Verbal Killa Posted February 27, 2006 Share Posted February 27, 2006 ok.. well i just finished buyin my whole system. u guys tell me what u think of it. if its good. not good. okay. etc... ( I Have 2 of these, 2005 15" vr's) 15" subwoofer with high-strength steel basket Polymineral cone with double-stitched foam surround Power Handling Watts, Peak (RMS) - 500 (250) Sensitivity [sPLo], dB @ 1W, 1m - 90.2 Effective Frequency Range, Hz - 25-500 Mounting Depth, in (cm) - 7 3/8 (18.7) Hole Cut-Out Diameter, in (cm) - 13 7/8 (35.2) Equivalent Volume [Vas], ft3 (L) - 9.61 (272.33) Net Displacement, in3 (cc) - 198.7 (3256. Moving Mass [Mms], oz (g) - 7.38 (209.31) Magnet Weight, oz (kg) - 75 (2.13) ] (Amplifier KenWood 9152d *Newest one out*) Mono channel Power Amplifier with Dual Mono Drive Function RMS Power: 500W x 1 @ 4 ohms RMS Power: 900W x 1 @ 2 ohms RMS Power: 900W x 1 at 1 ohms RMS Power: 900W x 2 at 4 ohms (Dual Mono Drive) Aluminium Die-casting Heat Sink Detachable Aluminium Dress Plate & Top Panel Control Dual Mono Drive (Bridged Connections of KAC-9152D x 2) Gold Plated Input/Output Terminals Single Side Exposure of Terminals for Multi Installation (Front Speakers 6.5, Inifinity Kappas *Newest ones out 63.7l*) Power Handling, RMS: 75 Watts Power Handling, Peak: 225 Watts Sensitivity: 95dB Frequency Response: 45Hz - 25kHz Mounting Depth: 2-3/16" Impedance: 2 Ohms (6x9 SoundStream xtream) Zolon Coated Low Resonance Baskets Black Zicronium Plated Injection Molded Cones TPU Rubber Surrounds High Efficiency Polymide Dome Tweeters Aluminum Voice Coils Swivel Pole Tweeter Mount Chrome Front Back Plates Rubber Magnet Cover Ferrite Magnets RMS POWER HANDLING (WATTS) : 200 MAGNET WEIGHT (Oz.) : 30 FREQ. RESPONSE (Hz) : 40 - 20k VOICE COIL WOOFER/TWEETER : 1"/1"k VOICE COIL : 0.75 SENSITIVITY 92dB MOUNTING DEPTH (INCHES) : 3.25 What do u guys think my set up will sound like? Rank it. with a 4 Gauge Amp Kit. Thanx Link to comment Share on other sites More sharing options...
90IntegraC1 Posted February 27, 2006 Share Posted February 27, 2006 subs: A amp: A sub wire: B- 6.5's: who makes them? they look cheap 6x9's: who makes them? they look cheap and stupid with that spider thing in the middle on the cover Link to comment Share on other sites More sharing options...
Verbal Killa Posted February 27, 2006 Author Share Posted February 27, 2006 ^^ The 6.5 Infinity Kappas. the newest Ones they have out An 6x9. SoundStream xts Link to comment Share on other sites More sharing options...
90IntegraC1 Posted February 27, 2006 Share Posted February 27, 2006 ooo those infinity's are real nice, haven't seen them yet: A+++ soundstream...never heard them, but you made good choices on everything else so i'll give you an A Link to comment Share on other sites More sharing options...
Verbal Killa Posted February 27, 2006 Author Share Posted February 27, 2006 ^^YEAAAH. it took me a while too buy everything. and my subbs should hit very HARD. since i have a 1992 civic =P Link to comment Share on other sites More sharing options...
CleanGSR Posted February 27, 2006 Share Posted February 27, 2006 Sound of the subs depends on the box about as much as the sub itself. It would sound a lot better if you could sound match the rears with the fronts by getting Infiniti Kappa's all around. Link to comment Share on other sites More sharing options...
Verbal Killa Posted February 27, 2006 Author Share Posted February 27, 2006 ^^So i should get infinity kappas for the back set too then. and the box of the subbs. ima going too have too get custom made box too fix around the trunk in my civic. becuase the 2 boxes i have right now are too big. i had too take out the backseats of my car too fit em in there. an there are HUGE nothing else can fit. not even the rear speakers can fit. so im goin too get a custom made box make around the trunk with Vents in them. so air can pressure out Link to comment Share on other sites More sharing options...
CleanGSR Posted February 28, 2006 Share Posted February 28, 2006 Yeah, if you like rap, then a ported box will be better. Definately go Infiniti Kappa's all around on the mids/highs. Link to comment Share on other sites More sharing options...
Verbal Killa Posted February 28, 2006 Author Share Posted February 28, 2006 ^^Do u think it will slow down my car by ALOT?? the system Link to comment Share on other sites More sharing options...
CleanGSR Posted February 28, 2006 Share Posted February 28, 2006 I'd say it will be noticable. On my previous car I could tell a pretty big difference with 2-12" subs/box/amp in there. Link to comment Share on other sites More sharing options...
Verbal Killa Posted February 28, 2006 Author Share Posted February 28, 2006 damn. that sux i dont want my car runnin slow. its a stock engine still. im workin on the looks. then final ima top it off with a h22/b16a3/b15c5 engine. one of those probobly. after im done with exterior an interior. Link to comment Share on other sites More sharing options...
airjordan223 Posted February 28, 2006 Share Posted February 28, 2006 thats a pretty nice system set up. and deff. go with the infinitys all the way around, thats what i have, its a really clean sound, the highs are excellent, the bass isnt that great, but thats why you have subs. good luck with the box build Link to comment Share on other sites More sharing options...
SexyH22 Posted February 28, 2006 Share Posted February 28, 2006 i think u spent alot of money. Link to comment Share on other sites More sharing options...
CleanGSR Posted February 28, 2006 Share Posted February 28, 2006 No kidding. I wish I had that kinda cash for my motor right now. Link to comment Share on other sites More sharing options...
SexyH22 Posted February 28, 2006 Share Posted February 28, 2006 do what i do. use money you dont have and worry later. Link to comment Share on other sites More sharing options...
CleanGSR Posted February 28, 2006 Share Posted February 28, 2006 I'm already trying to pay off money I didn't have so don't wanna make it worse. Paying off wife's wisdom teeth and house repair bills (all on the credit card). Link to comment Share on other sites More sharing options...
Verbal Killa Posted February 28, 2006 Author Share Posted February 28, 2006 Nah i aint spent alot of money. lol i just turned 16 years old so i dont have much. barely lookin for a job. took me a while to get the money thoe. bought things one by one took me bout 1 month. Inifity Kappas - $140+shippin n handlin SoundStream Xtream - $70 + Shippin n Handlin Kendwood 9152d - $160 + shippin n handlin =O!!! Yess.. very very cheap Two Kicker 15" Vr's - $220 with ported box seperate. i got things very cheap man.. an BRAND NEW. retail price for everything will prob be around 1 grand+. Link to comment Share on other sites More sharing options...
airjordan223 Posted February 28, 2006 Share Posted February 28, 2006 im doing the same thing, i got my sol when i was 15, now im 18 and still slowly adding to it. thats an awesome deal for your system 600 for all that.....real good Link to comment Share on other sites More sharing options...
SolLesHonda Posted February 28, 2006 Share Posted February 28, 2006 Anyone who wants Infinity Kappa or any Infinity Series (Perfects, References, etc.) Let me know. I got both pairs of my Kappa Perfects for 230 shipped. Working at Circuit City has it's perks Link to comment Share on other sites More sharing options...
Verbal Killa Posted February 28, 2006 Author Share Posted February 28, 2006 ^^How much r ur 6x9? Link to comment Share on other sites More sharing options...
sha0linzer0 Posted February 28, 2006 Share Posted February 28, 2006 im getting these: http://www.crutchfield.com/S-Py3kxdpy9AL/c...+6X9&i=1086927I on ebay for $100 i have the infinity 6.5s in the front $50. infinitys have a real good sound. Link to comment Share on other sites More sharing options...
dr5tock Posted March 2, 2006 Share Posted March 2, 2006 ^^How much r ur 6x9? screw 6x9's. component sets are the way to go. unless you have a passive crossover for your speakers they will sound like crap and blow in like 6 months. infiniti speakers are OKAY. they aren't great. if you are looking for supreme car audio invest in image dynamics, boston acoustics, jl audio, alpine, mb quart, phoenix gold, and there's more i'm missing but you get the picture. get a component set. rule of thumb to go by is the bigger the crossover/ better looking the crossover the better sounding it will be. you can tell by the quality of what's good and what's not. Link to comment Share on other sites More sharing options...
CleanGSR Posted March 2, 2006 Share Posted March 2, 2006 The title says "finally finished". I'd like to see some finished install pictures please. I'd like to see what you did with your setup as far as the subs/box goes. Link to comment Share on other sites More sharing options...
90IntegraC1 Posted March 2, 2006 Share Posted March 2, 2006 drstock forgot Eclipse Components +1 for pics Link to comment Share on other sites More sharing options...
dr5tock Posted March 2, 2006 Share Posted March 2, 2006 drstock forgot Eclipse Components +1 for pics i'm not a real big fan of eclipse. they are overpriced in my opinion. Link to comment Share on other sites More sharing options...
