xalexjx@yahoo.com Posted March 2, 2006 Share Posted March 2, 2006 look at boston acoustics also,,, iv had good experience w/ them.. i bought them 4 years ago and blew one about 3 years after i bought them and they gave me a new one, and i didnt have a reciept either, Link to comment Share on other sites More sharing options...
dr5tock Posted March 2, 2006 Share Posted March 2, 2006 look at boston acoustics also,,, iv had good experience w/ them.. i bought them 4 years ago and blew one about 3 years after i bought them and they gave me a new one, and i didnt have a reciept either, which component set did you have? Link to comment Share on other sites More sharing options...
xalexjx@yahoo.com Posted March 2, 2006 Share Posted March 2, 2006 ill have to go out in the garage and look at the box after dinner Link to comment Share on other sites More sharing options...
dr5tock Posted March 2, 2006 Share Posted March 2, 2006 ill have to go out in the garage and look at the box after dinner the pro series 6.5 are really nice if you can afford the 3-way system more power to ya Link to comment Share on other sites More sharing options...
Verbal Killa Posted March 5, 2006 Author Share Posted March 5, 2006 The title says "finally finished". I'd like to see some finished install pictures please. I'd like to see what you did with your setup as far as the subs/box goes. Nah im finally finished buyin the system.. lol. i tried puttin the 2 15"s in my trunk an they didnt fit. i had too take out the back seats too fit one in there an took over whole trunk. ima get a custom made trunk. for bout 300. ill post pictures when im completely done. Link to comment Share on other sites More sharing options...
dr5tock Posted March 6, 2006 Share Posted March 6, 2006 i have (1) 15" sub in a 5' cubic box which is insane. it takes up so much trunk space. i'm going to get a 10" or 12" solo baric sub this summer and build a stealth box. it will be tight as hell. Link to comment Share on other sites More sharing options...
Blackoutt Posted March 6, 2006 Share Posted March 6, 2006 I have two fosgate P3's and a fosgate d2000 watt amp. I hits hard but I have two MA Audio 3000 sitting in a box and a Boss 4000 watt amp that I am going to change out when I get home. Link to comment Share on other sites More sharing options...
Verbal Killa Posted March 6, 2006 Author Share Posted March 6, 2006 ^^Ur car is sick Link to comment Share on other sites More sharing options...
CleanGSR Posted March 6, 2006 Share Posted March 6, 2006 And that's a large picture. You need to learn how to drive with a body kit. Link to comment Share on other sites More sharing options...
SolLesHonda Posted March 6, 2006 Share Posted March 6, 2006 Maybe it's just the pic, but do I see a tach ? If you have an SI, you have a factory tach that works just fine. What's with the gap between the front bumper and the hood ? Link to comment Share on other sites More sharing options...
InfinitePrelude Posted March 8, 2006 Share Posted March 8, 2006 only just read this tread. nice set up I still say stick with infinity 3ways or components all the way. don't mix and match. subs will have an effect on the 6x9s if its sharing the same air space. ie the boot you got s risk of blowing your subs with that amp though. thats a v good amp don't kill it Link to comment Share on other sites More sharing options...
Verbal Killa Posted March 11, 2006 Author Share Posted March 11, 2006 ^^Thanx man. yeah it is a good amp. noit very big either normal sized. but i guess i just wont turn my bass up all the way Link to comment Share on other sites More sharing options...
rob669 Posted March 19, 2006 Share Posted March 19, 2006 well man i think its gona be tight, the subs and the amp are great, i had the same amp in my integra last year before some one stole it , but the lil speakers im not to crazy about, good luck though on them Link to comment Share on other sites More sharing options...
cranny Posted March 20, 2006 Share Posted March 20, 2006 4g is plenty enough wire. and for the people who havent heard of soundstream theyve been around for a long time and make good gear. in my day were mostly known for there amps but. one system we put in a sunfire(YACK ON GM PRODUCTS) , 2 amps we used were both soundstream. they were monsters. one was called the Picasso and the other was a mono block sub amp called the 10.0. they were high polished chrome and they were badass. Link to comment Share on other sites More sharing options...
9524tee Posted March 20, 2006 Share Posted March 20, 2006 It's ok, better than stock at least... But, you asked for an honest opinion so here it is... The subs... 15's are too big unless you get a super snappy high quality 15 and even then it's not gonna hit the high notes too well... Door speakers... You didn't buy components.... bad call... At least find the specs on your coaxials and wire a crossover to them or something, the sound difference will be amazing... 6x9,s, the spider is ugly, And they are 6x9,s which means your most likely going to put them into the rear of the car? Bad idea also... especially since the subs will be back there too... Not enough highs and mids in the front, so this is what your set up is basically going to sound like... Distorted from the rear especially, and uneven unless you do some SERIOUS tuning with it... If you plan on using this stuff, at least make sure that you use good quality connections and get some good battery terminals, fuses, etc so it will clean up the sound and you can expect them to sound a little better than they normally would... And one of the biggest MUST DO'S is... use some sort of sound deadening material, like dynamat or blackhole 5... It's not that heavy as long as you use just a little bit and place it in just the critical areas... If you want some more advise on what to do and what not to do, email me, I'd be more than glad to help... nizmo24090@aol.com Link to comment Share on other sites More sharing options...
InfinitePrelude Posted March 21, 2006 Share Posted March 21, 2006 If your realy that bothered about sound quality. the speakers should be installed tightly with aposing screws to oak wood its the best way to transfer sound. Link to comment Share on other sites More sharing options...
9524tee Posted March 22, 2006 Share Posted March 22, 2006 If your realy that bothered about sound quality. the speakers should be installed tightly with aposing screws to oak wood its the best way to transfer sound. Or Ironwood from the Sonoran Desert ... The best Link to comment Share on other sites More sharing options...
hondaswap352 Posted March 23, 2006 Share Posted March 23, 2006 i give you props you got realy nice stuff for the system when you get it all in let me know how it sounds Link to comment Share on other sites More sharing options...
