kirbydelslow Posted June 26, 2009 Share Posted June 26, 2009 So, as the topic states, I made a big whoops. I was 17 at the time, knew nothing and still know nothing. I was given lowering springs from a friend for free, he had no use for them. Apparently that caused the halfshafts to be at too extreme of an angle and that screwed them up bad. How and why did this happen? And how would I avoid this problem again? Quote Link to comment Share on other sites More sharing options...
cmgogo Posted June 26, 2009 Share Posted June 26, 2009 um.... wow, were you riding on frame? I didnt think sols could be lowered to the point of where bearing races would get scarred, but aparently i was wrong. Quote Link to comment Share on other sites More sharing options...
Humphries Posted June 26, 2009 Share Posted June 26, 2009 Your axles must have been pressed out by the negative camber. Which is weird because springs usually don't lower enough to do that. Only time I've heard of it is when you ride just struts no springs. Quote Link to comment Share on other sites More sharing options...
Xeryon Posted June 26, 2009 Share Posted June 26, 2009 billy's press out issue is a possibility. I think a very likely issue is that your shafts had worn-in at the stock angle and when you made the significant lowering that the joints were now rotating and riding on a spot that was not the original worn region. My shafts displayed a similar issue after 1k miles or so from being lowered 3in. The original shafts are of unknown age and I assume they were thousands of miles and several years old when I did it. Quote Link to comment Share on other sites More sharing options...
