onthefloor Posted March 17, 2006 Share Posted March 17, 2006 Anyone know about how much it will cost to paint my grill red? Link to comment Share on other sites More sharing options...
CleanGSR Posted March 17, 2006 Share Posted March 17, 2006 You can order paint for your car from paintscratch.com and do it yourself. Just prep everything really well. Are you talking about the upper grill?...cause I think the lower one looks good black. Link to comment Share on other sites More sharing options...
SolLesHonda Posted March 17, 2006 Share Posted March 17, 2006 I think you should leave it. Which one are you talking about. It looks good like that. Link to comment Share on other sites More sharing options...
CleanGSR Posted March 17, 2006 Share Posted March 17, 2006 I'd paint the upper one to match. You can get exact matching paint at paintscratch.com and from results of people that have used it, it's pretty good quality too. Link to comment Share on other sites More sharing options...
xxscaxx Posted March 17, 2006 Share Posted March 17, 2006 I'd paint the upper one to match. You can get exact matching paint at paintscratch.com and from results of people that have used it, it's pretty good quality too. i agree. paint the top one, leave the bottom. Link to comment Share on other sites More sharing options...
onthefloor Posted March 17, 2006 Author Share Posted March 17, 2006 Im talking about the top grill. Im a newbee at painting U think i can still do it by myself? ALright im on the site now.... 1st off which of these do i need? Tricoat Clearcoat Primer? Or all 3? 2nd of all how much doo i need? 1/2 oz 1oz or 2 oz?? Link to comment Share on other sites More sharing options...
CleanGSR Posted March 18, 2006 Share Posted March 18, 2006 Is your car milano red? If so don't paint it yourself cause there's a midcoat that will be hard to make even. If not, then you'll want a primer, basecoat, clearcoat. Just make sure to sand with about 600 or 800 grit, then put 2 or 3 coats of primer and then do a bunch of really light coats of paint. It should take about 3 coats to fully cover it because you want to put on really light coats, otherwise it will run and fisheye. Then do about 2 or 3 coats of clearcoat. Leave about 10 minutes between each coat. Then let it sit overnight and install the next day. It's really not that hard. Link to comment Share on other sites More sharing options...
onthefloor Posted March 19, 2006 Author Share Posted March 19, 2006 Sounds good thxs!! Link to comment Share on other sites More sharing options...
rob669 Posted March 19, 2006 Share Posted March 19, 2006 you should leave it the way it is, it looks good the way it is. Link to comment Share on other sites More sharing options...
xxscaxx Posted March 19, 2006 Share Posted March 19, 2006 it would look better if the outer part was painted red and the inside grill piece stayed black. i didnt see how your mirrors are black. Link to comment Share on other sites More sharing options...
rob669 Posted March 20, 2006 Share Posted March 20, 2006 damn your right that would look sick, to bad. Link to comment Share on other sites More sharing options...
cranny Posted March 20, 2006 Share Posted March 20, 2006 get a scotchbright pad and scuff where you want to paint than tape off where you dont want to. and spray away. dont get runs and dont put too little paint on it. you want it to dry in a hot dry place. moisture will make paint flash off or dull , so will cold. Link to comment Share on other sites More sharing options...
CleanGSR Posted March 20, 2006 Share Posted March 20, 2006 Just to clarify Cranny. Don't put to little on in general, but spray it really light for each coat. The key is higher quantity lighter coats rather than fewer heavy coats. Scotch Brite pad will work to scuff the surface to, just make sure to clean it with alcohol before you start spraying to get all the dust off from sanding. Link to comment Share on other sites More sharing options...
SexyH22 Posted March 20, 2006 Share Posted March 20, 2006 i think it looks nice black. i vote leave it Link to comment Share on other sites More sharing options...
babykansas04 Posted March 23, 2006 Share Posted March 23, 2006 me too i think u should leave it..... it'll be too much red if u paint it Link to comment Share on other sites More sharing options...
cranny Posted March 23, 2006 Share Posted March 23, 2006 i need no painting tips son , but thanks. ive ground up restored cars. my last car i restored actually frame off ground up was a 68 camara SS. wanna see pics? shouldnt say frome off cause it is a unit body car but , lol , thats the saying. i dont know what kind of paint your talkin about but go ahead and put heavy coats on see what happens. acrylic maybe. Link to comment Share on other sites More sharing options...
CleanGSR Posted March 23, 2006 Share Posted March 23, 2006 If he paints it, it will blend in with the rest of the body and be more sleek. It will stand out a lot less than the way it is now. Less gaudy is better IMO. Link to comment Share on other sites More sharing options...
cranny Posted March 23, 2006 Share Posted March 23, 2006 i agree. paint it black dude for sure. you want a little bit of contrast , paint it flat black than but do a good job. but not red too clashy. Link to comment Share on other sites More sharing options...
blackdelsol Posted March 24, 2006 Share Posted March 24, 2006 you wanna paint your grill? Link to comment Share on other sites More sharing options...
onthefloor Posted March 24, 2006 Author Share Posted March 24, 2006 Haha ill keep that one in mind.... Link to comment Share on other sites More sharing options...
