OTiS Posted May 31, 2011 Share Posted May 31, 2011 as iv stated many times before i have rust eaten rocker panels. its on the part that connects the sideskirt and goes all the way back to the beginning of the rear wheel well. does anybody know a place that sells those parts cheap? or would any other civic rocker panel fit with little to no modding? majestic only has one side for 115 i beleve Link to comment Share on other sites More sharing options...
Xeryon Posted May 31, 2011 Share Posted May 31, 2011 Since it is a part you will never see you can just make your own. Take some sheet, bend it at the appropriate spots into the correct "U" shape, weld it on, mark and drill the attachment spots for the skirt to lock into. Link to comment Share on other sites More sharing options...
Raley Posted June 1, 2011 Share Posted June 1, 2011 Cut out old, then weld in new. Use 20ga or 18 ga Link to comment Share on other sites More sharing options...
OTiS Posted June 1, 2011 Author Share Posted June 1, 2011 idk if i can bend it myself. never worked with sheetmetal before. heres some pics of how bad it is. these are from inside the trunk, near the taillight, behind the bumper cover Link to comment Share on other sites More sharing options...
Xeryon Posted June 1, 2011 Share Posted June 1, 2011 buy some rust repair panels, that covers the wheel arch and some of your under-door rail. you will need to pull the lower side skirt to see the full extent of the damage but the part under the skirt is where you just fab up the replacement. rust repair isn't an exact science, it's part art and part sweat and a whole lot of 'looks good enough' (when it comes to a DD) I hate to send you elsewhere, but there are several excellent how-to guides written at d-series.org with butt-loads of pics, materials lists and step by step instructions. Link to comment Share on other sites More sharing options...
OTiS Posted June 1, 2011 Author Share Posted June 1, 2011 noob question but what do you mean by rust repair panels? like from www.fixmyrust.com? i actually saw a how to on d-series and have it bookmarked. to be honest this is something i dont have the tools or time to do myself. what i wanted to do was get the replacement panels and pay someone to weld them on. i can kinda pull back the sideskirt and see the damage and tbh its not as bad as i was expecting. its more of the spot in the trunk and the area between the rear wheel well and door. Link to comment Share on other sites More sharing options...
Xeryon Posted June 1, 2011 Share Posted June 1, 2011 That's the place. Link to comment Share on other sites More sharing options...
OTiS Posted June 2, 2011 Author Share Posted June 2, 2011 That's the place. nothing for the del sol tho. just civics and crx. would the 92-95 civic ones work since most egs are interchangeable or would the del sol be diffrent? if they would work which should i look at hb,sedan or coupe ones? also what about the wheel arches? Link to comment Share on other sites More sharing options...
Xeryon Posted June 3, 2011 Share Posted June 3, 2011 you need to have sol arches. the del sol body lines were unique to that chassis. last i checked that place had them. d-series would be the place to ask around to find a place that still stocks them. Link to comment Share on other sites More sharing options...
Raley Posted June 3, 2011 Share Posted June 3, 2011 you might be able to mod the civic ones depending on wheel arch, im kinda lazy so im not gunna go make a template and walk over to the sol and check.... sorry... Link to comment Share on other sites More sharing options...
SalvageZone Posted November 2, 2011 Share Posted November 2, 2011 Get a new car. lol Link to comment Share on other sites More sharing options...
OTiS Posted November 3, 2011 Author Share Posted November 3, 2011 way to bring up an old thread. and i dont want to buy a new car i want to keep the sol. dick. Link to comment Share on other sites More sharing options...
