Celtzer Posted May 28, 2006 Share Posted May 28, 2006 Well my Eibach Sportline Springs just came in for my 2000 Honda Civic EX. I was wondering will it look good with just the springs, or are there other things I should spend money on to make it look really professional and "clean". Thank Ya Link to comment Share on other sites More sharing options...
Celtzer Posted May 28, 2006 Author Share Posted May 28, 2006 Well I don't really know what you mean by driving it in salt, but it has 35k miles on it. Link to comment Share on other sites More sharing options...
xalexjx@yahoo.com Posted May 28, 2006 Share Posted May 28, 2006 the front shocks are cake to change, the rear can be a pain, the lower shock mount bolt can be welded in there, so best way to do it is drop the inner and outer bolt on the control arm and pull the two tops nuts out with a 14mm socket, lower control arms are a good idea if money isnt a problem, you should also consider not using the springs you bought and pay the eaxtra and get some tein's, much better qaulity imo, good luck with the lowering, let me know if you have any problems Link to comment Share on other sites More sharing options...
cranny Posted May 28, 2006 Share Posted May 28, 2006 tein are not better quality than eibach. but you should get a camber kit. and alex is right the rear wishbone bolts are FAGS!!!!lol. try and tap them out first though see if theyl come out if not dolike alex says take the spindle off no other choice. Link to comment Share on other sites More sharing options...
Celtzer Posted May 28, 2006 Author Share Posted May 28, 2006 I appreciate it guys, so a camber kit is really all I need? Camber kits are pretty expensive, i found them for the front and back for around 215... but do I really NEED them... I don't race or anything. Link to comment Share on other sites More sharing options...
Nancy Posted May 28, 2006 Share Posted May 28, 2006 camber kits are good to have if your car is low enough to where you have a negative camber. without one youll wear out the inside of your tires faster. once you have the eibachs in, take a look to see if its giving you a negative camber. i dont think its really needed unless you drop more than 1.5" or so. i used just the springs at first and didnt need one but once i put full coilvers in i had to get a camber kit. Link to comment Share on other sites More sharing options...
Celtzer Posted May 28, 2006 Author Share Posted May 28, 2006 Well darn, the springs are lowering it 1.8" and like 1.6" in the back.. or something like that. Im not really auto savy but I guess i'll get cambers wants i can afford it. Coilovers look cheap on eBay, but I have no idea what they do. Link to comment Share on other sites More sharing options...
Nancy Posted May 28, 2006 Share Posted May 28, 2006 coilovers are adjustable springs that allow you to raise or lower the car to the desired ride height. i think most coilovers let up to a 4" drop. it all depends on how much youre willing to spend. some people get a full coilover system where its the shock and coil in one. or you could buy the shocks and coilovers seperate and use them together. like using koni struts with skunk2 coilovers. + i think you would save money getting a full coilover set. but those springs youre talking about should be fine if you dont wanna drop it too low. Link to comment Share on other sites More sharing options...
Celtzer Posted May 28, 2006 Author Share Posted May 28, 2006 I really do appreciate it, I might spend money on shocks, or just not get them and get cambers, i currently don't have a job so it sux. Link to comment Share on other sites More sharing options...
xalexjx@yahoo.com Posted May 28, 2006 Share Posted May 28, 2006 o yeah, for your info dont buy coilovers on ebay if there the cheap ones, way to stiff, it will make your car bounce, expect to pay over 150 for decent coilovers, Link to comment Share on other sites More sharing options...
Celtzer Posted May 29, 2006 Author Share Posted May 29, 2006 o yeah, for your info dont buy coilovers on ebay if there the cheap ones, way to stiff, it will make your car bounce, expect to pay over 150 for decent coilovers, the springs themselves ran me over 200, i don't see why coilovers aren't as much or much more then springs. Link to comment Share on other sites More sharing options...
Nancy Posted May 29, 2006 Share Posted May 29, 2006 probably about 250 for just the coilovers. eibach is good stuff, still a little too much just for springs imo. Link to comment Share on other sites More sharing options...
90IntegraC1 Posted May 29, 2006 Share Posted May 29, 2006 yo man eibach springs are great, just install them (rear springs are a bitch), get this camber kit--->Click ME and you'll be good... o yeah, and when your done, you should totally buy one of these--->Hott Shytttt good luck. Link to comment Share on other sites More sharing options...
Celtzer Posted May 29, 2006 Author Share Posted May 29, 2006 haha, i don't know about the engine.. but ty on the camber kit... but i noticed it was only for the front.. wouldn't i need them on the back too? Link to comment Share on other sites More sharing options...
xalexjx@yahoo.com Posted May 29, 2006 Share Posted May 29, 2006 http://www.robearracing.com/pd_omni_power_rear.cfm Link to comment Share on other sites More sharing options...
cranny Posted May 29, 2006 Share Posted May 29, 2006 on the back you can add a washer or 2 in between the chassis and the camber arm , will correct it. Link to comment Share on other sites More sharing options...
xalexjx@yahoo.com Posted May 29, 2006 Share Posted May 29, 2006 on the back you can add a washer or 2 in between the chassis and the camber arm , will correct it. good idea, never thought of that Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted May 29, 2006 Share Posted May 29, 2006 The rear camber isnt really thrown off that much with the drop, mine was fine. That was an expensive front camber kit, I would look for something else. Tein are good springs, I have them, my buddy has them on his s13, I havent ever heard anyone say anything bad about them. If you just want to drop it you can get by with just getting the springs. Link to comment Share on other sites More sharing options...
