blazeilly024 Posted February 23, 2011 Share Posted February 23, 2011 I have a bone stock 95 dx with 250k+ miles. Just a little while back it started leaking oil pretty good from the bottom of the car. After local diagnosis, problem was determined to be the oil pan gasket. So I replaced it. After completion of the pan gasket the leak all but stopped. By that I mean, I had stopped seeing drips in the driveway and the frequency of me adding oil had slowed. I decided to check the underside of the car and noticed a single drop forming on the oil pan drain plug. I cleaned it off and checked to see if it would form again while I was watchin and it didn't. The next day I checked again and there was anothr drop and so on. Over time it has gradually gotten worse to the point that it was before I replaced the gasket. I am looking for any type or form of advice that anyone can provide on this matter because I'm beginning to get extremely frustrated with it. I would greatly appreciate any input on the subject. Thanks garae Link to comment Share on other sites More sharing options...
Raley Posted February 23, 2011 Share Posted February 23, 2011 if its forming on the drain plug that means that either the crush washer or the pan surface/bolt surface are bad... id replace the crush washer next time you change the oil... Link to comment Share on other sites More sharing options...
blazeilly024 Posted February 23, 2011 Author Share Posted February 23, 2011 Hey, thanx for the reply raley. Well... I have determined so far after looking a lil bit more in depth at it that the leak is coming from the top of the oil pan or above. I have repeatedly cleaned the pan and continue to see oil marks coming from what looks to be the top of it. But when I put the new gasket on it I cleand the surface as well as I could have, even permatexed the new gasket in place to prevent movement during installation. At first no oil leak present, only after driving the car for a couple of months did I start to notice the leak had returned. Do you think the bolts could have loosened themselves up? I have not checked them since re-installation was complete. Link to comment Share on other sites More sharing options...
Raley Posted February 24, 2011 Share Posted February 24, 2011 Doubt full, its roughly 18 years old and id guess some other rubber seal is starting to go out, a very cheap fix (not perfect) but run 10w30 in the car Link to comment Share on other sites More sharing options...
blazeilly024 Posted February 24, 2011 Author Share Posted February 24, 2011 Well... I was runnin 10w30 but the valve seals in the head are startin to go out and it starts burnin real bad if I wind it out so I switched to 10w40 til I can get the head rebuilt or jus kop a new one. Been doin a lot of research on mini mees' but that still doesnt solve the leakin problem. Would like to jus yank it n rebuild the whole thing but its the only ride I got right now soo ima leave that for l8r. I'm kinda hopin it was just a bolt stripped out or somthin. I can't think of anything else. Man, I do greatly appreciate your help and info tho thanks seriously. Two heads are always better than one, and anything else you can think of would be just as great of help too. Link to comment Share on other sites More sharing options...
Raley Posted February 24, 2011 Share Posted February 24, 2011 If you shot a pic of it, i might be able to help alil more, it might be the crank breather box o ring too. If you shot a pic of it, i might be able to help alil more, it might be the crank breather box o ring too. Link to comment Share on other sites More sharing options...
blazeilly024 Posted February 24, 2011 Author Share Posted February 24, 2011 Yea, I dunno why I didn think of that. Ok I will. This crank breather box is on the back of the motor somewhere I presume. Link to comment Share on other sites More sharing options...
blazeilly024 Posted February 24, 2011 Author Share Posted February 24, 2011 Man you guys are great! Thanks for all the help. Link to comment Share on other sites More sharing options...
blazeilly024 Posted February 26, 2011 Author Share Posted February 26, 2011 Sorry, just waitin for the weather to warm up a bit so I can crawl up under an shoot some pics. Link to comment Share on other sites More sharing options...
Raley Posted February 26, 2011 Share Posted February 26, 2011 No prob, its a black box on the back of the motor. Roughly 3" x 5". Link to comment Share on other sites More sharing options...
blazeilly024 Posted February 27, 2011 Author Share Posted February 27, 2011 i was out lookin around the car today, i think i found the breather box but it appears to be right under the intake manifold and a bit difficult to get a good look at it. i destroyed my phone today so i couldnt snap any pics, but if the weather holds out ima go out tomorrow n crawl up under there n see whats goin on. will definitely keep you posted on the results. Link to comment Share on other sites More sharing options...
Trae%eh6 Posted February 27, 2011 Share Posted February 27, 2011 i would still check all your bolts from the oil pan..... my question is did you just tighting them down or did you torque them down to spec with a torque wrench Link to comment Share on other sites More sharing options...
blazeilly024 Posted March 1, 2011 Author Share Posted March 1, 2011 just tightend didnt have a tourque werench available at the time. i still havent gotten back up under there to check. Link to comment Share on other sites More sharing options...
Raley Posted March 1, 2011 Share Posted March 1, 2011 They are 10mm. Something like 12 lbs each... shouldnt have a problem with the gasket, i also put a thin layer of rtv on both metal surfaces Link to comment Share on other sites More sharing options...
blazeilly024 Posted March 14, 2011 Author Share Posted March 14, 2011 Ya, I think I'm jus gonna take it back down and re- do the whole thing. I'm startin to smell oil now when I come to a stop, so I'm guessin its gettin worse. Link to comment Share on other sites More sharing options...
blazeilly024 Posted May 2, 2011 Author Share Posted May 2, 2011 Hey does anybody know if a leaking heater core would cause the motor to run hot? Link to comment Share on other sites More sharing options...
Raley Posted May 2, 2011 Share Posted May 2, 2011 Depends how much the heater core leaks.... Link to comment Share on other sites More sharing options...
blazeilly024 Posted May 2, 2011 Author Share Posted May 2, 2011 Well... the floor up under the dash on the passenger side is pretty wet. Reason I ask is cause every once in a while the car will just start to run hot. Coolant level is ok and just replaced the thermostat and radiator water pump is still ok. I can't think of anything else to check. Link to comment Share on other sites More sharing options...
OTiS Posted May 2, 2011 Share Posted May 2, 2011 do a compression test and leakdown test to the motor. if your running hot your headgasket may be bad even tho your coolant level is fine. my old d15 wouldent smoke the white smoke, or the oil wasnt milky, and no oil in coolant but i was still losing it. started small at first, hardly noticeable tbh. may not be much help but its my .02c Link to comment Share on other sites More sharing options...
blazeilly024 Posted May 2, 2011 Author Share Posted May 2, 2011 Thanks for the reply. I actually put a new head gasket on it about 7 months ago and I just re torqued the head bolts again just to make sure. Can you think of any other reasons for it to run hot. Link to comment Share on other sites More sharing options...
OTiS Posted May 2, 2011 Share Posted May 2, 2011 has it been hot where you live? any excess load that wasnt there? running ac more? Link to comment Share on other sites More sharing options...
blazeilly024 Posted May 3, 2011 Author Share Posted May 3, 2011 Ya, it has been warming up slowly here. As for the ac, I removed that from the car this spring. My question is, if the heater core is leaking could it cause air to get in the system leaving parts of the motor un cooled. Link to comment Share on other sites More sharing options...
blazeilly024 Posted May 5, 2011 Author Share Posted May 5, 2011 Does anybody have any info on how to replace the heater core in a 95 dx? Link to comment Share on other sites More sharing options...
Raley Posted May 5, 2011 Share Posted May 5, 2011 Do you not have a manual? Link to comment Share on other sites More sharing options...
DelSolSweetie Posted May 5, 2011 Share Posted May 5, 2011 Hey does anybody know if a leaking heater core would cause the motor to run hot? yes if its soaking the floorboard you should go ahead and fix that Link to comment Share on other sites More sharing options...
