vtecmang Posted June 14, 2009 Share Posted June 14, 2009 my car smiokes blue and i smell gas fumz.. what do yuh think it might be? my spark plugs are black. i changed them last month! do yuh think my car is running to rich? will i need a new p28 computer for my sohc vtec?..its a 95 engine in a 93 shell motor swap?.. Quote Link to comment Share on other sites More sharing options...
Pballer2005 Posted June 14, 2009 Share Posted June 14, 2009 ur burning oil Quote Link to comment Share on other sites More sharing options...
Xeryon Posted June 14, 2009 Share Posted June 14, 2009 If you are puffing lots of blue smoke, even when at idle, you have a major issue. Probably blew out or damaged piston rings, possibly a blown head gasket. There are a lot of things that can cause the blue genie. First off, tell us or find out if the smoke is coming from an external leak in the engine bay or if it is internal only and just coming out the tail pipe. Quote Link to comment Share on other sites More sharing options...
Speed_Freak23 Posted June 19, 2009 Share Posted June 19, 2009 my car smiokes blue and i smell gas fumz.. what do yuh think it might be? my spark plugs are black. i changed them last month! do yuh think my car is running to rich? will i need a new p28 computer for my sohc vtec?..its a 95 engine in a 93 shell motor swap?.. Your most likely burning oil, or bad head gasket. Quote Link to comment Share on other sites More sharing options...
Tubbith Posted June 19, 2009 Share Posted June 19, 2009 My guess would be either your rings are shot, or your headgasket is. Quote Link to comment Share on other sites More sharing options...
Turtlehead Posted June 19, 2009 Share Posted June 19, 2009 If you are puffing lots of blue smoke, even when at idle, you have a major issue. Probably blew out or damaged piston rings, possibly a blown head gasket. There are a lot of things that can cause the blue genie. First off, tell us or find out if the smoke is coming from an external leak in the engine bay or if it is internal only and just coming out the tail pipe. ^^^+1 Quote Link to comment Share on other sites More sharing options...
adamEj6 Posted June 24, 2009 Share Posted June 24, 2009 most likely rings. Quote Link to comment Share on other sites More sharing options...
Humphries Posted June 24, 2009 Share Posted June 24, 2009 what are fumz? Quote Link to comment Share on other sites More sharing options...
