mountaindewguy Posted May 14, 2006 Share Posted May 14, 2006 what exactly is final drive? i never really knew what it was. is it decent for daily driving? can anyone explain the process of it? and how is it installed? thanks. Link to comment Share on other sites More sharing options...
cranny Posted May 14, 2006 Share Posted May 14, 2006 you know how your axles plug into your tranny from either side right. well there plugging into your differential. your final drive gear is bolted to your differential. heres a pic of it: the final drive is the piece with teeth all the way around the outside. the number of teeth on that wheel with teeth is what makes your final drive ratio what it is. so more teeth on that wheel the lower you will rev on highway , and the less it has the higher youl rev. in order to change your final drive , removal of trans and trans breakdown is required. not a job for the do it yourselfer without the tools or know how. i could do it for you but im sure were at least 1000 miles apart , haha. Link to comment Share on other sites More sharing options...
..SSR.. Posted May 14, 2006 Share Posted May 14, 2006 It is the ring gear on your diff and the counter shaft itself. Higher numerically the fast you will be. Cost ranges from $400-$1,500 ($400 being OEM 4.7, 1,500 being Houseman). Install is usually $600+ or so by a regular shop. Link to comment Share on other sites More sharing options...
Nancy Posted May 14, 2006 Share Posted May 14, 2006 i thought you need to count the teeth on the ring gear and then count the teeth on the pinion gear, then divide the number of teeth on the ring gear by the teeth on the pinion gear and that gives you the final drive ratio. im pretty sure thats how you find out. Link to comment Share on other sites More sharing options...
SolLesHonda Posted May 14, 2006 Share Posted May 14, 2006 ..SSR.. don't you have a 4.7? That's not OEM, or is it ? Link to comment Share on other sites More sharing options...
mountaindewguy Posted May 14, 2006 Author Share Posted May 14, 2006 thanks guys for the answer! Link to comment Share on other sites More sharing options...
..SSR.. Posted May 14, 2006 Share Posted May 14, 2006 I have a 4.71. My stocker was 3.722 (hatchback only). Here is a comparison of my gears. Green is stock, Red is ZC 3rd and final drive. http://www.fatboyraceworks.com/gears/index...Graph&Compare=1 Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted May 14, 2006 Share Posted May 14, 2006 Link didnt work. you need to add the bracket at the end of the /url. Link to comment Share on other sites More sharing options...
SolLesHonda Posted May 14, 2006 Share Posted May 14, 2006 It worked for me. I want a 4.7 FD ..SSR.. Link to comment Share on other sites More sharing options...
cranny Posted May 14, 2006 Share Posted May 14, 2006 was trying to simplify for him SSR . Link to comment Share on other sites More sharing options...
