Kohen Posted March 21, 2011 Share Posted March 21, 2011 Hey, I'm new here. So, I have a stock d16y8. Pretty sure everything in unmolested. I've read some things about this and it seems that y8's can run VTEC? I just wanna make my SOHC VTEC. Please help me out with what I will need to make this happen. A list with everything I need to buy would be great. I know I need a head and everything but idk if I need a new harness or what if my current ECU can read VTEC Any information helps. Also how to install it would be great. If you need more information, ask and I will get back to you ASAP with my best knowledge. If there is a topic about this, please link me! Thanks for reading! And thank you very much if you give some good information ;) EDIT: I've read more and it says that my engine is VTEC.. I definitely don't feel any VTEC.. Link to comment Share on other sites More sharing options...
Raley Posted March 21, 2011 Share Posted March 21, 2011 Its not gunna be felt without exhaust... then you MIGHT feel it. Bigger cam also helps. Its 100 whp, what do you expect? Link to comment Share on other sites More sharing options...
Kohen Posted March 21, 2011 Author Share Posted March 21, 2011 Its not gunna be felt without exhaust... then you MIGHT feel it. Bigger cam also helps. Its 100 whp, what do you expect? i do have an aftermarket exhaust. 2.5" inlet to a 3.5" outlet and a test pipe soon to come along with headers (i/h/e ftw). i can hear when VTEC would crack at. but i thought it would've been more noticeable. so once i get more WHP i will notice a more significant difference? (EDIT: like i will notice when VTEC kicks in?) thanks. Link to comment Share on other sites More sharing options...
cmgogo Posted March 21, 2011 Share Posted March 21, 2011 dude it s a sohc motor, your not goin g to feel it, and your i/h/e might give you 5-10 whp. If you want more power out of your sohc you have 2 options Boost or High comp + spray. As far as noticing it... not really on stock cams, get some larger profile cams and possibly, but only with supporting modifications. Link to comment Share on other sites More sharing options...
Kohen Posted March 21, 2011 Author Share Posted March 21, 2011 dude it s a sohc motor, your not goin g to feel it, and your i/h/e might give you 5-10 whp. If you want more power out of your sohc you have 2 options Boost or High comp + spray. As far as noticing it... not really on stock cams, get some larger profile cams and possibly, but only with supporting modifications. yeah i plan on building it and eventually turbo after i do so. thanks for your help. i was just seriously confused cause everyone makes VTEC seem like the sickest thing so i just wasn't sure if i had it or not. thanks again! EDIT: what are some other supporting mods can i make? cams, pistons, cam gear and what else? Link to comment Share on other sites More sharing options...
EJ1 D16 Posted March 21, 2011 Share Posted March 21, 2011 http://www.jdmenginesamurai.com/engines/honda/jdm_engine_d16y8.htm http://en.wikipedia.org/wiki/Honda_D_engine#1.6_Litre Link to comment Share on other sites More sharing options...
Kohen Posted March 22, 2011 Author Share Posted March 22, 2011 http://www.jdmenginesamurai.com/engines/honda/jdm_engine_d16y8.htm http://en.wikipedia.org/wiki/Honda_D_engine#1.6_Litre thanks Link to comment Share on other sites More sharing options...
Xeryon Posted March 22, 2011 Share Posted March 22, 2011 nobody older then 18 that i know makes a big deal out of vtec. at this point most auto manufacturers use a licensed version of it in their cars. gm has been using it since the early 90's, almost before honda put it on the street in large numbers. with an aftermarket i/h/e you won't feel it engage but you should at least be able to hear the airflow increase through the aftermarket air filter. Link to comment Share on other sites More sharing options...
jrok Posted March 24, 2011 Share Posted March 24, 2011 On my d16z6 del sol with headers, intake , full Tsudo exhaust u can here it at like 4rpm.....its goes bwaaaaaah to BWAAAAAAAAAAAAAAAAAAH! Link to comment Share on other sites More sharing options...
Kohen Posted March 28, 2011 Author Share Posted March 28, 2011 nobody older then 18 that i know makes a big deal out of vtec. at this point most auto manufacturers use a licensed version of it in their cars. gm has been using it since the early 90's, almost before honda put it on the street in large numbers. with an aftermarket i/h/e you won't feel it engage but you should at least be able to hear the airflow increase through the aftermarket air filter. yeah i can. thanks Link to comment Share on other sites More sharing options...
Kohen Posted March 28, 2011 Author Share Posted March 28, 2011 On my d16z6 del sol with headers, intake , full Tsudo exhaust u can here it at like 4rpm.....its goes bwaaaaaah to BWAAAAAAAAAAAAAAAAAAH! VTEC usually kicks in at ~5500 on d16's but okay Link to comment Share on other sites More sharing options...
Raley Posted March 28, 2011 Share Posted March 28, 2011 And idle is above 4... Link to comment Share on other sites More sharing options...
I <3 My Ej1 Posted April 2, 2011 Share Posted April 2, 2011 On my d16z6 del sol with headers, intake , full Tsudo exhaust u can here it at like 4rpm.....its goes bwaaaaaah to BWAAAAAAAAAAAAAAAAAAH! ahahhaha Link to comment Share on other sites More sharing options...
misterspock07 Posted May 2, 2011 Share Posted May 2, 2011 i can feel my VTEC u just need to upgrade to VTAC <---- 100 hp more Link to comment Share on other sites More sharing options...
Ben. Posted May 2, 2011 Share Posted May 2, 2011 I thought Y8's were VTEC from the factory..? Link to comment Share on other sites More sharing options...
