cgshonda Posted October 1, 2010 Share Posted October 1, 2010 Having trouble removing Spring Pin (Manual Tranny) I removed cover but cannot get pin out. Haynes Manual says to just pull out. Can't get it out. Would like any help. Thanks Quote Link to comment Share on other sites More sharing options...
cmgogo Posted October 1, 2010 Share Posted October 1, 2010 which spring pin, the bitch pin? Quote Link to comment Share on other sites More sharing options...
mpearce1974 Posted October 1, 2010 Share Posted October 1, 2010 which spring pin, the bitch pin? Obviously! Quote Link to comment Share on other sites More sharing options...
cgshonda Posted October 2, 2010 Author Share Posted October 2, 2010 Having trouble removing Spring Pin (Manual Tranny) I removed cover but cannot get pin out. Haynes Manual says to just pull out. Can't get it out. Would like any help. Thanks YES, I believe it has beeb called Bitch Clip. I see on line a special tool but cost 25.00? Quote Link to comment Share on other sites More sharing options...
airjordan223 Posted October 2, 2010 Share Posted October 2, 2010 Sometimes you can rent tools for autoparts stores since you'll only need to use it once Quote Link to comment Share on other sites More sharing options...
Humphries Posted October 2, 2010 Share Posted October 2, 2010 the shift linkage pin? use a hammer and a punch. Quote Link to comment Share on other sites More sharing options...
cgshonda Posted October 4, 2010 Author Share Posted October 4, 2010 Having trouble removing Spring Pin (Manual Tranny) I removed cover but cannot get pin out. Haynes Manual says to just pull out. Can't get it out. Would like any help. Thanks Just a note on how I solved. From above I used a long scredriver and large hammer to tap the pin down. This got it moved a short distance. Sprayed with thin oil and let sit. The used a long screwdriver with square head (robertson) This acts like the special tool you can buy. The "square" part goes inside and the round part acts like a punch. It came out quite easily. Cgs Quote Link to comment Share on other sites More sharing options...
