auto trimmer Posted December 23, 2011 Share Posted December 23, 2011 Hello to all. I'm a new member here looking for some help. has anyone removed a dash from a del sol. I have a 94 del sol and have found a 97 del sol with good dash. are both compatible and what is needed to remove dash. any help is appriciated. Link to comment Share on other sites More sharing options...
Raley Posted December 23, 2011 Share Posted December 23, 2011 10mm, 12mm, 14mm and screw drivers. Once im on a comp ill say how. Link to comment Share on other sites More sharing options...
auto trimmer Posted December 23, 2011 Author Share Posted December 23, 2011 thanks. i figure I can remove dash, just need to know procedure to eliminate mistakes. also my car is a 94 model. will changing targa seals from 97 model help with leaks. I read that honda recalled and updated seals with newer model seals. David Link to comment Share on other sites More sharing options...
Raley Posted December 24, 2011 Share Posted December 24, 2011 93 and some 94s had seal recalls, look at the seals on the car above the visors, id thers little nipples, its a newer seal. It could fix leaks, but the new ones might be just as bad. Also you might need to adjust the targa for a solid seal. Link to comment Share on other sites More sharing options...
Raley Posted December 24, 2011 Share Posted December 24, 2011 ok, start by removing the center console (you gotta pull the shift knob, 2 screws up front, 2 in back) next pull the panel below the steering wheel (i think its only 2 screws, may be 3), next pull the glove box, open it and on each side there is little stops, rotate those and drop the glove box all the way down, there is a screw at each hinge (can be gotten to with the glovebox closed. now, there is a bolt on each outside of the dash, 1 in the top center, then remove the 2 bolts that you made appear. (one on the outside of where the glovebox sat, and one on the outside above the clutch pedal.) finally there is a few bolts under where the center console was. that is all the hardware removed. then is the wiring, those seem to change locations every time someone plays with a dash, so i can't give you great dirrection on that. if you drop the steeringwheel down, the dash will slide right out. Link to comment Share on other sites More sharing options...
auto trimmer Posted December 24, 2011 Author Share Posted December 24, 2011 thanks alot for the info. I plan on removing the dash next weekend. also I'm looking for a passenger seat outside rail. my passenger seat wont recline. if anyone has a lead, much appriciated. David Link to comment Share on other sites More sharing options...
Raley Posted December 24, 2011 Share Posted December 24, 2011 You need a new seat. The reclining thing is a simple mechanizum, you might be able to clean it. Link to comment Share on other sites More sharing options...
auto trimmer Posted December 24, 2011 Author Share Posted December 24, 2011 thanks for all info. I have added washers for locks on targa top. I haven't adjusted the targa top itself yet. also I plan to add foam to targa. this way I can make a design on targa panel. give it a unique finish. also the seats will be recovered. tip for others. you can steam the old covers to remove fabric from frames. leaves bare foam.then you can repair foam,s. such as driver bolster( driver back). I have installed leather covers on these cars , when they were new cars. David Link to comment Share on other sites More sharing options...
Raley Posted December 24, 2011 Share Posted December 24, 2011 I have a spare pass seat cover that i was planning to use to make a pattern with. But ive never fixed foam, do you have any hints to fix that? Link to comment Share on other sites More sharing options...
auto trimmer Posted December 25, 2011 Author Share Posted December 25, 2011 fixing foam is not hard. you first need to remove any loose foam in area. then you will need a piece of foam ( fabric supply store) . you take the foam and cut to size of damaged area. make sure that the foam has density. you need the piece to be some what larger than damaged area. you will then spray adhesive to damaged area and new foam. let dry till glue is somewhat tacky.give 5 or so minutes.you will then place new foam in damaged area. slowly work into damaged area. the trick is to have foam placed inside area and fit like original piece. by being larger than damaged area. the foam should not collapse and leave firm filled area. . next you use sew foam. this is foam that is usually 1 inch thick. this is the foam used for seat covers. you will need to cut a piece of sew foam as large as front of seat (back rest). the purpose is to glue sew foam to back rest and pad damaged area. this will leave a smooth , comfortable area. after applying glue and fixing sew foam to back rest. the sew foam needs to be trimmed . look at the seat and determine where the original seams for cover are located. to do this. look at oppsite seat and find where cloth and vinyl meet on cover.after you have area cut to where cover seams are located. you will need to take a razor blade and edges need to be cut at angle . you want a beveled edge of sew foam at where seams of cover meet. I hope I haven't confused you. if you have any more questions about process. ask away. also after reading how to remove dash. I going to recover dash too. all it will take is time ,glue, vinyl , steamer and stretching pliers. I almost forgot this . if you can get a steamer for clothes or iron that puts out alot of steam. steam the damaged area of foam . this will make foam rise to original shape. do this before you repair damaged area. wal-mart has cheap versions. you could buy one , use it and return to wal-mart. tell them you weren't happy. any other questions fire away. David Link to comment Share on other sites More sharing options...
Raley Posted December 25, 2011 Share Posted December 25, 2011 Sounds easy enough, as long as joann fabric can find it. Link to comment Share on other sites More sharing options...
auto trimmer Posted December 25, 2011 Author Share Posted December 25, 2011 before you try joann fabrics. try to locate a upholstery fabric store. this will be the place trimmers purchase goods. they will be more knowledgable. joann is for more crafts and lighter used goods. plus the staff is not knowledgable about auto trim needs. i know this from experience. also give ebay a chance.type upholstery foam. you can also use 1/2 inch sew pleating foam for outside wrap. also they have blocks that can be cut to size. use a large kitchen knife to contour shape of foam block. also 3 m spray glue will work for you. David Link to comment Share on other sites More sharing options...
Raley Posted December 25, 2011 Share Posted December 25, 2011 Sweet, the one uphostry shop in town is now closed so ill probably have to use ebay, Id really like to useneoprene for the material but its so expensive Link to comment Share on other sites More sharing options...
auto trimmer Posted December 25, 2011 Author Share Posted December 25, 2011 remember your are just trying to replicate original look. dont waste money on neoprene. soon i will do same thing to my driver seat. also I will add felt to bottom cushion.this will go under foam to lift off bottom frame. this will make bottom cushion more firm. try to do this cost effective. if you take to trim shop, they will do same method. if you have any more ?'s fire away. David Link to comment Share on other sites More sharing options...
auto trimmer Posted December 30, 2011 Author Share Posted December 30, 2011 went to look at car with newer seals. seals were crap. dash was perfect. I have changed my mind on covering dash. also got fender for 50.00. bought some dielectric grease to condition seals. also changed torx screws that hold visor assembly. those screws are made of soft metal. went to home depot and purchased socket cap screws( allen head screws). this will stop loose visor assembly. if anyone else has problem. look for socket cap screws M5-.8x16mm. next i will adjust targa top. thanks again Raley for help. Link to comment Share on other sites More sharing options...
Raley Posted December 31, 2011 Share Posted December 31, 2011 No prob. Keep us updated on the progress. Link to comment Share on other sites More sharing options...
cmgogo Posted December 31, 2011 Share Posted December 31, 2011 ive tried the dielectric grease before it works okay, but the best shit ive used has been the actual shinetsu grease (you can get it form the stealership for an arm and a leg, or get it on ebay for about $10) Link to comment Share on other sites More sharing options...
auto trimmer Posted January 1, 2012 Author Share Posted January 1, 2012 thanks man. purchased a tube off ebay last night. Link to comment Share on other sites More sharing options...
auto trimmer Posted January 1, 2012 Author Share Posted January 1, 2012 ? what do you about vin # pop rivets in dash swap. do I need to find black pop rivets? never swapped a dash and what is legal. Link to comment Share on other sites More sharing options...
Raley Posted January 2, 2012 Share Posted January 2, 2012 Mines bolted in and ive had a cop question it, but i just popped the hood and showed it to him on the firewall and he was fine. Link to comment Share on other sites More sharing options...
auto trimmer Posted January 14, 2012 Author Share Posted January 14, 2012 well i have the dash removed. I had a problem. I didn't anticipate the dash dropping so fast. I now have a small nick in dash. now I'm disassembling the dash to cover. I'm only having one issue. the plastic piece with vin # will not seperate from dash. I have the front seperated,but rear plastic piece is tight. dont wont to crack rear piece. are the pieces hot glued or plastic welded together. this is my last hurdle. I plan on stripping vinyl and padding. I now have steamer and this will make job easy. has anyone seperated these two pieces ? Link to comment Share on other sites More sharing options...
Raley Posted January 14, 2012 Share Posted January 14, 2012 i have not, and im having a hard time invisioning what you are talking about... usually in automotive they will be heat staked together... its kinda like a plastic pop rivet. Link to comment Share on other sites More sharing options...
auto trimmer Posted January 15, 2012 Author Share Posted January 15, 2012 i decided now to repair hole. I was informed that the parts don't seperate. thanks Link to comment Share on other sites More sharing options...
auto trimmer Posted January 16, 2012 Author Share Posted January 16, 2012 it was a epoxy that held the dash cap in place. you have to use something to pry from bottom of dash. I now have the dash pad stripped of vinyl. now the fun part . recovering. Link to comment Share on other sites More sharing options...
