ALLTHROTTLE/Noboost/Nobottle Posted November 25, 2003 Share Posted November 25, 2003 I have a 1990 Crx and im trying to decide what types of brakes to get i was thinking about this brake kit from FASTBRAKES.COM which includes cross-drilled and slotted rotors new brakelines (stainless steel), oem calipers that are rebuilt, and axxis brake pads for 565.00. if anyone has anything that is around the price range of 100-800 dollars and is better or if u just have an opinion on it reply please. Link to comment Share on other sites More sharing options...
..SSR.. Posted November 25, 2003 Share Posted November 25, 2003 Fastbrakes rock. Don't change your font and everything when posting, thats annoying as hell. Link to comment Share on other sites More sharing options...
TLontheDL Posted November 26, 2003 Share Posted November 26, 2003 im riding on axxis metal masters right now and the stopping power on those guys are great! the only downside is that it gives off break dust like a bitch so if you have aftermarket wheels, you'll have to clean them often. Link to comment Share on other sites More sharing options...
b18crx Posted December 4, 2003 Share Posted December 4, 2003 powerslot rotors are good. drilled rotors are known to crack. i have a custom brake set up on my rex Link to comment Share on other sites More sharing options...
TLontheDL Posted December 4, 2003 Share Posted December 4, 2003 what are power slots and what are drilled? don't they both have holes in them? ive seen some that have holes in them as well as um...whatchamacallit...diagonal slits to relieve friction? i think the diagonal slits help reduce temp. the holes are to relieve the brake dust..that i know Link to comment Share on other sites More sharing options...
b18crx Posted December 4, 2003 Share Posted December 4, 2003 i have the slotted ones the cross-drilled crack inbetween the drilled point alien Link to comment Share on other sites More sharing options...
optional187 Posted December 4, 2003 Share Posted December 4, 2003 mark: the diagonal slits are slotted rotors. the let gas and heat escape from inbetween the pad and rotor. the ones with holes are drilled, which basically do the same thing...they even make rotors that are both slotted and cross drilled. my parents harleys have cross drilled rotors on them...they look awesome because of all the chrome. Link to comment Share on other sites More sharing options...
TLontheDL Posted December 4, 2003 Share Posted December 4, 2003 well, i already know what the holes function as. i just didnt know the slits do the same. but how can it relieve brake dust if its just slits and not a slit that is cut through the whole rotor?? its like a slit that goes half way down through the rotor. plus, i thought the slits help reduce friction. wouldn't you WANT friction btw the pads and the rotors in order for it to come to a halt? Link to comment Share on other sites More sharing options...
..SSR.. Posted December 4, 2003 Share Posted December 4, 2003 Get non drilled or slotted rotors. Get good brake pads and make some brake cooling ducts for the front. If you make the brake cooling pads, make sure you make the ducts go to the bottom of the rotor on the backside of the rotor. Link to comment Share on other sites More sharing options...
optional187 Posted December 5, 2003 Share Posted December 5, 2003 the slot's aren't for brake dust, they're to get rid of excess heat and to let the gases that build up between the pad and rotor to escape so that you get more surface area of the pad on the rotor to shorten your stopping distance. Link to comment Share on other sites More sharing options...
JDM Jackass2 Posted December 6, 2003 Share Posted December 6, 2003 i like OEM brakes. CTR 5 lug with NSX calipers is what i plan on doing eventually... fastbrakes/wilwood would be my next choice. by the way, cross drilled and/or slotted rotors suck ass. lets see here: less surface area, and prone to cracking. sign me up! yeah... fuk that. Link to comment Share on other sites More sharing options...
EGRacer Posted December 7, 2003 Share Posted December 7, 2003 brembo slotted rotors all around with axxis ultimate ceramic pads. thats what im running Link to comment Share on other sites More sharing options...
jew4u2nv Posted December 23, 2003 Share Posted December 23, 2003 im also looking for better brakes. right now i have the stock si hubs/brakes. need to be bigger. oh yeah .... JDM Jackass2by the way, cross drilled and/or slotted rotors suck ass. lets see here: less surface area, and prone to cracking. sign me up! yeah... fuk that. i guess all those touring cars/ rally cars/ nascars should just quit using them ? ....0wn3d. Link to comment Share on other sites More sharing options...
optional187 Posted December 23, 2003 Share Posted December 23, 2003 racing cars use huge diameter disc brakes, the huge diameter makes up for the loss in surface area. slotted rotors for your car come in stock diameter, therefore they don't make up in loss of surface area. ...OwN3D. nobody will ever own jdmjackass2, its near impossible. Link to comment Share on other sites More sharing options...
EGRacer Posted December 23, 2003 Share Posted December 23, 2003 i can i can. lol i probably could if i tried but i enjoy his commentary so i let him be. anyways my drilled and slotted rotors dont loose any surface area because they are about 1" bigger overall. they are great rotors but a bitch to break in Link to comment Share on other sites More sharing options...
optional187 Posted December 23, 2003 Share Posted December 23, 2003 i'm probably going to be getting powerslots or brembo slotted rotors for my car in a month or so...i already warped the stock ones braking down from 135. Link to comment Share on other sites More sharing options...
jew4u2nv Posted December 24, 2003 Share Posted December 24, 2003 < this crx'r got owned. willing to admit it. < has power slotted rotors on celica, sounds good to tell people though. Link to comment Share on other sites More sharing options...
