how can i check if my alternator is working
demon_belial
Posted
my lights keep getting dim then they come back to normal i think my alternator is bad how can i check to see if its working properly i do not have no special tools to check voltage. is their another way? I have a 91 accord
Posted
autozone sucks donkey balls.
The 3 times I have taken batteries, or alternators down there they have been completly wrong on the status of the part I have brought them.
Hook up your multimeter and see what voltage you are getting, with the car running you should be getting around 14.1v.
  • 1 month later...
Posted
Disconnect battery, if the car stays running, its good.
Pleas tell disconnect neg or positive cable? Will this damage the engine? Thanks for reply!
Posted
Please tell what if it low than 14.1V or higher than 14.1 V? Thanks for reply.
