mountaindewguy Posted December 7, 2005 Share Posted December 7, 2005 ok, kinda new to the site... not really a virgin to bolt ons.... but never messed with the cam gears/cams/and pulleys before. so a few questions to get goin on... first, the pulleys...simple any yays or nays about AEM pulleys? the alternator/power steering pulleys? and cams/gears... i was gonna get a stage 1 comp cam (zex cam) for my z6...but i was wondering if i need an aftermarket cam gear for it? because they are noted to be used on stock engines... but i was also told to get one... which would you recommend? i was thinking AEM.. second.. if i do need a cam gear, do i need it 'dyno tuned'? i was told on another honda site that an adjustable cam NEEDS to be dyno tuned. i know plenty of people with them and theres not a dyno around this state as far as i know... is there not a way to correct the timing by yourself? if so.. how? sorry about all the reading...just gettin to know the site, thanks! Link to comment Share on other sites More sharing options...
..SSR.. Posted December 7, 2005 Share Posted December 7, 2005 Stock pulleys and cam gear. Link to comment Share on other sites More sharing options...
mountaindewguy Posted December 7, 2005 Author Share Posted December 7, 2005 whats the complaint on the aem pulleys? Link to comment Share on other sites More sharing options...
..SSR.. Posted December 7, 2005 Share Posted December 7, 2005 They don't do crap. Link to comment Share on other sites More sharing options...
mountaindewguy Posted December 7, 2005 Author Share Posted December 7, 2005 do they affect anything? or do you just think they dont do anything? i mean... if theres no balance issues or belt wear issues.. i'd be willing to give em' a try. thanks for your input! Link to comment Share on other sites More sharing options...
SolLesHonda Posted December 7, 2005 Share Posted December 7, 2005 AEM pulleys don't do much. Although, the Unorthadox underdrive pulley will add a little bit for you. Not much, but a little. Link to comment Share on other sites More sharing options...
..SSR.. Posted December 7, 2005 Share Posted December 7, 2005 Any underdrive pullies do more harm than good. There is a reason there is rubber in the OEM crank pulley. Vibrations. Yeah yeah, bring up the CTR N1 crank pulley. The CTR N1 was a race car not to be driven on the street. Hence why it came with steelies versus normal CTR wheels. Link to comment Share on other sites More sharing options...
mountaindewguy Posted December 7, 2005 Author Share Posted December 7, 2005 hmmm, dont do much, but that means they do a little... i guess it would be worth trying if their safe, unlike an underdrive, andi can find a set for cheap.. Link to comment Share on other sites More sharing options...
..SSR.. Posted December 7, 2005 Share Posted December 7, 2005 Ok, ignore what the engine guru says. Link to comment Share on other sites More sharing options...
CleanGSR Posted December 7, 2005 Share Posted December 7, 2005 Yeah, SSR just said they do more harm than good. That means they might do a little but not worth the risk of the harm they may do. Underdrive pullies will underdrive all of your accessories so they don't take as much power to run them. However, you have to think that Honda made those accessories to run on the power the stock pullies provide them and not less. If they could run reliably on less then I'm sure Honda would have done that. Link to comment Share on other sites More sharing options...
..SSR.. Posted December 7, 2005 Share Posted December 7, 2005 Easy solution. Remove PS and A/C belts. Link to comment Share on other sites More sharing options...
Stock Racing Posted December 8, 2005 Share Posted December 8, 2005 about the cams and cam gears, are they worth the risk? and do they need to be dyno tuned? Link to comment Share on other sites More sharing options...
CleanGSR Posted December 8, 2005 Share Posted December 8, 2005 cam(s) is/are a good upgrade. Shouldn't hurt anything. If you go with a very agressive cam you'll want to upgrade your valvetrain but you can get good cams that work with stock valvetrain. Link to comment Share on other sites More sharing options...
SexyH22 Posted December 8, 2005 Share Posted December 8, 2005 and you should get it tuned after chagning the cams. Link to comment Share on other sites More sharing options...
XScarAudio Posted December 9, 2005 Share Posted December 9, 2005 Easy solution. Remove PS and A/C belts. Its amazing the difference the AC belt makes considering the size of the AC compressor. Too bad mine was just due to laziness in replacing the belt i'll put it back on before it gets real hot again though. Link to comment Share on other sites More sharing options...
..SSR.. Posted December 9, 2005 Share Posted December 9, 2005 My A/C is coming out next week when I pull my trans. Hope the Miami heat in mid December won't kill me. Link to comment Share on other sites More sharing options...
