gsr vs typr-r
Posted
easiest way to tell the difference between these two engines,
i got a engine matched with a tranny and the engine code just says b18c
ive read that some jdm motors dont have the last digit on them?
i believe the tranny has the LSD too soooo....
Posted
Type R is B18c5. It could be JDM, shouldn't the last owner know that? There might also be ECU codes stamped all around it. Like on my H22 the P13 ECU, the "P13" is stamped all over the place. That could tell you the motor too. For the trans, find the trans code and tell us. Should be in front and easy to access/see.
Posted
last owner was kinda of a redneck/hick/nobody that im pretty sure he might have stolen the engine (funny story behind that) , i dont have the right ecu for it so thats kinda of a lost cause.. ill try to see if i can get the tranny code for you, but i dont have it near me right now, so your gonna have to wait.
so if its jdm like i thought... would it be their version of the type-r or what?
Posted
It could....or it could be from a GSR, I dunno. And not having the ECU doesn't matter, the stamp should be over other stuff like the head of the motor and the intake manifold, among places.
Posted
JDM would be B18C. No 1 or 5. I forgot tranny code.
Posted
so from what im hearing i have a b18c that's from the jdm type-r, ruffly 195hp at the crank?
Posted
We know, but would it a GSR or Type R?
Posted
I'd assume Type R. USDM Type R at least SPECIFIES what it is.
Though Rob had a JDM Gsr motor and it had the exact same engine code..
Posted
hahaha now you know why im so confused with this... because im mostly sure that its JDM i dont really know exactly what it is... and what im really trying to find out what the compression ratio is of my exact motor... i know its still high because of it either being a gsr or type-r but im trying to find a safe amount of boost to run on it later down the road.
Posted
im not sure about the engine... but if youre trying to find out if your tranny has lsd heres an easy way to find out
lift your car up and roll the wheel with your hand... both tires should move.. or something like that.... thats how my buddy tested his out...
somewhat i cant remember how he did it exactly but ill ask
Posted
whats the intake manifold look like? is the plenum on top or below the runners..
Posted
JDM type R = red valve cover
JDM SiR-G (jdm gsr) = black valve cover
tranny codes are as follows::
GSR or SiR-G = Y80
Type R = S80
hope this helps :)
  • 3 weeks later...
