kdozier Posted February 15, 2011 Share Posted February 15, 2011 Hey guys. Long story short: Idler pulley seized up and snapped the belt. I replaced the pulley and I can't figure out how to get the new belt on!! It is a 94 Del Sol S 1.5 with NO power steering. I'm trying to get this belt on and there's this bar between the A/C pulley and the crankshaft pulley. I tried routing it up and over the bar but then the belt is too short. How do I get it under the bar? Please help!!! Link to comment Share on other sites More sharing options...
Raley Posted February 15, 2011 Share Posted February 15, 2011 That bar is called an engine mount and you have to unbolt it, run it through the belt. Link to comment Share on other sites More sharing options...
kdozier Posted February 15, 2011 Author Share Posted February 15, 2011 Okay. So that bar is a metal engine mount? I see it's bolted in either one of two places. 1) Unbolt it at the engine block (2 bolts I think) or 2) There appears to be an access panel at the wheel well and I think I saw a bolt somewhere around there. What is the easiest way to unbolt it? Thank you for the reply!! Link to comment Share on other sites More sharing options...
kdozier Posted February 16, 2011 Author Share Posted February 16, 2011 Never mind... I found where I need to unbolt this thing. 2 14mm bolts hidden behind the plastic under trim.... Great... I'll get to it tomorrow. Link to comment Share on other sites More sharing options...
cmgogo Posted February 16, 2011 Share Posted February 16, 2011 unbolt the 2 bolts holding the mount to the chassis (mind you jack the engine up while you do this) then slowly lower the jack enough to get the belt around it, route belt, tension it, lift motor back up, put the 2 bolts back in. done. Link to comment Share on other sites More sharing options...
Raley Posted February 16, 2011 Share Posted February 16, 2011 Those frame bolts always rust, i pull the 4 on the block. Link to comment Share on other sites More sharing options...
cmgogo Posted February 16, 2011 Share Posted February 16, 2011 hmmm mine never have, i think its just cause your gay raley, they like to be tight for you. Link to comment Share on other sites More sharing options...
kdozier Posted February 17, 2011 Author Share Posted February 17, 2011 Well it's done now! Thanks guys! My bolts weren't rusted. In fact the bolt threads looked brand new. Only the head of the bolts looked aged. I probably spent more time getting the plastic panel back on correctly (tucking it underneath the bumper panel) than I did getting the belt routed and tightened. I ran the engine and made sure the belt wouldn't slip by turning on the air conditioner and revving it. However I noticed something very peculiar about the A/C. The compressor clutch engages when you do not have the your foot on the gas. As soon as I give the engine some throttle the compressor disengages (as if it's free-wheeling) and as it winds down and approaches idle... it re-engages. All the while when this is happening... there's a "hiss" sound (almost sounds like a blow-off valve for turbo). I just got this Del Sol in November so I haven't had to use the A/C yet. But I know it blows cold air. I just never noticed the hissing sound... Next question is "Is this normal?"?? Link to comment Share on other sites More sharing options...
Raley Posted February 21, 2011 Share Posted February 21, 2011 Well. It disengages so you can accelorate then will reengage while cruising. Helps with getting off the line and not robbing power. The his is because ac compresses air, cools it off then releaves the pressure... its multiple valves. Link to comment Share on other sites More sharing options...
kdozier Posted February 22, 2011 Author Share Posted February 22, 2011 Thanks for the useful information Raley Link to comment Share on other sites More sharing options...
Raley Posted February 22, 2011 Share Posted February 22, 2011 i know i help out lots of people but when i see "thanks raley" i still get confused... im use to "your a dork" haha... Link to comment Share on other sites More sharing options...
