90IntegraC1 Posted September 24, 2006 Share Posted September 24, 2006 ahhhhh so many questions, so few answers.... i'm just as confuzzled as u. Link to comment Share on other sites More sharing options...
mycarsux Posted September 25, 2006 Share Posted September 25, 2006 will a teg harness plug right into the p28? wondering cause its SOHC ECU. i have a 98 GSR head, 97 LS block. so, get the OBD1 dizzy, to go with the ECU, teg harness now, do i get an OBD1 or 2 harness, or does it matter? and will the dizzy plug right into the harness? OR could i get the teg harness (obd2) obd2 head obd2 block obd1 ECU and just get the conversion harness to plug into the ECU? everyone in the past has told me my SOHC vtec harness will do just fine. f*ck. get ALL obd1 parts so it goes with your ecu. the dizzy doesn't matter but get it with the car you are getting the ecu from so its easy. get the obd1 wiring harness get a conversion harness regardless of a half ass job, its easier and waaaaaaaayyyyyy less complicated. SOMEONE CORRECT ME IF I'M WRONG Link to comment Share on other sites More sharing options...
mountaindewguy Posted September 25, 2006 Author Share Posted September 25, 2006 ok, BUT, for the last time, the ECU is from a SINGLE OVER HEAD CAM CAR! A D SERIES, NOT A B SERIES. Link to comment Share on other sites More sharing options...
mountaindewguy Posted September 25, 2006 Author Share Posted September 25, 2006 and for the record, EVERYTHING IS OBD2A. (HEAD, BLOCK) CAR is 95 civic, OBD1 ECU, is p28 OBD1 ECU from SOHC harness is OBD1 vtec from SOHC now, what dizzy do i use, thats it and since i'm using the civic harness, do i need the jumper harness ORRRRR if i use a teg harness (obd2) do i just need a jumper harness for the ECU? the way i figure it, i get a b series OBD2 dizzy (OBD2A) and a teg harness, and get a jumper harness. or just use my civic harness and don't use a jumper harness. from here on out, unless you know exactly what you're doing. don't post. cranny, solles, ring in lol. and all answers from here on out are in stupid english lol Link to comment Share on other sites More sharing options...
cranny Posted September 25, 2006 Share Posted September 25, 2006 ok so what you need is a teg harness , a conversion harness to make the teg engine harness fit the P28 ecu. this is easiest way in my opinion. orrrr , you can find out what wires are what in your car now(the pinouts) , and cut the plugs off your existing engine harness and hardwire them to thier proper places on the teg plugs(cut out of a tegs engine harness) which youl also need , for this anyways. pain in the ass but really the proper way of doing it. orrr , you could leave your harness in there , still get a conversion harness to plug an obd1 ecu(your P28) into your obd2a harness(existing harness) , and have a few things to work out. orrrr , lol , naa thats it. Link to comment Share on other sites More sharing options...
mountaindewguy Posted September 25, 2006 Author Share Posted September 25, 2006 so just build the damn engine, get the obd2 harness to match (with dizzy) and the sohc ecu, and all i need is the conversion harness? good. Link to comment Share on other sites More sharing options...
SolLesHonda Posted September 25, 2006 Share Posted September 25, 2006 Yes. Like I said, it doesn't matter. You're making this way harder than it needs to be lol. Link to comment Share on other sites More sharing options...
mountaindewguy Posted September 25, 2006 Author Share Posted September 25, 2006 well then whats up with using my SOHC harness? everyone told me it would be the same..? Link to comment Share on other sites More sharing options...
SolLesHonda Posted September 25, 2006 Share Posted September 25, 2006 You can use it man. I'm telling you that you can. I'm 99.9% sure. Link to comment Share on other sites More sharing options...
mountaindewguy Posted September 25, 2006 Author Share Posted September 25, 2006 so why is cranny all anal about having to rewire stuff then? and if i use a DOHC harness, it has to be vtec right? Link to comment Share on other sites More sharing options...
SolLesHonda Posted September 25, 2006 Share Posted September 25, 2006 Yeah. Cranny is smart with this stuff, but I am pretty damn sure on this one lol. Link to comment Share on other sites More sharing options...
mountaindewguy Posted September 25, 2006 Author Share Posted September 25, 2006 ok. so going back, keept he obd2 dizzy, but use sohc harness, do i need a jumper wire? Link to comment Share on other sites More sharing options...
SolLesHonda Posted September 25, 2006 Share Posted September 25, 2006 Probably. Are you installing everything yourself? Link to comment Share on other sites More sharing options...
buggman26 Posted September 25, 2006 Share Posted September 25, 2006 obd2 can go suck a duck Link to comment Share on other sites More sharing options...
mountaindewguy Posted September 25, 2006 Author Share Posted September 25, 2006 don't threadjack. i'm not installing EVERYTHING myself, but i'm not taking it to a shop either. my cousin and this local kid that knows this stuff is helping me, but i can't get a hold of him cause he's out of state. i think i'll just get the OBD2 harness, OBD2 dizzy, the p28 ECU, and the jumper harness. do i need the vtec harness? sounds like a dumb question but everyone just says integra harness. Link to comment Share on other sites More sharing options...
SolLesHonda Posted September 25, 2006 Share Posted September 25, 2006 Yeah. It's an easy install. Link to comment Share on other sites More sharing options...
mountaindewguy Posted September 25, 2006 Author Share Posted September 25, 2006 ok finally got it. obd2 harness, dizzy... obd1 ecu with jumper harness. will i run into any plug issues with the non vtec block and vtec head... like there being an extra plug or something...? Link to comment Share on other sites More sharing options...
mycarsux Posted September 25, 2006 Share Posted September 25, 2006 will i run into any plug issues with the non vtec block and vtec head... like there being an extra plug or something...? i'm gonna go ahead and say no since ls/vtec is pretty damn common. Link to comment Share on other sites More sharing options...
mountaindewguy Posted September 25, 2006 Author Share Posted September 25, 2006 yeah, i figured that. i remember a while back someone saying there will be an extra plug i think either by the tranny or crankcase, but to just tape it up and out of the way cause it doesn't make a difference. sound like i'm set solles? Link to comment Share on other sites More sharing options...
cranny Posted September 26, 2006 Share Posted September 26, 2006 you got er , your existing harness , a conversion harness to plug your P28 into an obd2 harness , and an obd2 dizzy cause your using your existing harness which is obd2. make sure you get the same obd2 though be it a or b. i bet any money youl have to unplug your EVAP purge control solenoid. Link to comment Share on other sites More sharing options...
mountaindewguy Posted September 26, 2006 Author Share Posted September 26, 2006 you got er , your existing harness , a conversion harness to plug your P28 into an obd2 harness , and an obd2 dizzy cause your using your existing harness which is obd2. make sure you get the same obd2 though be it a or b. i bet any money youl have to unplug your EVAP purge control solenoid. i don't have an OBD2 harness... my civic harness is OBD1. why do i need my current harness plus an obd2 harness? Link to comment Share on other sites More sharing options...
mycarsux Posted September 26, 2006 Share Posted September 26, 2006 i don't have an OBD2 harness... my civic harness is OBD1. why do i need my current harness plus an obd2 harness? 2 harness is better than 1 i'm jk. cranny isn't making any sense again. Link to comment Share on other sites More sharing options...
cranny Posted September 26, 2006 Share Posted September 26, 2006 honestly dude , i asked you like 2 times what fukin car we are talking about and you didnt tell me , thats why i kept saying Link to comment Share on other sites More sharing options...
cranny Posted September 26, 2006 Share Posted September 26, 2006 honestly dude , i asked you like 2 times what fukin car we are talking about and you didnt tell me , thats why i kept saying 96-00 civic. WHAT YEAR CIVIC DUDE , for the last time. your saying its a 92-95 gen civic? no wonder your all fuked up , post all the info dude so than theres no comfusion , all this time your asking us what gear to use , and never once did you post what car it is , lol. if the car is obd1 civic than you should know dam well the P28 will plug right into the car , no problem. all the jumper or conversion harness does , is rearrange your ecu's pinouts without cutting a wire. Link to comment Share on other sites More sharing options...
SolLesHonda Posted September 26, 2006 Share Posted September 26, 2006 Don't post twice. Link to comment Share on other sites More sharing options...
