good question about parts in LSVTEC
i already did....
and for the record, EVERYTHING IS OBD2A. (HEAD, BLOCK)
CAR is 95 civic, OBD1
ECU, is p28 OBD1 ECU from SOHC
harness is OBD1 vtec from SOHC
now, what dizzy do i use, thats it
and since i'm using the civic harness, do i need the jumper harness
ORRRRR
if i use a teg harness (obd2) do i just need a jumper harness for the ECU?
the way i figure it, i get a b series OBD2 dizzy (OBD2A) and a teg harness, and get a jumper harness.
or just use my civic harness and don't use a jumper harness.
from here on out, unless you know exactly what you're doing. don't post.
cranny, solles, ring in lol.
and all answers from here on out are in stupid english lol
  • Replies 63
  • Created
  • Last Reply
hahaha , for once i totally agree with solles , lol , no matter how much i dont like it. ok easy dude. you need a dizzy from an obd1 integra. or you can do like solles says , get any one and repin or change wiring so each sensor is on its correct wire leading to ecu. simple. your P28 will plug right into your car. ill make an ecu map for ya , just give me a bit.
sounds good to me. the thing is the cars be it integra or civic , are wired the same , but , obd1 tegs and civics , obd2a tegs and civics , so on. so if you stay obd1 parts , will make your life easier , thats all i was getting at.
heres as far as i got in your ecu map , this is for obd1 Si and Dx civics :
A01 green , injector 1
A02 yellow , injector 4
A03 red , injector 2
A04 orange/white , VTS(spool solenoid valve , Z1 and Z6 engines)
A05 light blue , injector 3
A06 orange/black , HTCNTL(heated oxygen sensor , B7 , Z6 engines)
A07 green/yellow , FLR1(main relay)
A08 green/yellow , FLR2(main relay)
A09 green/white , IACV
A10 not used
A11 orange/blue , ES(egr control solenoid valve , Z1 engine only)
A12 yellow/green , FANC(fan control)
A13 green/orange , WARN(check engine light)
A14 not used
A15 red/blue , ACC(ac compressor clutch relay)
A16 white/yellow or pink , ACGC(alternator)
A17 ATLSB(A/T solenoid , a/t only)
A18 not used
A19 ATLSA(A/T solenoid , a/t only)
A20 red , PGS(purge cut off solenoid valve)
A21 red/green , IGP1(ignitor)
A22 red/green , IGP2(ignitor)
A23 PG1
A24 PG2(ground/mainrelay)
A25 IGP1
A26 LG1
B01 IGP2
B02 LG2
B03 ATD3(D3 indicator , a/t only)
B04 ATD4(D4 indicator , a/t only)
B05 blue/red , ACS(ac switch)
B06 not used
B07 CLSW(switched ground for M/T) ; ATNP(park neutral indicator , a/t only)
B08 brown/red , PSW(power steering pressure sensor switch)
B09 white/blue , STS(main relay)
B10 yellow/blue , VSS(speed sensor)
B11 CYLP(cylinder sensor)
B12 CYLM(cylinder sensor)
B13 TDCP(top dead center sensor)
B14 TDCM(top dead center sensor)
B15 CRNKP(crank position sensor)
B16 CRNKM(crank position sensor)
D01 not used
D02 green/white , BKSW(brake pedal switch)
D03 LABEL(laf sensor , Z1 engine only)
D04 brown , SCS(service check connector)
D05 not used
D06 orange/blue , VTM(vtec oil pressure switch , for D16Z1 and D16Z6 engines)
D07 light blue , TXD/RXD(data link connector)
D08 VS+(laf sensor , Z1 engine only)
D09 white/yellow or pink , ACGF(alternator)
D10 green/red , EL(eld unit)
D11 not used
D12 white/black , EGRL(egr valve lift sensor, for D15Z1 only)
D13 red/white , TW(tw sensor , tied into data link connector)
D14 orange/black , heated O2 sensor(for B7 , Z6 , Z1((IP+ also)), engines) ; O2(non heated , for B8)
D15 red/yellow , TA(ta sensor , tied into data link connector)
D16 orange/black , IP-,VS-(laf sensor)
D17 not used
D18 pink/green , SIL(shift up indicator , m/t) , white/red (interlock control unit , a/t)
D19 VCC1(map sensor)
D20 VCC2(egr valve)
D21 SG1(map sensor)
D22 SG2(connected to all engine sensors for data link connector)
like i said im really not finished this yet , im making one for all the cars , few things ill update.
i would say yes although im not 100% positive. like i mentioned before , obd2 and obd1 cars are different entirely. if you were using all obd1 parts , engine and head as well , youd have no problems. since your using obd2 head and block , it will have obd2 sensors. the sensors most likely are 95% the same. but lets for example say the 2 map sensor wires leaving the ecu are blue and red(examples) , well in an obd1 car , the blue and red wires are going to the map sensor. but in an obd2 car , it could be the blue and white wire for the map sensor , and they could leave the ecu from a different location. so at the sensor plug end of the wires(once P28 is plugged in), the blue and red one in obd2 could be going to somin other than the map sensor. you see what im getting at?
your best bet is when unplugging all your wiring harness under the hood when taking engine out , label them all.
lets get to obd2 ecu maps , make this easier. theres 4 sockets in obd1 and 2 ecu's but one is for autos only , in obd1 , its C plug. in obd2 , its B plug.
all 96-98 models except D16B5 , 99-00 D16Y5 w/ manual tranny
OBD2a(ecu pin) , Function , Color , (Notes)
A01 , Injector 4 , Yellow
A02 , Injector 3 , Blue
A03 , Injector 2 , Red
A04 , Injector 1 , Brown
A05 , SO2SHTC , black/white
A06 , PO2SHTC , Orange/black
A07 , D16Y5 with m/t-pink(E-EGR) ; CVT-red(esol)
A08 , VTS , green/yellow , (D16Y5 , D16Y8)
A09 , LG1 , brown/black
A10 , PG1 , Black
A11 , IGP1 , Yellow/Black
A12 , IACV , black/blue , (D16Y5 , D16Y8 w/. M/T)
A13 , *1: ORN(IACV N)
A14 , *1: BLK/BLU (IACV P)
A15 , PCS , red/yellow
A16 , FLR , Green/Yellow
A17 , ACC , Black/Red
A18 , MIL , Green/Orange
A19 , ALTC , white/green , (USA)
A20 , ICM , yellow/Green
A21 ----------------
A22 , LG2 , Brown/black
A23 , PG2 , Black
A24 , ICP2 , Yellow/Black
A25 , CVT , WHT/RED (VREF)
A26 ----------------
A27 , FANC , Green , (USA)
A28 , *2: BLU (2WBS)
A29 , *2: LT GRN/WHT (VSV)
A30 , SIS , white/red , (SLU for CVT) (shift up indicator light)
connector B only for auto tranny only
B01 WHT(LS-1)
B02 RED(LS+1)
B03 BLU/YELLOW(SHA)
B04 GRN/BLK(LC B)
B05 YEL(LC A)
B06 ------
B07 ------
B08 PINK(ATP D3)
B09 ------
B10 ------
B11 GRN/WHT (SHB)
B12 WHT/RED(SLU)
B13 GRN/BLK(D4 ind)
B14 WHT(NM SG)
B15 RED(NM)
B16 WHT(ATP R)
B17 BLU(ATP 2)
B18 -----
B19 -----
B20 -----
B21 -----
B22 GRN(NC SG)
B23 BLU(NC)
B24 YEL(ATP D4)
B25 LT GRN(ATP NP)
C01 CKFP , blue/red
C02 CKPP , Blue
C03 TDCP , green
C04 CYPP , yellow
C05 ACS , Blue/Red
C06 STS , Blue/orange
C07 SCS , Brown
C08 K-line , light blue
C09
C10 VBU , White/Blue
C11 CKFM , white/red
C12 CKPM , white
C13 TDCM , red
C14 CYPM , black
C15 VTM , blue/black , (D16Y5 , D16Y8)
C16 PSPSW , green , (USA)
C17 ALTF , white/red
C18 VSS , blue/white
C19 -----
C20 -----
C21 -----
C22 -----
C23 D16Y5 with M/T-BLK(IP +)
C24 D16Y5 with M/T-RED(IP-,VS-)
C25 D16Y5 with M/T-WHT(VS +)
C26 -----
C27 -----
C28 -----
C29 CLSW , red , (D16Y5 w/. M/T) ; ATPNP , light green , (CVT only)
C30 TMB , PINK , (CVT only)
C31 -----
D01 TPS , red/Black
D02 ECT , Red/White
D03 MAP , red/green
D04 VCC1 , Yellow/red
D05 BKSw , Greem/White
D06 KS , Red/blue , (D16Y8/CVT)
D07 PHO2S , White , (all , except , D16Y5 w/. M/T=LABEL)
D08 IAT , red/yellow
D09 EGRL , white/black , (D16Y5 only)
D10 VCC2 , Yellow/blue
D11 SG2 , Green/black
D12 SG1 , Green/white
D13 SHO2SG , green/black , (D16Y5 , D16Y8) ; red/yellow , (D16Y7)
D14 SHO2S , white/red
D15 *2:light green , (PTANK)
D16 EL , green/red , (USA)
*1=D16Y5 , D16Y8 w/. A/T
*2=D16Y7 , all
heres an obd2b ecu map i just finished , i made these using the service manuals so there right for sure. most of the crap you can find is wrong.
D16B5 , all 99-00 models except D16Y5 w. M/T
A01 *1 , STS CHTL , blue/white
A02 *1 , TFO , green/yellow
A03 *1 , FWARN , blue/red ; *4 , 2WBS , blue
A04 *1 , F METER , orange ; *4 , VSV , light green/white
A05 *2 : CRS , blue/green
A06 *4 : PCS , red/yellow
A07 ATP D , yellow , (CVT only)
A08 So2S HTC , black/white
A09 ATP DN , light green , (CVT only)
A10 SCS , brown
A11 -----------
A12 -----------
A13 -----------
A14 *3 : D4IND , green/black
A15 -----------
A16 FLR , green/yellow
A17 ACC , black/red
A18 MIL , green/orange , (engine light)
A19 *4 : NEP , blue
A20 FANC , green
A21 *1 : K LINE , light blue ; *4 : K LINE , blue/yellow
A22 *1 : PFO , blue/yellow ; ATP L , blue , (CVT only)
A23 SHO2S , white/red
A24 *1 : STS , blue/orange ; *4 : STS , blue/white
A25 -----------
A26 PSPSW , green
A27 ACS , blue/red
A28 A/T : white/red
A29 *4 : light green , PTANK
A30 EL , green/red
A31 -----------
A32 BKSW , green/white , (brake switch)
B01 IGP1 , yellow/black
B02 PG1 , black
B03 injector 2 , red
B04 injector 3 , blue
B05 injector 4 , yellow
B06 *4 : IACVP , black/blue
B07 E-EGR , pink , (D16B5) ; ESOL , red , (CVT only)
B08 *1 : LS- , white ; HLC LSM , pink/black , (CVT only)
B09 IGP2 , yellow/black
B10 PG2 , black
B11 injector 1 , brown
B12 *2 : VTS , green/yellow
B13 ICM , yellow/green
B14 INJ MOD , light green , (D16B5)
B15 *4 : IACV N , orange
B16 -----------
B17 *1 : LS+ , red ; HLC LSP , green/white , (CVT only)
B18 SC LSM , pink/black , (CVT only)
B19 -----------
B20 LG1 , brown/black
B21 VBU , white/blue
B22 LG2 , brown/black
B23 *3 : IACV , black/blue
B24 -----------
B25 SCLSP , yellow , (CVT only)
C01 PO2SHTC , black/white
C02 ALTC , white/green
C03 *1 : KS , red/blue
C04 -----------
C05 ALTP , white/red
C06 *2 : EGR2 , white/black
C07 SG1 , green/white
C08 CKPP , blue
C09 CKPM , white
C10 *3 : VTM , blue/black
C11 -----------
C12 -----------
C13 TF2 , green/red , (D16B5)
C14 PF2 , blue/red , (D16B5)
C15 -----------
C16 PHO2S , white
C17 MAP , red/green
C18 SG2 , green/black
C19 VCC1 , yellow/red
C20 TDCP , green
C21 TDCM , red
C22 CKFP , blue/red
C23 VSS , blue/white
C24 -----------
C25 IAT , red/yellow
C26 ECT , red/white
C27 TPS , red/black
C28 VCC2 , yellow/blue
C29 CYPP , yellow
C30 CKFM , white/red
D connector is for D16B5 except CVT , and 99-00 CVT trannys
connector A : *1= D16B5
*2= D16Y7/D16Y8 with a/t
*3= a/t except CVT
*4= except D16B5
connector B : *1= a/t except CVT
*2= except D16Y7
*3= m/t except D16Y7
*4= a/t , and all D16Y7
connector C : *1= CVT , D16Y8 , B16A2
*2= CVT , D16B5
*3= except D16Y7
feel free to copy and paste boys , good to have.
and heres an obd0 ecu map with dpfi and mpfi comparison also already done :
OBD0 DPFI to MPFI Comparison Pinouts
DPFI MPFI
Pin# Wire Color Function Wire Color Function
A1 Yellow 2 Aux Injector , Brown #1 Injector
A2 Black 1 Main Relay/Ground , Black 1 Main Relay/Ground
A3 Yellow 1 Aux Injector , Red #2 Injector
A4 Black 2 Main Relay/Ground , Black 2 Main Relay/Ground
A5 Red 2 Main Injector , Light Blue #3 Injector
A6 Green Purge Cut Off Solenoid Valve (Coil) , Green Purge Cut Off Solenoid Valve (Coil)
A7 Red 1 Main Injector , Yellow 1 #4 Injector
A8 Yellow 3 Sedan LX (A/T only)
A10 Red EGR Solenoid Control Valve (Coil) (A/T only)
A11 Blue/Yellow EACV (Coil) , Blue/Yellow EACV (Coil)
A12 Green/Black 2 Main Relay , Green/Black 2 Main Relay
A13 Yellow/Black 2 Main Relay , Yellow/Black 2 Main Relay/Injector Resistor Box
A14 Green/Black 1 Main Relay , Green/Black 1 Main Relay
A15 Yellow/Black 1 Main Relay , Yellow/Black 1 Main Relay/Injector Resistor Box
A16 Brown/Black Ground , Brown/Black Ground
A17
A18 Black/Red Ground , Black/Red Ground
B1 White/Green Hazard Fuse , White/Green Hazard Fuse
B2 Orange Tandem Control Solenoid Valve , Blue 1 Fast Idle Control Solenoid Valve
B3 Yellow A/C Clutch Relay , Yellow A/C Clutch Relay
B4 Yellow/Green Radiator Fan Relay , Yellow/Green Radiator Fan Relay
B5 White/Yellow Alternator , White/Yellow Alternator
B6 Green/Orange Check Engine Warning Light , Green/Orange Check Engine Warning Light
B7 Green/Orange Position Console Switch (Park, Neutral) , (A/T only)
B8 Blue/Red A/C Switch , Blue/Red A/C Switch
B9
B10 Orange Crank Angle Sensor
B11 Green/Black A/T Shift Position Console Switch (Drive) , (A/T only)
B12 White Crank Angle Sensor
B13 Blue/White Main Relay , Blue/White Main Relay
B14 Blue 2 To Yellow, To Alternator Blue 2 Alternator
B15 White 1 Ignitor Unit White 1 Ignitor Unit
B16 Yellow/Red Speed Sensor Yellow/Red Speed Sensor
B17 White 2 Ignitor Unit White 2 Ignitor Unit
B18
B19 Green/Red Electric Load Detector Green/Red Electric Load Detector
B20 Brown Ignition Timing Adjusting Connector Brown Ignition Timing Adjusting Connector
C1 Orange Crank Angle Sensor Blue/Green Cylinder Position Sensor
C2 White 4 Crank Angle Sensor Blue/Yellow Cylinder Position Sensor
C3 Orange/Blue TDC Sensor Orange/Blue TDC Sensor
C4 White/Blue TDC Sensor White/Blue TDC Sensor
C5 Red/Yellow TA Sensor Red/Yellow TA Sensor
C6 Red/White 1 TW Sensor Red/White 1 TW Sensor
C7 Red/Blue Throttle (Position) Angle Sensor (TPS) Red/Blue Throttle (Position) Angle Sensor (TPS)
C8 Yellow EGR Lift Valve Sensor
C9 Red/White 2 PA Sensor Red/White 2 PA Sensor
C10 Green/White 3 Brake Switch Green/White 3 Brake Switch
C11 White 1 MAP Sensor White 1 MAP Sensor
C12 Green/White 2 EGR Lift Valve Sensor/Pa Sensor/Ignition Timing Adjusting Connector/TA Sensor/TPS Sensor/TW Sensor Green White 2 Pa Sensor/Ignition Timing Adjusting Connector/TA Sensor/TPS Sensor/TW Sensor
C13 Yellow/White EGR Lift Valve Sensor/Pa Sensor/TPS Sensor Yellow/White Pa Sensor/TPS Sensor
C14 Green/White 1 MAP Sensor Green/White 1 MAP Sensor
C15 Yellow/Red MAP Sensor Yellow/Red MAP Sensor
C16 White 3 O2 Sensor White 3 O2 Sensor
