hondatyper Posted August 11, 2003 Author Share Posted August 11, 2003 the motor has about 20,000 - 25,000 on it. keep stock pistons? and put in 1.8 rods and crank. stock or after market parts? Link to comment Share on other sites More sharing options...
..SSR.. Posted August 11, 2003 Share Posted August 11, 2003 Stock. Link to comment Share on other sites More sharing options...
hondatyper Posted August 12, 2003 Author Share Posted August 12, 2003 how much do think stock honda crank and rods cost Link to comment Share on other sites More sharing options...
..SSR.. Posted August 12, 2003 Share Posted August 12, 2003 how much do think stock honda crank and rods cost I told you several times already. You can get a B18C1 crank and rods for around $400. Link to comment Share on other sites More sharing options...
hondatyper Posted August 12, 2003 Author Share Posted August 12, 2003 400 from a honda dealer? i thought it be more than that for oem parts. Link to comment Share on other sites More sharing options...
..SSR.. Posted August 12, 2003 Share Posted August 12, 2003 400 from a honda dealer? i thought it be more than that for oem parts. No. A B18C1 crank from a dealership is around $700. You don't need to buy a new crank and rods. That is pointless. Link to comment Share on other sites More sharing options...
hondatyper Posted August 12, 2003 Author Share Posted August 12, 2003 oh ok so should i check junk yards or web sites like ebay? Link to comment Share on other sites More sharing options...
..SSR.. Posted August 12, 2003 Share Posted August 12, 2003 Here is a B18C1 crank on H-T for $200 shipped. You can pick up B18C1 rods on H-T for around $50. ($75 shipped.) Link to comment Share on other sites More sharing options...
hondatyper Posted August 12, 2003 Author Share Posted August 12, 2003 oh good crap if i hadn't spent all of my money last week than i would buy it. but i'll try to hustle it out of my parents Link to comment Share on other sites More sharing options...
gotboost? Posted September 8, 2003 Share Posted September 8, 2003 #1, dont you dare touch that block, all motor is all about hi rev and head work. full port and polish job on the head, cams, cam gears, and a whole valve job, rev that thing to 10,000 rpm, u will run a low 13 easy. a turbo on that motor will pop it in a second. Link to comment Share on other sites More sharing options...
..SSR.. Posted September 8, 2003 Share Posted September 8, 2003 #1, dont you dare touch that block, all motor is all about hi rev and head work. full port and polish job on the head, cams, cam gears, and a whole valve job, rev that thing to 10,000 rpm, u will run a low 13 easy. a turbo on that motor will pop it in a second. Dude, you're just about the dumbest person I've seen all month. 1. He need higher compression and displacment if he wants power. 2. You can't port and polish cams or cam gears. 3. His cams make plenty of power. 4. Even if he built it, he wouldn't be able to rev it to 10,000RPM for very many 1/4 mile runs before he had to rebuild it (if it even lasted). 5. If he strokes it to 1.8L, he should be able to run 12's. 6. No, it would be able to handle a bolt on kit amoutn of boost (6-8psi). 7. You Got0wn3d. Link to comment Share on other sites More sharing options...
BigBirdSucks Posted September 8, 2003 Share Posted September 8, 2003 higher compression + turbo + not built with stronger than stock parts = you're gonna blow your motor up Link to comment Share on other sites More sharing options...
..SSR.. Posted September 8, 2003 Share Posted September 8, 2003 higher compression + turbo + not built with stronger than stock parts = you're gonna blow your motor up Who would be dumb enough to raise the CR then turbo it? Link to comment Share on other sites More sharing options...
JDM Jackass2 Posted September 9, 2003 Share Posted September 9, 2003 Venom High flow fuel railVenom high flow injectors Venom fuel pressure regulator HKS circle earth grounding kit Venom intake manifold Spoon spark plugs Nology grounded plug wires Ported and polished head Spoon throttle body Toda Spec B cams Toda racing cam gears Toda racing valve springs Skunk 2 retainers Unorthadox Racing underdrive pulleys lmfao you bought spoon spark plugs.... good job paying an extra 75 bucks for NGK iridiums rice boy. LOGIC > BRAND LOYALTY!!!!! Link to comment Share on other sites More sharing options...
joecollins2 Posted September 10, 2003 Share Posted September 10, 2003 So why is it that just because people are jealous they have to talk crap??? You're name says it all man. Just so you know I really don't give two fracks what you say so you can flame away and I still don't care. Honestly I think all white trash should die, so you're opinion of me isn't worth anymore than the crap that I flushed down the toilet this morning! Link to comment Share on other sites More sharing options...
