b16a hatch Posted March 21, 2011 Share Posted March 21, 2011 does grounding all the spots with a fatter wire help the car start better i also heard it gives you alittle more hp Link to comment Share on other sites More sharing options...
DelSolSweetie Posted March 21, 2011 Share Posted March 21, 2011 cleaner contacts and possibly bigger/better wire can help the car because it'll be grounded better which provides less resistance not so much more hp Link to comment Share on other sites More sharing options...
b16a hatch Posted March 21, 2011 Author Share Posted March 21, 2011 cleaner contacts and possibly bigger/better wire can help the car because it'll be grounded better which provides less resistance not so much more hp thanks for the info man Link to comment Share on other sites More sharing options...
CuDiZoNe11 Posted April 1, 2011 Share Posted April 1, 2011 thanks for the info man she is a woman, dude lol Link to comment Share on other sites More sharing options...
b16a hatch Posted April 5, 2011 Author Share Posted April 5, 2011 she is a woman, dude lol My bad bro just use to calling everyone "man" Link to comment Share on other sites More sharing options...
cmgogo Posted April 5, 2011 Share Posted April 5, 2011 as far as your original post: Larger gauge wire to ground spots to the chassis is never a bad idea. Read up on "the Big 3" It wont necessarily give you more HP or make your car easier to start, however it will put less stress on the alternator, allow for a cleaner spark (yes, with bad enough grounds this is an issue), and help with any headlight dimming or noise in the electrical system. My best suggestion is to NOT use the wire you find for car audio systems, but rather find a local welding supply store. Most car audio wire kits are copper clad aluminum with fairly thick wires and "ok" insulation. The wire you get from welding supply stores is 99-100% copper usually, had a tougher insulation, and has finer wire strands (allowing for flexibility) and will cost 50-75% of what the amp kits cost. For terminals get solder terminals, they provide a stronger physical hold on the wire and also allow for the best conductivity (and look cleaner IMO) Link to comment Share on other sites More sharing options...
