dragonball6789 Posted May 7, 2009 Share Posted May 7, 2009 just put a new short ram intake on my 07 civic si. check engine light came on and says map sensor is running rich. it seems like the ecu should adapt from what i have heard. any ideas? Link to comment Share on other sites More sharing options...
Staninator Posted May 8, 2009 Share Posted May 8, 2009 just put a new short ram intake on my 07 civic si. check engine light came on and says map sensor is running rich. it seems like the ecu should adapt from what i have heard. any ideas? Check the wiring on the sensor and make sure it is on there correctly. That could be the only problem I can think of. I've heard of this happening before. Link to comment Share on other sites More sharing options...
siRius Posted May 9, 2009 Share Posted May 9, 2009 try unhooking your batt. for 5 min then hooking it back up should reset you ecu let your car run so the ecu can reset all the settings Link to comment Share on other sites More sharing options...
dragonball6789 Posted May 10, 2009 Author Share Posted May 10, 2009 i did unplug the battery for more than 5 min and it came back on a day later. this is really pissing me off u know Link to comment Share on other sites More sharing options...
adamEj6 Posted May 10, 2009 Share Posted May 10, 2009 run the codes then and get it fixed. Link to comment Share on other sites More sharing options...
dragonball6789 Posted May 11, 2009 Author Share Posted May 11, 2009 there is nothing wrong with the car, when i put the stock box back on it doesnt do it. so there is nothing to fix. just wondering if anyone has had this problem with an intake on an 07 si. Link to comment Share on other sites More sharing options...
adamEj6 Posted May 11, 2009 Share Posted May 11, 2009 what intake is it anyways? Link to comment Share on other sites More sharing options...
lceah Posted May 11, 2009 Share Posted May 11, 2009 hm, did you follow install directions? It shouldn't do this, but maybe something small is missing! Link to comment Share on other sites More sharing options...
siRius Posted May 12, 2009 Share Posted May 12, 2009 what brand do you have some of the generic intakes are not quiet right so they throw code from what i was told umm ill keep looking into it. Link to comment Share on other sites More sharing options...
dragonball6789 Posted May 12, 2009 Author Share Posted May 12, 2009 its i no name intake off ebay, i just ordered a k&n cold air intake so im hoping that this will fix the problem. Link to comment Share on other sites More sharing options...
Staninator Posted May 13, 2009 Share Posted May 13, 2009 its i no name intake off ebay, i just ordered a k&n cold air intake so im hoping that this will fix the problem. That should definitely help it. If you put your stock air box back on and it doesn't do it then that means that it's the intake that is screwing up. Link to comment Share on other sites More sharing options...
88prelude Posted May 13, 2009 Share Posted May 13, 2009 you probably have to get an aftermarket map considering all new cars are full of computers and you cant do anything to them or they f*ck up lol Link to comment Share on other sites More sharing options...
dragonball6789 Posted May 13, 2009 Author Share Posted May 13, 2009 so u think an aftermarket map sensor would be good. where would i look for that? u know a place that sells crap like that? Link to comment Share on other sites More sharing options...
adamEj6 Posted May 14, 2009 Share Posted May 14, 2009 dont get an aftermarket map sensor. just get an AEM intake, it will work guaranteed. Link to comment Share on other sites More sharing options...
dragonball6789 Posted May 14, 2009 Author Share Posted May 14, 2009 i already ordered an k&n cold air intake and it will be here on tuesday. aem was my next choice but i talked to the people at k&n and they said it will work fine so we will see. Link to comment Share on other sites More sharing options...
