mike32526 Posted January 25, 2006 Share Posted January 25, 2006 Any Ideas on how to loosen the 19mm bolt on the crank pulley (1997 Prelude)? I have tried an Impact (@240fl lbs torqe) and broken a few extensions using a "cheater" pipe. I am changing the timing belt and H2O pump. Thansk.... Link to comment Share on other sites More sharing options...
CleanGSR Posted January 25, 2006 Share Posted January 25, 2006 Get some p buster. I think that's what it's called. P buster, or P breaker....something like that. You can get it at walmart, and unless the bolt is fused, it will help a lot at loosening it up. Link to comment Share on other sites More sharing options...
AMERICANMUSCLE Posted January 30, 2006 Share Posted January 30, 2006 go get a breaker bar, wd-40 and a 1" wide piece of steal tube and some one that has some lead in there pencil Link to comment Share on other sites More sharing options...
cranny Posted January 30, 2006 Share Posted January 30, 2006 gotta use heat dude its the only way. Get access to a torch and heat the bastard up red , ittl come out. strap wrench on the pulley to keep it from turning helps too if you havent been usin one.And for the record , if you plan on keepin car(should be normal practise anyway) put antiseize on it before reinstalling , makes life in the future easier. Link to comment Share on other sites More sharing options...
xalexjx@yahoo.com Posted January 31, 2006 Share Posted January 31, 2006 load it up with zep 45 or wd 40 and let it soak...also dont heat it up totaly red as you may cause cracks on the mount Link to comment Share on other sites More sharing options...
..SSR.. Posted January 31, 2006 Share Posted January 31, 2006 Put car in gear. Have someone stand on the brakes. 1/2" breaker bar with 3' iron pipe. For the extension use an impact extension. Easy. Link to comment Share on other sites More sharing options...
cranny Posted January 31, 2006 Share Posted January 31, 2006 honest to god SSR i used to do this as well but i was told at honda actually that this can harm the crank is this not the case? Link to comment Share on other sites More sharing options...
mountaindewguy Posted January 31, 2006 Share Posted January 31, 2006 not if you do it just once and put the antiseize like said earlier and you wont have to do it again Link to comment Share on other sites More sharing options...
