v Posted May 22, 2008 Author Share Posted May 22, 2008 Also, Would a complete set of strut braces for a EK9 Type R civic fit my EJ6 coupe? Link to comment Share on other sites More sharing options...
Nancy Posted May 22, 2008 Share Posted May 22, 2008 Thanks Nancy. I have a feeling you'll be answering a lot of my Honda queries! ill help anytime i know the answer. ive had 2 itr's, 2 ej6's and 1 eh2 so i know a little bit. just so you know, ksports are known to blow now and then. they should sell for like 800 max brand new. Link to comment Share on other sites More sharing options...
clio_16v Posted May 22, 2008 Author Share Posted May 22, 2008 Thanks again. My only problem is that if i wanna buy stuff from america then the shipping will kill me. Good coilovers in Ireland are 1200 dollars plus. I've seen new coilovers for like 650 dollars but shipping would be astronomical! Link to comment Share on other sites More sharing options...
