97CIVICHATCHDX Posted August 13, 2012 Share Posted August 13, 2012 Does anyone know what ecu the jdm d15b is suppose to have? Vtec doesn't feel like its kicking in at all. Im going to check tomorrow and see which ecu is in the car, but just wanted to see if anyone knew which ecu it was. Link to comment Share on other sites More sharing options...
Xeryon Posted August 13, 2012 Share Posted August 13, 2012 With 130hp you won't ever feel vtec kick in. This isn't F&F. With an aftermarket intake or exhaust you might hear it though. It should be a p28 or p2p. Both of which are the american counterpart that run a d15b just fine. Link to comment Share on other sites More sharing options...
97CIVICHATCHDX Posted August 13, 2012 Author Share Posted August 13, 2012 Thanks zeryon you have been alot of help. Im going to check on this during lunch and see if the correct ecu is in the car. Link to comment Share on other sites More sharing options...
97CIVICHATCHDX Posted August 14, 2012 Author Share Posted August 14, 2012 Found out mine has the p2p ecu. I have read that other people having issues with getting up to speed at low rpm"s and beginning of each gear. I have read that the p28 ecu is the way to go and to also get the p08 maps put on it. Inless you can find a p08 ecu but heard those are hard to find. The p28 ecu seems to react better at the low rpm's and beginning of each gear. Let me know if im wrong Link to comment Share on other sites More sharing options...
Xeryon Posted August 14, 2012 Share Posted August 14, 2012 If I am reading this correctly you need to make sure to get an OBD2 p28. It looks like there was both OBD1 and OBD2 versions....? Link to comment Share on other sites More sharing options...
97CIVICHATCHDX Posted August 14, 2012 Author Share Posted August 14, 2012 obd2 p28 ok sounds good xeryon, Do you know the price range of what they might be? Link to comment Share on other sites More sharing options...
Xeryon Posted August 14, 2012 Share Posted August 14, 2012 beats me, ebay indicates maybe $200 or so. most of the ones on eBay are obd1 with a conversion harness. Swaps and ecus are beyond my sphere of experience though. My realm is more in the stock category. Link to comment Share on other sites More sharing options...
97CIVICHATCHDX Posted August 14, 2012 Author Share Posted August 14, 2012 Oh okay, thanks for everything thou, much appreciated Link to comment Share on other sites More sharing options...
Draytech Performance Posted August 28, 2012 Share Posted August 28, 2012 the po8 base map is the way to go with jdm d15bvtec 130hp, with the d16zc vtec you want to use the p28. 125 hp- 127hp. The Jdm d15b will destroy all other single vtec motors and even some b-series motors with a good tune on your d15bvtec. i should know because my bone stock d15b vtec with a little tune made 120 Bhp and 101 ft lbs torque at the wheels. Which means 140hp to the fly wheel. Link to comment Share on other sites More sharing options...
97CIVICHATCHDX Posted August 29, 2012 Author Share Posted August 29, 2012 Nice to know draytech, I may be asking you some more questions then. It seems my car can pick speed up pretty quick in 2nd and 3rd but at the start of first gear its like you have to kind of ride the clutch at 2000-2500 rpm just to get it to move a little quicker, Im not really sure how to explain it. But it Just seems sluggish in first gear. Link to comment Share on other sites More sharing options...
Draytech Performance Posted August 30, 2012 Share Posted August 30, 2012 did u change throttle body or gasket? or u need a new dizzy Link to comment Share on other sites More sharing options...
Draytech Performance Posted August 30, 2012 Share Posted August 30, 2012 if u still need a ecu obd1. then obd2 to obd1 jumper for your car i know a good seller cheap and u get a base map for that bad ass d15b vtec d16z6 7200 rpm d15b 7500 rpm Link to comment Share on other sites More sharing options...
97CIVICHATCHDX Posted August 31, 2012 Author Share Posted August 31, 2012 I AM IN NEED OF AN ECU AND MAPPING DOWN IF YOU KNOW SOMEONE THAT HAS ONE AND CAN DO THEM JUST LET ME KNOW. AND WHATS A NEW DIZZY?? AND I HAVENT CHANGED THROTTLE BODY OR GASKET Link to comment Share on other sites More sharing options...
Draytech Performance Posted August 31, 2012 Share Posted August 31, 2012 a distributor. check plogs and wire. for the ecu do u have ebay or paypal? plugs and wire Link to comment Share on other sites More sharing options...
94camocivic Posted August 31, 2012 Share Posted August 31, 2012 if your looking for a p28 go on craigslist they are like 50 bucks if you cant find one let me know i know some one Link to comment Share on other sites More sharing options...
97CIVICHATCHDX Posted September 1, 2012 Author Share Posted September 1, 2012 i put new ngk spark plugs in. maybe i need to check dist. and maybe do a cap and rotor then. ive checked around on craigslist but always a few hours away. i do have ebay and also just signed up for a pay pal account Link to comment Share on other sites More sharing options...
