Jekruger72 Posted June 3, 2008 Share Posted June 3, 2008 First off I did search, but this forum is kinda messy. Pretty simple. I get to around 60 mph it vibrates, kinda jitters gets worse as I go up. I was thinkin suspension bushings. I dont wanna just through money at it so what do you guys think? Also Completely different but when I brake theres like a tick tick tick comin from the rear. my dad took it to the shop before and they "fixed" it. and it came back a couple days/ weeks later. Happened a couple times. Thank you. Link to comment Share on other sites More sharing options...
BrIaN EG2 Posted June 3, 2008 Share Posted June 3, 2008 could be wheel/tire balance, bushings, tires could be spotted... those are a few things that first popped in my head... Link to comment Share on other sites More sharing options...
Jekruger72 Posted June 3, 2008 Author Share Posted June 3, 2008 Thats the second time I've heard that I'll rotate them then go from there. Any help for the breaking thing? Thank you. Link to comment Share on other sites More sharing options...
alex37211 Posted June 3, 2008 Share Posted June 3, 2008 well an obvious step would be to check the brakes back there. 1990 CRX? That's an 18 yr old car so who knows when or if the brake shoes were ever replaced. It's worth a look anyways. Link to comment Share on other sites More sharing options...
Jekruger72 Posted June 3, 2008 Author Share Posted June 3, 2008 Sorry that was my old car. need to change it. Its a 95 civic dx now, but I'll check them when I rotate the tires. Thank you. Link to comment Share on other sites More sharing options...
BrIaN EG2 Posted June 4, 2008 Share Posted June 4, 2008 No problem, just keep us posted if that doesnt work, ill keep trying to think of any other problems that i can think of Link to comment Share on other sites More sharing options...
fastbackvtech Posted June 11, 2008 Share Posted June 11, 2008 rotors Link to comment Share on other sites More sharing options...
CleanGSR Posted June 11, 2008 Share Posted June 11, 2008 I had the same vibration problem awhile back. Having the tires re-balanced fixed the problem. Pretty sure that the DX has drums in the back so I wouldn't think it was the rotors causing the brake issue. A bad alignment can also cause a little bit of vibration, but not usually as bad as tires that are improperly balanced. Link to comment Share on other sites More sharing options...
BrIaN EG2 Posted June 11, 2008 Share Posted June 11, 2008 If rotating the tires doesnt work, it could be the tires have flat spots on them (i said it in my first post but i dont think anyone picked it up) it depends on where the vibration is coming from front or rear, if its the rear it could be from FWD "drifting" the front could be from it sitting for a while and they got flat spotted that way... Link to comment Share on other sites More sharing options...
fastbackvtech Posted June 12, 2008 Share Posted June 12, 2008 pick up some falken's while your at it. Link to comment Share on other sites More sharing options...
BrIaN EG2 Posted June 12, 2008 Share Posted June 12, 2008 tires arent cheap man... not everyone can just throw around money to buy brand new tires... but if they are spotted look into getting some new tires Link to comment Share on other sites More sharing options...
Tubbith Posted June 12, 2008 Share Posted June 12, 2008 or.... just deal with the vibration...and hope you dont have a blow out that will cause to filp your car... its what i would do. Link to comment Share on other sites More sharing options...
