salmon2day Posted November 23, 2010 Share Posted November 23, 2010 I have a 1995 Honda Del sol SI the valve cover says Honda Vtec. The trunk lid says Dohc Vtec. Did they make some Del sols in 1995 that are dohc but not write dohc on the valve cover?? My car fax showed no accidents etc and all checked out. Now that Im selling it some people say it is not a Dohc, and that my vin number does not match the dohc cars. Im just curious if the engine was swapped or if they just put a decal on the back. Link to comment Share on other sites More sharing options...
drkyle96 Posted November 23, 2010 Share Posted November 23, 2010 I have a 1995 Honda Del sol SI the valve cover says Honda Vtec. The trunk lid says Dohc Vtec. Did they make some Del sols in 1995 that are dohc but not write dohc on the valve cover?? My car fax showed no accidents etc and all checked out. Now that Im selling it some people say it is not a Dohc, and that my vin number does not match the dohc cars. Im just curious if the engine was swapped or if they just put a decal on the back. Two things you need to check. The VIN# will tell you what engine originally came with the car. You state it is an "Si". The Si came with SOHC and the VIN will have EH6 in the number. Second, you can actually check the engine itself to see if it has one or two cams. There are plenty of pictures on HF depicting both types. The valve covers look completely different. Link to comment Share on other sites More sharing options...
Xeryon Posted November 23, 2010 Share Posted November 23, 2010 easy to tell, compare the valve covers. DOHC has a much wider cover. The colors and inscriptions varied from model to model and year to year, so don't worry if my pictures look a little different. You are just comparing the shape. DOHC SOHC Link to comment Share on other sites More sharing options...
salmon2day Posted November 23, 2010 Author Share Posted November 23, 2010 I have a 1995 Honda Del sol SI the valve cover says Honda Vtec. The trunk lid says Dohc Vtec. Did they make some Del sols in 1995 that are dohc but not write dohc on the valve cover?? My car fax showed no accidents etc and all checked out. Now that Im selling it some people say it is not a Dohc, and that my vin number does not match the dohc cars. Im just curious if the engine was swapped or if they just put a decal on the back. Link to comment Share on other sites More sharing options...
salmon2day Posted November 23, 2010 Author Share Posted November 23, 2010 easy to tell, compare the valve covers. DOHC has a much wider cover. The colors and inscriptions varied from model to model and year to year, so don't worry if my pictures look a little different. You are just comparing the shape. DOHC SOHC VIN: jhmeh6167ss001821 My vin number has ehs in it but the valve cover is that of a sohc. Does that mean its not the original engine? Link to comment Share on other sites More sharing options...
salmon2day Posted November 23, 2010 Author Share Posted November 23, 2010 VIN: jhmeh6167ss001821 My vin number shows eh6 but the valve cover is that of a sohc does that mean it is not the original engine? Link to comment Share on other sites More sharing options...
cmgogo Posted November 23, 2010 Share Posted November 23, 2010 you have and Si that someone rebadged as a VTEC model. Just take the sticker off the trunklid, its not the originial sticker anyways. Link to comment Share on other sites More sharing options...
Xeryon Posted November 24, 2010 Share Posted November 24, 2010 or someone replaced the trunk lid and the repair person was lazy when they took one off of the junkyard donor. Link to comment Share on other sites More sharing options...
