Ballinfrogs Posted April 14, 2006 Share Posted April 14, 2006 Alright I understand the last numbers but can anyone explain to me the first one. I looked online and got an explanation. but didint really understand it. Can anyone explain the whole thing to me in stupid terms please? Link to comment Share on other sites More sharing options...
SolLesHonda Posted April 14, 2006 Share Posted April 14, 2006 The first number = the width of the tire in mm The second number = the percentage of the width, which is how tall the sidewall is. The third number = the size of the wheel. Link to comment Share on other sites More sharing options...
Ballinfrogs Posted April 14, 2006 Author Share Posted April 14, 2006 so if I have a low second number and a high first number, that will give me the lowest profile? Link to comment Share on other sites More sharing options...
TLontheDL Posted April 14, 2006 Share Posted April 14, 2006 bingo Link to comment Share on other sites More sharing options...
Ballinfrogs Posted April 14, 2006 Author Share Posted April 14, 2006 so then whats the difference in a 205/40/17 and a 215/45/17? both the numbers go up. Link to comment Share on other sites More sharing options...
mountaindewguy Posted April 14, 2006 Share Posted April 14, 2006 the 215/45 is a wider and taller sidewall tire. the 205/40 is not quite as wide, and a more lower profile. Link to comment Share on other sites More sharing options...
Ballinfrogs Posted April 14, 2006 Author Share Posted April 14, 2006 so what would look better then? isnt wider worse? or is it width from beind so it would look cooler? Link to comment Share on other sites More sharing options...
mountaindewguy Posted April 14, 2006 Share Posted April 14, 2006 what vehicle is it on? personally, if its a civic, and its lowered, and you HAVN'T bought the rims yet, get 16's. they still look great but wont get as bumpy of a ride. Link to comment Share on other sites More sharing options...
Ballinfrogs Posted April 14, 2006 Author Share Posted April 14, 2006 95 honda prelude, i think im going with these http://cgi.ebay.com/ebaymotors/ws/eBayISAP...TRK%3AMEWA%3AIT questions comments? hints? i think theyll look tight caus emy cars white but with the black tints its gonna be nice. Link to comment Share on other sites More sharing options...
Pyrorocketeer Posted April 14, 2006 Share Posted April 14, 2006 the wider the tire is obviously the larger contact patch you have with the road. so the more grip you have. the higher the sidewall the tires want to "roll" (left or right) around the rim, and not with the rim. lower profile tires help prevent that, as do stiffer side walls. also there is a limit on how wide you can go and still be benificial like in autocross racing. they know that there is only a certain ammount of tire they can heat up while going around the turns. to wide of tire means they won't get to optimum temp, and provide less traction than say a smaller tire that can reach optimum temp. So there is a healthy medium one needs to reach. Link to comment Share on other sites More sharing options...
cranny Posted April 14, 2006 Share Posted April 14, 2006 so then whats the difference in a 205/40/17 and a 215/45/17? both the numbers go up. both nombers dont go up together but if you change one of the dimensions the other changes as well. so if you have 205/40/17's , and you want to put a wider tire on it , and decide to go with a 215/40/17 , than because you have increased width by 1 cm(first # is width in millimeters) , that means your profile(second number , which is 40% of the width from the rim to the road) will also increase even though same number on tire. this is cause its 40% of whatever the width is. but if you change middle number only than width stays same but sidewalls curl towards tread the higher profile you go. low profiles have straight sidewalls for the most part. last number is like solles said , rim size or diameter. Link to comment Share on other sites More sharing options...
CleanGSR Posted April 14, 2006 Share Posted April 14, 2006 I was about to type something about the same when I saw your post cranny. Good post. Changing the first number will change the side of the sidewall too. So as stated a way's above, A high first number and low second number will not give the lowest profile. A smaller first number and a smaller second number will give the smallest profile. Link to comment Share on other sites More sharing options...
TS John Posted April 14, 2006 Share Posted April 14, 2006 Well, there's really nothing more to be said about that. Link to comment Share on other sites More sharing options...
Ballinfrogs Posted April 15, 2006 Author Share Posted April 15, 2006 Well, there's really nothing more to be said about that. forest gump quote? Link to comment Share on other sites More sharing options...
TS John Posted April 15, 2006 Share Posted April 15, 2006 Actually, I meant that with all seriousness. That's a little scary... Link to comment Share on other sites More sharing options...
SolLesHonda Posted April 15, 2006 Share Posted April 15, 2006 That isn't even what Forrest Gump said buddy, so nice try. "That's all I've got to say about that" .. is what he said. Topic covered. Lock ... Link to comment Share on other sites More sharing options...
Ballinfrogs Posted April 16, 2006 Author Share Posted April 16, 2006 i am ashamed... Link to comment Share on other sites More sharing options...
