mnea Posted July 17, 2010 Share Posted July 17, 2010 Upon removing the "ATF Cooler Hoses" as directed in step 2, a dark brown fluid drained out. It was not the same color or consistency of the anti-freeze that drained from the upper and lower hoses so just kind of curious what that is and if i need to replace fluid somewhere other than the radiator with the new 50/50 anti-freeze? Link to comment Share on other sites More sharing options...
DelSolSweetie Posted July 17, 2010 Share Posted July 17, 2010 if you hadnt taken the rad. off i'd say flush the whole system because you might have some rust in there once you get the new rad. in i'd get some cleaner/flush and run it through then drain again and refill with 50/50 or whatever your preference is Link to comment Share on other sites More sharing options...
cmgogo Posted July 17, 2010 Share Posted July 17, 2010 haha sara the atf cooler is full of ATF not coolant, so its not rust you are leaking, its ATF. Link to comment Share on other sites More sharing options...
DelSolSweetie Posted July 17, 2010 Share Posted July 17, 2010 oops didnt read it really just saw brown color.. lol i'm slack at reading posts sometimes Link to comment Share on other sites More sharing options...
