Tubbith Posted December 6, 2010 Share Posted December 6, 2010 Hey guys. Getting ready to change out the driver side CV on my 3.0CL. Was wondering if there is anything special I need to know about changing one on an automatic. Do I leave the car in park or does it need to be in neutral? Ive done 4 or 5 on previous cars but they were all 5sp. Dont want to get halfway into doin it and realize I failed to do something that was needed. Link to comment Share on other sites More sharing options...
lastresort576 Posted December 6, 2010 Share Posted December 6, 2010 I've only changed axles on my auto camry and it was pretty simple and for the most part just like my sol. maybe for the sake of lineing it up easier neutral might be better...but regardless I doubt it'll be different. Link to comment Share on other sites More sharing options...
Tubbith Posted December 7, 2010 Author Share Posted December 7, 2010 Thats what I was thinking. Guess ill just get to it and if something aint right figure it out then. Link to comment Share on other sites More sharing options...
cmgogo Posted December 7, 2010 Share Posted December 7, 2010 Park, and mark the spline reference on the shafts and on the trans case. Link to comment Share on other sites More sharing options...
Ronin1 Posted December 22, 2010 Share Posted December 22, 2010 Hey guys. Getting ready to change out the driver side CV on my 3.0CL. Was wondering if there is anything special I need to know about changing one on an automatic. Do I leave the car in park or does it need to be in neutral? Ive done 4 or 5 on previous cars but they were all 5sp. Dont want to get halfway into doin it and realize I failed to do something that was needed. I am not sure whether you are intending to service the existing CV joint or exchange the axle for one that has been overhauled. If you are going to try servicing the unit, mark things as suggested just for piece of mind and make a note of the position of things as you take it apart. If you buy a remanufactured one, it should be in balance & etc, but make sure to compare it to the unit you will turn in as a core to make sure that is is the correct one. When I changed axles on an '86 Accord automatic and a '94 Accord 5 speed things were pretty much the same, but be careful not to damage the ball joint in the lower control arm. You will need a tool to get things apart to get at the axle. If you damage the 'rubber' cover on the ball joint you will need to replace it and pack the cover with a good quality grease so that dirt, water and so on won't get in there and cause you problems with it later. You might inspect the brake pads while you are in there just to be sure that they have enough left. <div><br></div><div>P.S. make sure to put something in the hole in the transaxle where the axle/half shaft goes in so that junk does not get into it while you have the axle out.</div> Link to comment Share on other sites More sharing options...
Kohen Posted March 30, 2011 Share Posted March 30, 2011 do both while you're at it. Link to comment Share on other sites More sharing options...
