90IntegraC1 Posted June 14, 2007 Share Posted June 14, 2007 my buddy jumped the CEL harness and we put my car in the "on" position, then it immediately threw 3 codes. 7, 10, and 43 In no particular order, it was Throttle Angle, Intake Air Temp, and Fuel Delivery System...EFF MEEEEE So any one of those could determine why vtec isn't engaging. I want the ignition timing checked as well as valve timing if possible. I'm also going to put a knock sensor on (courtesy of EH6TunerDaniel) and try running a stock P72 or P30 ecu.... I'll let ya'll know what happens... Link to comment Share on other sites More sharing options...
compuvision02 Posted June 14, 2007 Share Posted June 14, 2007 Don't forget the non-existent code 20. The AIDS! Hopefully crap gets figured out tomorrow Dan, good luck! I hope Jose pulls through. From one Honda technician to another. And as I said, Glenn doesn't think timing is doing it at all. It might be why it shuts off, maybe, but could be from some of the other symptoms. Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted June 14, 2007 Share Posted June 14, 2007 could the throttle angle code be your tps? Link to comment Share on other sites More sharing options...
lceah Posted June 14, 2007 Share Posted June 14, 2007 good luck let us know what happens...it's strange... Link to comment Share on other sites More sharing options...
cranny Posted June 14, 2007 Share Posted June 14, 2007 TPS is throttle angle sensor. if theres no wiring issues with the car dan , its most likely the ecu dude. Link to comment Share on other sites More sharing options...
..SSR.. Posted June 18, 2007 Share Posted June 18, 2007 Check your TPS as mentioned, IAT, and all fuel stuff (pump, injector wiring(which I think would throw a code 16), test the injectors, etc). Test all the wiring. Link to comment Share on other sites More sharing options...
